Cisco 876 - T-DSL Business
ich bekomme einfache keine DSL-Verbindung zustande.
Die Lämpchen bei OK, CD und PPP leuchten ständig grün am Router, aber kein blinken bei RXD ADSL oder TXD.
Wenn ich einen Connection Test mache, bekomme ich folgende Meldung:
Checking interface status: up
Checking for DNS settings: Failed
DNS configuration check has failed. No DNS Lookup has been configured.
Configure the command 'ip domain-lookup' in the config mode on the router.
Wenn ich dann unter DHCP -> DNS -> Primary DNS einen Eintrag mache
z.B.: 194.25.0.68oder 194.25.0.60 (DNS von Telekom), dann kommt folgende Meldung:
interface physical status : up
Line protocol status: up
Checking for DNS settings: successful
DNS lookup set: Yes
Statically configured DNS servers: none
Dynamically imported DNS servers: 194.25.0.68 194.25.0.60
Checking interface IP address: successful
Interface IP adress: 79.207.168.151
Interface IP address Type: Negotiated
Checking exit interface: Failed
Exit interface found: None
To test connectivity, SDM tries to ping the configured DNS servers. However, there is no configured route to any of the DNS servers through the selected interface.
Select 'User-specified' option or add a 'host specific/network specific/default' route through this interface and reset connection.
Ist das mit den DNS-Adressen überhaupt richtig?
Was mache ich falsch?
hier meine aktuelle Konfiguration (ohne DNS settings):
Building configuration...
Current configuration : 4290 bytes
version 12.4
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
crypto pki trustpoint TP-self-signed-1828894822
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1828894822
revocation-check none
rsakeypair TP-self-signed-1828894822
crypto pki certificate chain TP-self-signed-1828894822
certificate self-signed 01
3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
43BE7880 3FB79D88 D4E3743C 71FED7E3 3D7717
quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
multilink bundle-name authenticated
username admin privilege 15 secret 5 $1$76zT$pfLTOINQRy2Ayyagxnja5/
archive
log config
hidekeys
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 1/32
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
interface Dialer0
ip address negotiated
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname t-online-com/xxxxxxxxxxxxxxxx@t-online-com.de
ppp chap password 0 xxxxxxxx
ppp pap sent-username t-online-com/xxxxxxxxxxxxxxx@t-online-com.de password 0 xxxxxxxx
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege level of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to Shortcut Redirect - Cisco Systems
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
login local
transport input telnet ssh
scheduler max-task-time 5000
end
Neues Benutzerkonto erstellen
Anmelden
