Exchnage 2010 und Autodiscover
Geschrieben (bearbeitet)
ich habe ein Problem mit dem Autodiscover Service in Exchange 2010. Wenn ich Outlook über Autodiscover konfigurieren möchte fragt er mich ständig nach dem Passwort für sich am Server anmelden zu können. Egal was ich dort eingebe, es erscheint immer die Passwort abfrage.
Wenn ich Outlook per Hand konfiguriere funktioniert Outlook Anywehre ohne Probleme.
Hab sicherlich eine Kofigurationsfehler, zeigt auch der Test
Hier mal den Log com Connectivity test:
ExRCA is testing RPC/HTTP connectivity.
The RPC/HTTP test failed.
Test Steps
Attempting to test Autodiscover for administrator@mydomain.de
Testing Autodiscover failed.
Test Steps
ExRCA is attempting each method of contacting the Autodiscover service.
The Autodiscover service couldn't be contacted successfully by any method.
Test Steps
Attempting to test potential AutoDiscover URL https://mydomain.de/AutoDiscover/AutoDiscover.xml
Testing of this potential Autodiscover URL failed.
Test Steps
Attempting to resolve the host name mydomain.de in DNS.
Host successfully resolved
Additional Details
IP(s) returned: 212.xx.XX.203
Testing TCP Port 443 on host mydomain.de to ensure it is listening and open.
The port was opened successfully.
ExRCA is testing the SSL certificate to make sure it's valid.
The SSL certificate failed one or more certificate validation checks.
Tell me more about this issue and how to resolve it
Additional Details
A network error occurred while communicating with remote host
Exception details:
Message: The handshake failed due to an unexpected packet format.
Type: System.IO.IOException
Attempting to test potential AutoDiscover URL https://autodiscover.mydomain.de/AutoDiscover/AutoDiscover.xml
Test Steps
Attempting to resolve the host name autodiscover.mydomain.de in DNS.
Additional Details
IP(s) returned: 217.xx.xx.12
Testing TCP Port 443 on host autodiscover.mydomain.de to ensure it is listening and open.
ExRCA is attempting to contact the Autodiscover service using the HTTP redirect method.
The attempt to contact Autodiscover using the HTTP Redirect method failed.
Test Steps
Additional Details
Testing TCP Port 80 on host autodiscover.mydomain.de to ensure it is listening and open.
The specified port is either blocked, not listening, or not producing the expected response.
Additional Details
Exception details:
Message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 217.xx.xx.12:80
Type: System.Net.Sockets.SocketException
Stack trace:
at System.Net.Sockets.TcpClient.Connect(String hostname, Int32 port)
at Microsoft.Exchange.Tools.ExRca.Tests.TcpPortTest.PerformTestReally()
ExRCA is attempting to contact the Autodiscover service using the DNS SRV redirect method.
Failed to contact AutoDiscover using the DNS SRV redirect method.
Test Steps
Attempting to locate SRV record _autodiscover._tcp.mydomain.de in DNS.
The Autodiscover SRV record wasn't found in DNS.
bearbeitet von Maverick04
Neues Benutzerkonto erstellen
Anmelden
