Dcdiag
Leider keine Lösung
Habe jetzt alles überprüft, DNS, DHCP, WINS......alles läuft ohne Fehler, trotzdem erhalte ich die Meldung:
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Standardname-des-ersten-Standorts\SRV02
Starting test: Connectivity
SRV02's server GUID DNS name could not be resolved to an
IP address. Check the DNS server, DHCP, server name, etc
Although the Guid DNS name
(450f8da8-f94b-48e6-9144-3f8e5d96ed6f._msdcs.ELOCAB.local) couldn't be
resolved, the server name (SRV02.ELOCAB.local) resolved to the IP
address (192.168.168.1) and was pingable. Check that the IP address
is registered correctly with the DNS server.
......................... SRV02 failed test Connectivity
Doing primary tests
Skipping all tests, because server SRV02 is
not responding to directory service requests
Running enterprise tests on : ELOCAB.local
Starting test: Intersite
......................... ELOCAB.local passed test Intersite
Starting test: FsmoCheck
......................... ELOCAB.local passed test FsmoCheck
Fällt Euch eine Lösung ein?
Danke und Gruß, Jürgen
Dieses Thema wurde für weitere Antworten geschlossen.
