adam33 10 Geschrieben 19. Januar 2011 Melden Geschrieben 19. Januar 2011 Hey, ich implementiere gerade softewaredeployment mit wpkg. Dazu habe ich ein vbs, welches die Rechner im Netz ausliest. Const ADS_SCOPE_SUBTREE = 2 set fs = CreateObject("Scripting.FileSystemObject") set textstream = fs.CreateTextFile("hosts.xml", True) textstream.WriteLine "<?xml version=""1.0"" encoding=""UTF-8""?>" & vbCrLf textstream.WriteLine "<!-- automagically generated with " & Wscript.ScriptFullName textstream.WriteLine " Date: " & Date() & " -->" & vbCrLf & vbCrLf textstream.WriteLine "<wpkg>" Set rootDSE = GetObject("LDAP://RootDSE") domainContainer = rootDSE.Get("defaultNamingContext") Set objConnection = CreateObject("ADODB.Connection") Set objCommand = CreateObject("ADODB.Command") objConnection.Provider = "ADsDSOObject" objConnection.Open "Active Directory Provider" Set objCOmmand.ActiveConnection = objConnection objCommand.CommandText = _ "Select Name, distinguishedName from 'LDAP://" & domainContainer & "' " _ & "Where objectClass='computer'" objCommand.Properties("Page Size") = 1000 objCommand.Properties("Searchscope") = ADS_SCOPE_SUBTREE Set objRecordSet = objCommand.Execute objRecordSet.MoveFirst Do Until objRecordSet.EOF 'Wscript.Echo "Computer Name: " & objRecordSet.Fields("Name").Value 'Wscript.Echo "distinguishedName: " & objRecordSet.Fields("distinguishedName").Value arrPath = Split(objRecordSet.Fields("distinguishedName").Value, ",") strOU = "" for each a in arrPath if left(a,2) = "OU" Then strOU = "/" & right(a,len(a) - 3) & strOU End If Next 'Wscript.Echo "Path: " & StrOU textstream.WriteLine vbTab & "<host name=""" & objRecordSet.Fields("Name").Value & """ profile-id=""" & StrOU & """ />" objRecordSet.MoveNext Loop textstream.WriteLine "</wpkg>" textstream.close Wscript.Echo "Finished..." Hat einer eine Idee, wie ich wichtige Rechner, also server, außen vor lassen kann? MfG Zitieren
