Ghostolani 10 Geschrieben 6. Juni 2011 Melden Geschrieben 6. Juni 2011 Hallo, ich habe eine Problem bei einem Cisco Router 876. Die Remote Verbindung über ISDN zur Wartung bricht immer wieder ab. Es kommt kein Verbindungsaufbau zu stande. Im Anschluss der Debug. Kann mir jemand einen Tip geben wo ich mit suchen anfangen soll? :confused: Danke schon mal im vorraus ... ay 26 18:31:55.113: ISDN BR0 Q931: RX <- SETUP pd = 8 callref = 0x01 Sending Complete Bearer Capability i = 0x8890 Standard = CCITT Transfer Capability = Unrestricted Digital Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0x89 Exclusive, B1 Calling Party Number i = 0x2181, '351XXXXXXXX' Plan:ISDN, Type:National Called Party Number i = 0xC1, 'XXXXXXX' Plan:ISDN, Type:Subscriber(local) *May 26 18:31:55.117: BR0:1 DDR: Caller id 351XXXXXXX matched to profile IT1_Mgmt *May 26 18:31:55.117: BR0:1: interface must be fifo queue, force fifo *May 26 18:31:55.117: %DIALER-6-BIND: Interface BR0:1 bound to profile Di3 *May 26 18:31:55.121: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 351XXXXXXX N/A c876W_SVS-AD_V3# *May 26 18:31:55.121: ISDN BR0 Q931: TX -> CALL_PROC pd = 8 callref = 0x81 Channel ID i = 0x89 Exclusive, B1 *May 26 18:31:55.125: BR0:1 PPP: Using dialer call direction *May 26 18:31:55.125: BR0:1 PPP: Treating connection as a callin *May 26 18:31:55.125: BR0:1 PPP: Session handle[A5000014] Session id[15] *May 26 18:31:55.125: BR0:1 PPP: Phase is ESTABLISHING, Passive Open *May 26 18:31:55.125: BR0:1 LCP: State is Listen *May 26 18:31:55.145: ISDN BR0 Q931: TX -> CONNECT pd = 8 callref = 0x81 *May 26 18:31:55.305: ISDN BR0 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x01 c876W_SVS-AD_V3# *May 26 18:31:57.109: BR0:1 LCP: Timeout: State Listen *May 26 18:31:57.109: BR0:1 PPP: Authorization required *May 26 18:31:57.109: BR0:1 LCP: O CONFREQ [Listen] id 81 len 15 *May 26 18:31:57.109: BR0:1 LCP: AuthProto CHAP (0x0305C22305) *May 26 18:31:57.109: BR0:1 LCP: MagicNumber 0x1BFB2D40 (0x05061BFB2D40) c876W_SVS-AD_V3# *May 26 18:31:59.124: BR0:1 LCP: Timeout: State REQsent *May 26 18:31:59.124: BR0:1 LCP: O CONFREQ [REQsent] id 82 len 15 *May 26 18:31:59.124: BR0:1 LCP: AuthProto CHAP (0x0305C22305) *May 26 18:31:59.124: BR0:1 LCP: MagicNumber 0x1BFB2D40 (0x05061BFB2D40) c876W_SVS-AD_V3# *May 26 18:32:01.120: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 351XXXXXXX N/A c876W_SVS-AD_V3# *May 26 18:32:01.140: BR0:1 LCP: Timeout: State REQsent *May 26 18:32:01.140: BR0:1 LCP: O CONFREQ [REQsent] id 83 len 15 *May 26 18:32:01.140: BR0:1 LCP: AuthProto CHAP (0x0305C22305) *May 26 18:32:01.140: BR0:1 LCP: MagicNumber 0x1BFB2D40 (0x05061BFB2D40) c876W_SVS-AD_V3# *May 26 18:32:17.264: BR0:1 LCP: Timeout: State REQsent *May 26 18:32:17.264: BR0:1 DDR: disconnecting call *May 26 18:32:17.264: BR0:1 LCP: State is Listen *May 26 18:32:17.264: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 351XXXXXXX , call lasted 22 seconds *May 26 18:32:17.264: ISDN BR0 Q931: TX -> DISCONNECT pd = 8 callref = 0x81 Cause i = 0x8090 - Normal call clearing *May 26 18:32:17.392: ISDN BR0 Q931: RX <- RELEASE pd = 8 callref = 0x01 *May 26 18:32:17.396: BR0 DDR: has total 0 call(s), dial_out 0, dial_in 0 *May 26 18:32:17.396: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di3 c876W_SVS-AD_V3# *May 26 18:32:17.396: ISDN BR0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81 *May 26 18:32:17.396: BR0:1 PPP: Sending Acct Event[Down] id[16] *May 26 18:32:17.396: BR0:1 LCP: State is Closed *May 26 18:32:17.396: BR0:1 PPP: Phase is DOWN Zitieren
blackbox 10 Geschrieben 7. Juni 2011 Melden Geschrieben 7. Juni 2011 Hi, kannst du mal das Chap debuggen - den das kommt nicht zum Erfolg. Zitieren
