ara 10 Geschrieben 13. Oktober 2011 Melden Teilen Geschrieben 13. Oktober 2011 Hallo zusammen, wir haben das Problem dass zeitweilig (etwa 3-4 mal am Tag) plötzlich keine Frei-/Gebucht Informationen in Outlook mehr angezeigt werden. Abwesenheitsnachrichten kann man zur gleichen Zeit auch keine setzen. Nach ca. 15 min geht es dann plötzlich wieder. Habe das Logging in Outlook aktiviert, es liefert dann: 2011/10/13 16:00:50.847: Getting ASURL 2011/10/13 16:00:50.848: URL returned from cached autodiscover: https://cas.x.de/ews/exchange.asmx 2011/10/13 16:00:50.848: Request to URL: https://cas.x.de/ews/exchange.asmx 2011/10/13 16:00:50.848: Request action: http://schemas.microsoft.com/exchange/services/2006/messages/GetUserAvailability 2011/10/13 16:00:50.848: Request XML: <?xml version="1.0"?> <q:Envelope xmlns:q="http://schemas.xmlsoap.org/soap/envelope/"><q:Header><wsa:MessageID xmlns:wsa="http://www.w3.org/2005/08/addressing/">urn:uuid:67696DDD-7499-450D-9E46-AC9D39A658C7</wsa:MessageID></q:Header><q:Body xmlns:wsa="http://www.w3.org/2005/08/addressing/"><ex12m:GetUserAvailabilityRequest xmlns:ex12m="http://schemas.microsoft.com/exchange/services/2006/messages" xmlns:ex12t="http://schemas.microsoft.com/exchange/services/2006/types"><ex12t:TimeZone><ex12t:Bias>-60</ex12t:Bias><ex12t:StandardTime><ex12t:Bias>0</ex12t:Bias><ex12t:Time>03:00:00</ex12t:Time><ex12t:DayOrder>5</ex12t:DayOrder><ex12t:Month>10</ex12t:Month><ex12t:DayOfWeek>Sunday</ex12t:DayOfWeek></ex12t:StandardTime><ex12t:DaylightTime><ex12t:Bias>-60</ex12t:Bias><ex12t:Time>02:00:00</ex12t:Time><ex12t:DayOrder>5</ex12t:DayOrder><ex12t:Month>3</ex12t:Month><ex12t:DayOfWeek>Sunday</ex12t:DayOfWeek></ex12t:DaylightTime></ex12t:TimeZone><ex12m:MailboxDataArray><ex12t:MailboxData><ex12t:Email><ex12t:Address>y@x.de</ex12t:Address><ex12t:RoutingType>SMTP</ex12t:RoutingType></ex12t:Email><ex12t:AttendeeType>Required</ex12t:AttendeeType></ex12t:MailboxData></ex12m:MailboxDataArray><ex12t:FreeBusyViewOptions><ex12t:TimeWindow><ex12t:StartTime>2011-10-13T00:00:00</ex12t:StartTime><ex12t:EndTime>2011-11-10T00:00:00</ex12t:EndTime></ex12t:TimeWindow><ex12t:MergedFreeBusyIntervalInMinutes>30</ex12t:MergedFreeBusyIntervalInMinutes><ex12t:RequestedView>Detailed</ex12t:RequestedView></ex12t:FreeBusyViewOptions></ex12m:GetUserAvailabilityRequest></q:Body></q:Envelope> 2011/10/13 16:00:50.848: Sending request 2011/10/13 16:01:51.086: Request sent 2011/10/13 16:01:51.086: Response error code: 00000000 2011/10/13 16:01:51.086: HTTP status code: 0 2011/10/13 16:01:51.086: ------------------------------- 2011/10/13 16:01:51.086: There is an error in request/response. 2011/10/13 16:01:51.086: XML response: 2011/10/13 16:01:51.086: ------------------------------- 2011/10/13 16:01:51.086: Getting ASURL 2011/10/13 16:01:51.175: Failed to get ASURL. Error 8004010F scheint also so als würde einfach garnichts zurückkommen. Per OWA funktioniert alles in dieser Zeit. Hat jemand von euch eine Idee? Exchange 2010 SP1 RU4, Outlook 2010 SP1 Zitieren Link zu diesem Kommentar
RobertWi 81 Geschrieben 13. Oktober 2011 Melden Teilen Geschrieben 13. Oktober 2011 Moin, Gibt es da einen Loadbalancer oder wieviele CAS-Server sind das? Ist die URL "https://cas.x.de" die ganze Zeit auflösbar, kein Round-Robin, kein Proxy, keiner Firewall, etc. dazwischen? Zitieren Link zu diesem Kommentar
ara 10 Geschrieben 13. Oktober 2011 Autor Melden Teilen Geschrieben 13. Oktober 2011 ist eine 2 Server DAG, die CAS Adresse ist eine Windows Failovercluster-Resource und funktioniert die ganze Zeit. Auf beiden Servern auch keinerlei relevante Events zu der fraglichen Zeit. Zitieren Link zu diesem Kommentar
RobertWi 81 Geschrieben 13. Oktober 2011 Melden Teilen Geschrieben 13. Oktober 2011 Moin, die CAS Adresse ist eine Windows Failovercluster-Resource das ist nicht supported und vermutlich erlebst Du gerade, warum es das nicht ist -> weil es eben doch nicht stabil läuft. Wenn Du nur zwei Exchange-Server hast, such Dir hier was aus: MSXFAQ.DE - 2-Server-DAG Aber eigentlich bleibt nur der Einsatz eines vorgelagerten Loadbalancers als vernünftige Lösug (z.B. eine VM von KEMP). Zitieren Link zu diesem Kommentar
