DAH01CB 10 Geschrieben 12. Mai 2010 Melden Geschrieben 12. Mai 2010 Hallo zusammen, wir sitzen gerade an einem richtig großen Probelm: wir möchten unsere VM "test" auf unserem ESXi 4 sichern. Dazu haben wir uns ghettoVCB rausgesucht. Das script ist richtig entpackt, eine test.conf mit Inhalt: VM_BACKUP_VOLUME=/vmfs/volumes/datastore1/testbackup DISK_BACKUP_FORMAT=thin VM_BACKUP_ROTATION_COUNT=5 POWER_VM_DOWN_BEFORE_BACKUP=0 ENABLE_HARD_POWER_OFF=0 ITER_TO_WAIT_SHUTDOWN=3 POWER_DOWN_TIMEOUT=5 ENABLE_COMPRESSION=0 ADAPTER_FORMAT=buslogic VM_SNAPSHOT_MEMORY=0 VM_SNAPSHOT_QUIESCE=0 VMDK_FILES_TO_BACKUP="all" SNAPSHOT_TIMEOUT=15 erstellt. nun bekommen wir aber in der SSH lauter Fehlermeldungen: 2010-05-12 20:50:00 -- info: Error: failed to locate and extract VM_ID for VM_BACKUP_VOLUME=/vmfs/vo !umes/datastore1/testbackup !010-05-12 20:50:00 -- info: Error: failed to locate and extract VM_ID for DISK_BACKUP_FORMAT=thin 2010-05-12 20:50:00 -- info: Error: failed to locate and extract VM_ID for VM_BACKUP_ROTATION_COUNT= ! 2010-05-12 20:50:00 -- info: Error: failed to locate and extract VM_ID for POWER_VM_DOWN_BEFORE_BACK !P=0 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for ENABLE_HARD_POWER_OFF=0 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for ITER_TO_WAIT_SHUTDOWN=3 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for POWER_DOWN_TIMEOUT=5 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for ENABLE_COMPRESSION=0 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for ADAPTER_FORMAT=buslogic !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for VM_SNAPSHOT_MEMORY=0 !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for VM_SNAPSHOT_QUIESCE=0 2010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for VMDK_FILES_TO_BACKUP="all ! !010-05-12 20:50:01 -- info: Error: failed to locate and extract VM_ID for SNAPSHOT_TIMEOUT=15 2010-05-12 20:50:01 -- info: ###### Final status: ERROR: All VMs failed! ###### 2010-05-12 20:50:01 -- info: ============================== ghettoVCB LOG END ====================== Habt Ihr eione Ahnung, an was das liegen könnte? Vielen Dank schon mal!!!!!! DAH01CB Zitieren
Dr.Melzer 191 Geschrieben 12. Mai 2010 Melden Geschrieben 12. Mai 2010 Ich hab deinen Threadtitel mal ein wenig editiert. Titel wie "ich brauche dringend Hilfe!" bringen wenig. Du kannst davon ausgehen dass fast jeder hier dringend Hife benötigt... Zitieren
RanCyyD 10 Geschrieben 14. Mai 2010 Melden Geschrieben 14. Mai 2010 Schau mal, ob Dir das hilft: ghettoVCB4i.sh In diesem Beispiel wird als root mit dem Passwort P@ssw0rd auf den ESXi Server 1.2.3.4 zugegriffen (Punkt 3.1.1). Es wird das Script ghettoVCB4i.sh ausgeführt, welches auf dem Opensolaris Backup Server im Unterverzeichnis Backupscript liegt. Welche VMs zu sichern sind wird im .txt File vmbackup.one festgelegt. Siehe http://communities.vmware.com/docs/DOC-8760. Im Header des Scripts sind einige Angaben zu ändern, diese habe ich rot makiert. #!/bin/ash # Author: william2003[at]gmail[dot]com # Creation Date: 05/27/2008 # directory that all VM backups should go (e.g. /vmfs/volumes/SAN_LUN1/mybackupdir) VM_BACKUP_VOLUME=/vmfs/volumes/opensolaris/Backup # Format output of VMDK backup # 1 = zeroedthick # 2 = 2gbsparse # 3 = thin # 4 = eagerzeroedthick VMDK_OUTPUT_FORMAT=3 # Number of backups for a given VM before deleting VM_BACKUP_ROTATION_COUNT=5 Installation Opensolaris als ESXi Backup Server | ngud.de Zitieren
cschra 10 Geschrieben 18. Mai 2010 Melden Geschrieben 18. Mai 2010 Ich hab mich da gerade komplett durchgewuselt! Bitte poste mal deinen Befehl mit der du die gehtteVCB.sh aufrufst. Außerdem würde ich den Parameter VMDK_FILES_TO_BACKUP="all" weglassen und das script einfach mit einem -a aufrufen. Zitieren
unwissend 10 Geschrieben 31. Dezember 2010 Melden Geschrieben 31. Dezember 2010 Ich nutze das kleine Backupprogramm für Windows: "esxi backup" und konnte endlich auf den faq's die Lösung zum Fehler finden. Juhuuu Soweit ich glaube muss der Name der Virtuellen Maschine angepasst werden ESXi Backup GUI - ESXi Backup Wizard irgendwo stehts grüsse aus bern und guten rutsch :D Zitieren
samsam 14 Geschrieben 31. Dezember 2010 Melden Geschrieben 31. Dezember 2010 Moin, Step by Step guide: Sicherung von virtuellen Maschinen auf VMware ESXi mit ghettoVCB.sh und wenn Automatisch möchtest: Automatisches Backup der ESXi Gäste mfg Zitieren
Innuendo 10 Geschrieben 31. Dezember 2010 Melden Geschrieben 31. Dezember 2010 Da es nur Fehlermeldungen gibt: der ssh Zugang ist geöffnet und Du hast auch einmal mit Putty eine Verbindung hergestellt, um den RSA Key zu erstellen? Ich habe ghettoVCB über mkbackup (W2K3/W2K8) im Einsatz, inkl. logs per EMail innu Zitieren