Ghostolani 10 Geschrieben 7. Juni 2011 Autor Melden Geschrieben 7. Juni 2011 Guten Morgen, debugg ppp authentication bringt folgenden Log nach einmaliger Anwahl. Gibt es noch einen debugg genau für chap -- kann den gerade nicht finden ... May 23 19:44:28.805: %DIALER-6-BIND: Interface BR0:1 bound to profile Di3 *May 23 19:44:28.809: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 351XXXXXXX N/A c876W_SVS-AD_V3# *May 23 19:44:28.825: BR0:1 PPP: Using dialer call direction *May 23 19:44:28.825: BR0:1 PPP: Treating connection as a callin *May 23 19:44:28.825: BR0:1 PPP: Session handle[EB000002] Session id[1] c876W_SVS-AD_V3# *May 23 19:44:30.801: BR0:1 PPP: Authorization required c876W_SVS-AD_V3# *May 23 19:44:34.808: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 351XXXXXXX N/A c876W_SVS-AD_V3# *May 23 19:44:50.956: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 351XXXXXXX , call lasted 22 seconds *May 23 19:44:51.088: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di3 Zitieren
DocZenith 12 Geschrieben 7. Juni 2011 Melden Geschrieben 7. Juni 2011 Wie sieht denn deine Einwahlconfig auf dem Router aus? Zitieren
Ghostolani 10 Geschrieben 7. Juni 2011 Autor Melden Geschrieben 7. Juni 2011 hostname XXX ! boot-start-marker boot-end-marker ! logging buffered 8192 enable secret level 2 5 XXX ! aaa new-model ! ! ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.0 192.168.1.100 ! ip dhcp pool SVS-AD import all network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 lease 0 2 ! ! no ip bootp server ip host ASA-ST1 80.150.23.189 ip host ASA-ST2 62.206.215.121 ip host CONC-ST1 62.206.215.4 ip host CONC-ST2 193.159.174.132 ! multilink bundle-name authenticated isdn switch-type basic-net3 ! ! username XXX privilege 15 password 7 XXX username XXX privilege 15 password 7 XXX username XXX privilege 15 password 7 XXX ! ! archive log config hidekeys ! ! ! track 1 rtr 1 reachability ! track 2 rtr 2 reachability ! track 3 rtr 3 reachability ! track 4 rtr 4 reachability ! track 5 list boolean and object 1 not object 2 not object 3 not object 4 not ! track 6 list boolean or object 1 object 2 object 3 object 4 ! [...] ! bridge irb ! ! interface BRI0 description ISDN Port no ip address encapsulation ppp dialer pool-member 2 dialer pool-member 3 isdn switch-type basic-net3 isdn point-to-point-setup ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! [...] ! interface Dialer3 description Remote Management SVS-IT1 bandwidth 64 ip address 192.168.2.1 255.255.255.0 ip access-group 103 in ip access-group 103 out encapsulation ppp load-interval 30 dialer pool 3 dialer remote-name IT1_Mgmt dialer idle-timeout 360 dialer caller 351XXXXXXXX dialer hold-queue 16 dialer load-threshold 64 either dialer max-call 1 dialer-group 3 no fair-queue no cdp enable ppp authentication chap ! [...] ! interface BVI1 description virtuelles BridgeGroup Interface fuer die LAN und WLAN ip address 192.168.1.1 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp ip flow ingress ip flow egress ip nat inside ip virtual-reassembly ! ip local policy route-map rm ip forward-protocol nd ip route 80.150.23.189 255.255.255.255 Dialer1 name ASA-ST1 track 1 ip route 62.206.215.121 255.255.255.255 Dialer1 name ASA-ST2 track 2 ip route 0.0.0.0 0.0.0.0 Dialer2 track 5 ip route 0.0.0.0 0.0.0.0 Dialer1 track 6 ! ip flow-top-talkers top 50 sort-by bytes cache-timeout 1200 ! ip http server ip http authentication local ip http secure-server ip nat translation icmp-timeout 1 ip nat inside source route-map nat_via_dsl interface Dialer1 overload ip nat inside source route-map nat_via_isdn interface Dialer2 overload ! [....] ! logging trap warnings access-list 10 permit 192.168.147.0 0.0.0.255 access-list 10 permit 10.128.17.0 0.0.0.255 access-list 10 permit 62.206.215.0 0.0.0.127 access-list 10 permit 193.159.174.128 0.0.0.127 access-list 10 permit 62.245.183.0 0.0.0.127 access-list 10 permit 62.156.144.0 0.0.0.127 access-list 10 permit 192.168.1.0 0.0.0.255 access-list 10 permit 192.168.2.0 0.0.0.255 access-list 10 permit 172.25.0.0 0.0.255.255 [...] access-list 103 permit ip 10.248.0.0 0.7.255.255 host 192.168.2.1 access-list 103 permit ip 10.0.0.0 0.7.255.255 host 192.168.2.1 access-list 103 permit ip 10.240.0.0 0.7.255.255 host 192.168.2.1 access-list 103 permit ip 192.168.2.0 0.0.0.255 host 192.168.2.1 access-list 103 deny ip any any dialer watch-list 1 ip 62.206.215.4 255.255.255.255 dialer watch-list 1 ip 193.159.174.132 255.255.255.255 dialer watch-list 1 delay route-check initial 300 dialer-list 1 protocol ip permit dialer-list 2 protocol ip list 102 snmp-server community XXXXXX RO snmp-server enable traps tty no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip Zitieren
Ghostolani 10 Geschrieben 7. Juni 2011 Autor Melden Geschrieben 7. Juni 2011 die fast komplette muss erst freigeschaltet werden ... [...] interface BRI0 description ISDN Port no ip address encapsulation ppp dialer pool-member 2 dialer pool-member 3 isdn switch-type basic-net3 isdn point-to-point-setup [...] interface Dialer3 description Remote Management bandwidth 64 ip address 192.168.2.1 255.255.255.0 ip access-group 103 in ip access-group 103 out encapsulation ppp load-interval 30 dialer pool 3 dialer remote-name IT1_Mgmt dialer idle-timeout 360 dialer caller 62XXX dialer caller 35 dialer caller 35 dialer hold-queue 16 dialer load-threshold 64 either dialer max-call 1 dialer-group 3 no fair-queue no cdp enable ppp authentication chap Zitieren
Wordo 11 Geschrieben 8. Juni 2011 Melden Geschrieben 8. Juni 2011 Mach mal pap und trag auf beiden Routern den Username ein. Fuer debug bei ISDN generell: deb isdn sta deb ppp neg deb ppp auth ter mon Zitieren
Lian 2.557 Geschrieben 8. Juni 2011 Melden Geschrieben 8. Juni 2011 Hallo, am besten solche Configs/Logfiles als TXT File hier anhängen. Zitieren
Ghostolani 10 Geschrieben 8. Juni 2011 Autor Melden Geschrieben 8. Juni 2011 Es gibt keinen 2. Router. Ich möchte mich von einem Laptop über eine ISDN Karte einwählen ... aber ich teste das mal mit dem pap. Zitieren
Ghostolani 10 Geschrieben 9. Juni 2011 Autor Melden Geschrieben 9. Juni 2011 debugg mit den Einstellungen siehe oben. Das ergänzen von PAP hat keinen Erfolg gebracht. error.txt Zitieren
Ghostolani 10 Geschrieben 20. Juni 2011 Autor Melden Geschrieben 20. Juni 2011 Unterstützt die IOS c870-adventerprisek9-mz.124-15.t9.bin die ISDN Einwahl überhaupt? Eigentlich schon, oder? Zitieren
Otaku19 33 Geschrieben 20. Juni 2011 Melden Geschrieben 20. Juni 2011 cisco.com/go/fn, aber advanced enterprise kann so gut wie alles Zitieren
Wordo 11 Geschrieben 21. Juni 2011 Melden Geschrieben 21. Juni 2011 Jo, Enterprise kann auch ISDN Dial Backup nach draussen ... das geht mit den kleineren nicht. Zitieren
Ghostolani 10 Geschrieben 22. Juni 2011 Autor Melden Geschrieben 22. Juni 2011 Calling Party Number i = 0x2181, '3514XX5486' Plan:ISDN, Type:National Called Party Number i = 0xC1, '8XX0345' Plan:ISDN, Type:Subscriber(local) Ist das so ok oder deutet das auf ein Problem hin? Zitieren
Wordo 11 Geschrieben 22. Juni 2011 Melden Geschrieben 22. Juni 2011 Ist an beiden NTBA's jeweils nur ein Geraet angeschlossen? Hab mir jetzt den alten Debug noch mal angeschaut, da kommt nur Conreq O und kein I. Kommt mir so vor also wuerd da ein Geraet dazwischen was wegnehmen. Zitieren
