djmaker 95 Geschrieben 21. April 2010 Melden Geschrieben 21. April 2010 https://kc.mcafee.com/corporate/index?page=content&id=KB68780 Environment For details of all supported operating systems, see KB51109 Summary McAfee is aware of a w32/wecorl.a false positive with the 5958 DAT file that was released on April 21, 2010. Problem Blue screen or DCOM error, followed by shutdown messages after updating to the 5958 DAT on April 21, 2010. Solution The issue is resolved in the 5959 DAT file release (April 21, 2010), which is available from the McAfee Security Updates page at: McAfee, Inc. - Downloads - Virus Protection - DAT Files NOTE: Posting of the 5959 DAT file is currently in progress. It may take several hours for the new DAT file to replicate out to all McAfee download servers. IMPORTANT: If you are already affected by this issue, you must still either replace or restore svchost.exe. See Workaround 2 below. McAfee is continuing to work on an automated solution to fully resolve the issue for affected customers. Please watch for updates on this issue, which will be sent on a timely basis through Support Notification Service (SNS) and Platinum Proactive notifications. To subscribe to SNS, visit McAfee Support Subscription Center. This article will be updated as additional information becomes available.
XP-Fan 234 Geschrieben 21. April 2010 Melden Geschrieben 21. April 2010 Hi, danke für die Infos aber du bist leider 2ter Sieger zum Thema McAfee Fehler bei den DAT. :D -> http://www.mcseboard.de/tipps-links-5/mcafee-update-legt-rechner-lahm-164918.html
djmaker 95 Geschrieben 21. April 2010 Autor Melden Geschrieben 21. April 2010 Das ist gemein, ich wollte auch einmal 1. sein. Nun ja, jetzt bin ich es eben von hinten. Bei 2 Posts bekommt es wenigstens jeder mit. :D Sorry wegen dem Doppelpost. PS: Bin ich froh das in einer von mir betreuten Umgebung gerade kleinere Probleme mit der Verteilung von DATs bestehen. :D
XP-Fan 234 Geschrieben 21. April 2010 Melden Geschrieben 21. April 2010 Ich kam gerade von der geschilderten Aktion nach Hause ... :cry: Das ist der zweite Hammer von McAfee in 3 Jahren welchen sie sich geleistet haben. Da wir die Enterprise bei einigen Kunden im Einsatz haben bin ich gerade dran an den EPO's um morgen früh einen Strumlauf abzufangen. Mal schaun, BB Akku ist frisch geladen.
