benny0614 10 Geschrieben 21. Februar 2011 Melden Geschrieben 21. Februar 2011 Hallo zusammen, bei der Installation des System Center Virtual Machine Manager tritt eine Fehlermeldung auf und zwar: System Center Virtual Machine Manager was not installed successfully. Review the error log information and then try running Setup again. ID: 205. Details: Dieses Installationspaket konnte nicht geöffnet werden. Wenden Sie sich an den Hersteller der Anwendung, um sicherzustellen, dass es sich um ein gültiges Windows-Installationspaket handelt MSI (s) (50:60) [09:02:52:020]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI (s) (50:60) [09:02:52:020]: Restoring environment variables MSI © (2C:4C) [09:02:52:023]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1 MSI © (2C:4C) [09:02:52:024]: MainEngineThread is returning 1620 === Verbose logging stopped: 21.02.2011 09:02:52 === [21.02.2011 09:02:52] Information : MsiInstallProduct returned 1620. [21.02.2011 09:02:52] Information : End install. [21.02.2011 09:02:52] Information : ************************************************************************************** [21.02.2011 09:02:52] * Exception : => System Center Virtual Machine Manager was not installed successfully.Review the error log information and then try running Setup again.Microsoft.VirtualManager.Setup.Exceptions.BackEndErrorException: System Center Virtual Machine Manager was not installed successfully. Review the error log information and then try running Setup again. ---> Microsoft.VirtualManager.Setup.Exceptions.MsiInvokeException: System Center Virtual Machine Manager was not installed successfully. Review the error log information and then try running Setup again. bei Microsoft.VirtualManager.Setup.Wizard.Installer.Install() bei Microsoft.VirtualManager.Setup.Wizard.BackEnd.Install(Installer installer) *** Carmine error was: InstallFailed (205); WindowsAPI *** C:\ProgramData\VMMLogs\ServerSetup.log ** --- Ende der internen Ausnahmestapelüberwachung --- bei Microsoft.VirtualManager.Setup.Wizard.BackEnd.Install(Installer installer) bei Microsoft.VirtualManager.Setup.Wizard.VMInstaller.Install() bei Microsoft.VirtualManager.Setup.Wizard.ProgressPage.InstallVm() bei Microsoft.VirtualManager.Setup.Wizard.ProgressPage.InstallerThreadEntry() *** Carmine error was: InstallFailed (205); WindowsAPI *** C:\ProgramData\VMMLogs\ServerSetup.log ** [21.02.2011 09:02:52] *** Error : System Center Virtual Machine Manager was not installed successfully. Review the error log information and then try running Setup again. ID: 205. Details: Dieses Installationspaket konnte nicht geöffnet werden. Wenden Sie sich an den Hersteller der Anwendung, um sicherzustellen, dass es sich um ein gültiges Windows-Installationspaket handelt [21.02.2011 09:02:52] Information : Virtual Machine Manager Server installation did not successfully install. All items that were copied during the installation process have been removed, however some required prerequisite software is still present on the machine. It is not necessary to remove the remaining software before you run Setup again. But you can uninstall the prerequisite software by going to Add or Remove Programs. [21.02.2011 09:05:15] Information : <<< Dialog >>> Progress Page : Leaving[/indent] Hab alle Updates auf dem System installiert Windows Installer Dienst ist gestartet Windows Installer auch schon neu in der Registrierdatenbank angelegt msiexec /unregister msiexec /regserver .net Framework 4 noch installiert Hilft bis jetzt alles nichts, hoffe hier kann mir weitergeholfen werden :) Grüße Benjamin Zitieren
Necron 71 Geschrieben 21. Februar 2011 Melden Geschrieben 21. Februar 2011 Hi, um welche Version des SCVMM handelt es sich? Zitieren
benny0614 10 Geschrieben 21. Februar 2011 Autor Melden Geschrieben 21. Februar 2011 Oh ganz vergessen :) es handelt sich hierbei um: Microsoft System Center Virtual Machine Manager 2008 R2 (64Bit) Danke schonmal Zitieren
Necron 71 Geschrieben 21. Februar 2011 Melden Geschrieben 21. Februar 2011 Aus deinem Titel entnehme ich, dass Windows Server 2008 auf dem Server läuft. 32-Bit oder 64-Bit? Service Pack 2 installiert? Zitieren
benny0614 10 Geschrieben 22. Februar 2011 Autor Melden Geschrieben 22. Februar 2011 Läuft auf 64 Bit aber das Problem ist jetzt behoben. Lösung: SCVMM neu heruntergeladen Manchmal ist der Microsoft Download Manager wohl doch noch nicht so gut... Grüße Benjamin Zitieren
Necron 71 Geschrieben 22. Februar 2011 Melden Geschrieben 22. Februar 2011 Danke fürs Feedback!:) Zitieren
