Klettermaxx 10 Geschrieben 9. Februar 2011 Melden Geschrieben 9. Februar 2011 Bei folgender Konfiguration Output Drops auf dem Interface. Hat jemand eine Idee. Alle anderen Router machen auch keine Probleme. Bandbreitentechnisch ist kein Problem zu erwarten. Ohne Policy gibt es keine Drops. IOS:c1900-universalk9-mz.SPA.151-3.T #show policy-map interface GigabitEthernet0/0 Service-policy output: SHAPE-50M Class-map: class-default (match-any) 1006004 packets, 206579626 bytes 5 minute offered rate 125000 bps, drop rate 0 bps Match: any Queueing queue limit 64 packets (queue depth/total drops/no-buffer drops) 0/17/0 (pkts output/bytes output) 1005988/206543467 shape (average) cir 47500000, bc 190000, be 190000 target shape rate 47500000 Service-policy : QOS Class-map: VOICE (match-all) 86729 packets, 13168785 bytes 5 minute offered rate 3000 bps, drop rate 0 bps Match: ip precedence 5 Queueing queue limit 64 packets (queue depth/total drops/no-buffer drops) 0/0/0 (pkts output/bytes output) 86729/13168785 bandwidth 33% (15675 kbps) Class-map: class-default (match-any) 919275 packets, 193410841 bytes 5 minute offered rate 121000 bps, drop rate 0 bps Match: any queue limit 64 packets (queue depth/total drops/no-buffer drops) 0/17/0 (pkts output/bytes output) 919259/193374682 QoS Set precedence 0 Packets marked 918857 #show interfaces GigabitEthernet 0/0 GigabitEthernet0/0 is up, line protocol is up Hardware is CN Gigabit Ethernet, address is 588d.09a1.a080 (bia 588d.09a1.a080) Internet address is xxx.xxx.xxx.xxx/30 MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Full Duplex, 100Mbps, media type is RJ45 output flow-control is unsupported, input flow-control is unsupported ARP type: ARPA, ARP Timeout 04:00:00 Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 02:01:46 Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 17 Queueing strategy: Class-based queueing Output queue: 0/1000/0 (size/max total/drops) 5 minute input rate 165000 bits/sec, 139 packets/sec 5 minute output rate 127000 bits/sec, 144 packets/sec 3125285 packets input, 2300316026 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog, 0 multicast, 0 pause input 2790158 packets output, 716665254 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 babbles, 0 late collision, 0 deferred 0 lost carrier, 0 no carrier, 0 pause output 0 output buffer failures, 0 output buffers swapped out class-map match-all VOICE match ip precedence 5 ! policy-map QOS class VOICE bandwidth percent 33 class class-default set precedence 0 policy-map SHAPE-50M class class-default shape average 47500000 service-policy QOS ! interface GigabitEthernet0/0 ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx no ip proxy-arp duplex full speed 100 service-policy output SHAPE-50M
Otaku19 33 Geschrieben 10. Februar 2011 Melden Geschrieben 10. Februar 2011 bin kein QoS Profi aber: (queue depth/total drops/no-buffer drops) 0/17/0 = Input queue: 1/75/0/0 (size/max/drops/flushes); Total output drops: 17 somit wird von intern mit mehr als deinen zugelassenen 47,5Mb gesendet und zwar anscheinend so lange/so viel das dir der Puffer übergelaufen ist, ewig kann shaping zu viele Daten nicht speichern, wenn der Puffer voll ist wird gedropt.
Wordo 11 Geschrieben 10. Februar 2011 Melden Geschrieben 10. Februar 2011 Bin auch nich die QoS Leuchte, aber dreh mal BE und BC auf ... wenn am Anfang zu viel zu schnell gesendet wird greifen die halt.
tom12 10 Geschrieben 23. März 2011 Melden Geschrieben 23. März 2011 Hi! Ist klar dass du output drops am Interface hast. Die 17 pakete kommen von den drops in der default-class queue limit 64 packets (queue depth/total drops/no-buffer drops) 0/17/0 <----- (pkts output/bytes output) 919259/193374682 Ohne QOS am Interface hast du keine drops, da das Interface nie ans limit kommt (100 Mbit)! In dem falle wird dein Provider droppen. Also: Das passt so. Output am Interface ist einfach einmal ganz kurz das Limit von ca. 50 Mbit überschritten worden. Ich würde auch nicht undbedingt am BC, BE drehen.. Was du generell machen könntest: random-detect und fair-queue in der default class aktivieren. Grüsse, Thomas
