fis5 10 Geschrieben 19. April 2011 Melden Geschrieben 19. April 2011 Hallo Zusammen, ich habe eine Problem mit dem Hinzufügen eines Windows Server 208 R2 in die bestehende SBS 2003 AD. Ich habe auf den SBS 2003 schon adprep durchgeführt. Anschließend wollte ich den Windows Server 2008 mit DCpromo als 2 DC in die Domaine bringen. DCPromo ist auch durchgelaufen doch sind die Objekte nicht repliriert worden. In den Logs steht nur das die SBS2003 nicht erreichbar sei. Dann habe ich bei dem SBS 2003 mal DCDIAG ausgeführt und folgendes rausbekommen. Testing server: Standardname-des-ersten-Standorts\SERVER1 Starting test: Connectivity The directory service on SERVER1 has not finished initializing. In order for the directory service to consider itself synchronized, it must attempt an initial synchronization with at least one replica of this server's writeable domain. It must also obtain Rid information from the Rid FSMO holder. The directory service has not signalled the event which lets other services know that it is ready to accept requests. Services such as the Key Distribution Center, Intersite Messaging Service, and NetLogon will not consider this system as an eligible domain controller. The directory service on SERVER1 has not finished initializing. In order for the directory service to consider itself synchronized, it must attempt an initial synchronization with at least one replica of this server's writeable domain. It must also obtain Rid information from the Rid FSMO holder. The directory service has not signalled the event which lets other services know that it is ready to accept requests. Services such as the Key Distribution Center, Intersite Messaging Service, and NetLogon will not consider this system as an eligible domain controller. ......................... SERVER1 passed test Connectivity Doing primary tests Testing server: Standardname-des-ersten-Standorts\SBS2003 Starting test: Replications REPLICATION LATENCY WARNING SBS2003: A full synchronization is in progress from SERVER1 to SBS2003 Replication of new changes along this path will be delayed. The full sync is 99,73% complete. . There are warning or error events within the last 24 hours after the SYSVOL has been shared. Failing SYSVOL replication problems may cause Group Policy problems. SERVER1 failed test Advertising Starting test: KnowsOfRoleHolders SERVER1 passed test KnowsOfRoleHolders Starting test: RidManager Warning: attribute rIdSetReferences missing from CN=SERVER1,OU=Domain C ontrollers,DC=domain,DC=local Could not get Rid set Reference :failed with 8481: Bei der Suche konnte n keine Attribute aus der Datenbank abgerufen werden. ......................... SERVER1 failed test RidManager Starting test: systemlog An Error Event occured. EventID: 0x0000410B Time Generated: 04/19/2011 15:44:58 (Event String could not be retrieved) An Error Event occured. EventID: 0x0000410B Time Generated: 04/19/2011 16:26:44 (Event String could not be retrieved) ......................... SERVER1 failed test systemlog Starting test: VerifyReferences Some objects relating to the DC SERVER1 have problems: [1] Problem: Missing Expected Value Base Object: CN=SERVER1,OU=Domain Controllers,DC=domain,DC=local Base Object Description: "DC Account Object" Was kann ich noch machen damit sich die Domaine repliziert? Danke für eure Hilfe Gruß Frank Zitieren
Schmidddi 10 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 In einer SBS Domäne ist nur der SBS als Domänencontroller erlaubt (so war mal die Antwort an der MS Hotline bei Stellung derselben Frage). Weitere Server können wohl nur als normale Memberserver hinzugefügt werden. Zitieren
GuentherH 61 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Hallo. In einer SBS Domäne ist nur der SBS als Domänencontroller erlaubt Sorry, aber das ist völlig falsch. Der SBS muss nur der Rollenhalter sein, bzw es darf kein weiterer SBS in der gleichen Domäne installiert sein. Für weitere Infos einfach nur die Suchfunktion benutzen. LG Günther Zitieren
Schmidddi 10 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Sorry, aber das ist völlig falsch. Wie gesagt so war die Antwort des MS Support :-) Zitieren
iDiddi 27 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Wie gesagt so war die Antwort des MS Support Ja, ja. Diese Falschaussage hält sich wacker :( Das hört man ständig. Dadurch wird sie aber nicht richtig. Zitieren
Dukel 460 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Wer ist "SERVER1"? Womit soll sich der SBS replizieren? Gibt es schon einen anderen DC? Hat der neue DC den SBS als DNS Server eingetragen? Zitieren
lefg 276 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Konnte der Server der Domäne als Member hinzugefügt werden? Zitieren
dmetzger 10 Geschrieben 20. April 2011 Melden Geschrieben 20. April 2011 Wie gesagt so war die Antwort des MS Support :-) Kann ich mir im Jahr 2011 kaum mehr vorstellen. Debunking Myths About Additional Domain Controllers In SBS Domains - The Official SBS Blog - Site Home - TechNet Blogs How to install Small Business Server 2003 in an existing Active Directory domain How to prepare the SBS domain for an additional R2 Domain Controller Zitieren
