Ecke83 10 Geschrieben 23. August 2010 Melden Geschrieben 23. August 2010 Hi, ich habe mir soeben das ISO zur Windows 7 Professional 64 Bit DVD aus dem Partner Network heruntergeladen und versucht dieses zu brenne. Leider ohne Erfolg. Ich habe es auf 2 Maschinen ausprobiert, aber der Fehler bleibt der selbe. Hier ein Log von ImgBurn: I 12:51:25 ImgBurn Version 2.5.1.0 started! I 12:51:25 Microsoft Windows Vista Business Edition (6.0, Build 6002 : Service Pack 2) I 12:51:25 Total Physical Memory: 2.095.960 KB - Available: 952.544 KB W 12:51:25 Duplex Secure's SPTD driver can have a detrimental effect on drive performance. I 12:51:25 Initialising SPTI... I 12:51:25 Searching for SCSI / ATAPI devices... I 12:51:26 -> Drive 1 - Info: HL-DT-ST DVD-ROM GDR8164B 0L06 (F:) (ATA) I 12:51:26 -> Drive 2 - Info: SAMSUNG CD-R/RW SW-232B R300 (G:) (ATA) I 12:51:26 -> Drive 3 - Info: DELIH V0HIBOX2R 1.03 (H:) (SCSI) I 12:51:26 -> Drive 4 - Info: HL-DT-ST DVDRAM GSA-H10N JL10 (I:) (USB) I 12:51:26 Found 1 CD-RW, 1 DVD-ROM, 1 DVD±RW/RAM and 1 BD-ROM/HD DVD-ROM! I 12:51:54 Operation Started! I 12:51:54 Source File: E:\Share\SW_DVD5_Win_Pro_7_64BIT_German_X15-65813.ISO I 12:51:54 Source File Sectors: 1.558.723 (MODE1/2048) I 12:51:54 Source File Size: 3.192.264.704 bytes I 12:51:54 Source File Volume Identifier: GRMCPRXFRER_DE_DVD I 12:51:54 Source File Volume Set Identifier: 4eddd80 I 12:51:54 Source File Application Identifier: CDIMAGE 2.54 (01/01/2005 TM) I 12:51:54 Source File Implementation Identifier: Microsoft CDIMAGE UDF I 12:51:54 Source File File System(s): ISO9660 (Bootable); UDF (1.02) I 12:51:54 Destination Device: [0:0:0] HL-DT-ST DVDRAM GSA-H10N JL10 (I:) (USB) I 12:51:54 Destination Media Type: DVD-R (Disc ID: TTH02) (Speeds: 4x; 8x; 16x) I 12:51:54 Destination Media Sectors: 2.297.888 I 12:51:54 Write Mode: DVD I 12:51:54 Write Type: DAO I 12:51:54 Write Speed: MAX I 12:51:54 Link Size: Auto I 12:51:54 Lock Volume: Yes I 12:51:54 Test Mode: No I 12:51:54 OPC: No I 12:51:54 BURN-Proof: Enabled I 12:51:54 Write Speed Successfully Set! - Effective: 22.159 KB/s (16x) I 12:51:54 Filling Buffer... (40 MB) I 12:51:56 Writing LeadIn... W 12:52:19 Failed to Write Sectors 0 - 31 - Reason: Das Zeitlimit für die Semaphore wurde erreicht. W 12:52:19 Retrying (1 of 20)... W 12:52:20 Retry Failed - Reason: Power On, Reset, or Bus Device Reset Occurred W 12:52:20 Retrying (2 of 20)... W 12:52:20 Retry Failed - Reason: Cannot Write Medium - Incompatible Format W 12:52:20 Retrying (3 of 20)... W 12:52:20 Retry Failed - Reason: Cannot Write Medium - Incompatible Format W 12:52:20 Retrying (20 of 20)... W 12:52:20 Retry Failed - Reason: Cannot Write Medium - Incompatible Format W 12:52:31 Retrying (21)... W 12:52:31 Retry Failed - Reason: Cannot Write Medium - Incompatible Format E 12:52:32 Failed to Write Sectors 0 - 31 - Reason: Das Zeitlimit für die Semaphore wurde erreicht. I 12:52:32 Synchronising Cache... W 12:52:41 User opted to skip the 'Close Track/Session/Disc' functions. E 12:52:41 Failed to Write Image! E 12:52:41 Operation Failed! - Duration: 00:00:47 I 12:52:41 Average Write Rate: N/A - Maximum Write Rate: N/A I 13:04:30 Close Request Acknowledged I 13:04:30 Closing Down... I 13:04:31 Shutting down SPTI... I 13:04:31 ImgBurn closed! Habe es auch mit Nero und CDBurnerXp probiert. Alles ohne Erfolg Hat jemand ein Idee? Muss man etwas bestimmtes beachten oder das ISO einfach brennen? MfG Ecke Zitieren
Sunny61 819 Geschrieben 23. August 2010 Melden Geschrieben 23. August 2010 (bearbeitet) Wenn die ausgewählten Brennprogramme das unterstützen, sollte ein normales Brennen des ISO ausreichen. ISO mit dem Brennprogramm öffnen und brennen. Alternativ virtual-clonedrive installieren, das ISO damit öffnen und erst jetzt brennen/kopieren. bearbeitet 23. August 2010 von Sunny61 Posting korrigiert Zitieren
Gulp 275 Geschrieben 23. August 2010 Melden Geschrieben 23. August 2010 Off-Topic:@Sunny: Uuuuuuiiii böse Domain! WinRAR kann auch ISO's öffnen und extrahieren (7zip auch wenn ich mich nicht täusche), da geht einem dann leider nur der Bootblock flöten, zum checken der Integrität des ISO's reicht es aber meist dicke aus.GrüsseGulp Zitieren
Ecke83 10 Geschrieben 23. August 2010 Autor Melden Geschrieben 23. August 2010 (bearbeitet) Das WinRAR entpacken hat ohne Probleme geklappt. Ich hab mir jetzt mal nen Rechner mit internem DVD RW Laufwerk gesucht. Mal sehen ob es nun funktioniert. Aber aus euren ANtworten höre ich, das ich nicht einen speziellen Modus benötige oder soetwas. ALso hoffe ich mal das ich es hinbekomme :) Danke. Nachtrag: Mit einem internen DVD Brenner hat es sofort funktioniert :) bearbeitet 23. August 2010 von Ecke83 Zitieren
Sunny61 819 Geschrieben 23. August 2010 Melden Geschrieben 23. August 2010 Off-Topic:@Sunny: Uuuuuuiiii böse Domain! Ups, sorry, habs auch grade erst geschnallt. ;) Zitieren
zahni 571 Geschrieben 23. August 2010 Melden Geschrieben 23. August 2010 Für den Brenner gibt es eine akuellere Firmware LG Produkt Support für GSA-H10N . Medium nicht mit16x brennen, sonder mit 8x oder langsamer. -Zahni Zitieren
oz42 10 Geschrieben 24. August 2010 Melden Geschrieben 24. August 2010 Auch nett für solche Aufgaben: ISO Recorder Olaf Zitieren
