flosrlabs 10 Geschrieben 6. Februar 2012 Melden Geschrieben 6. Februar 2012 Hi, ich bekomme alle 30 Minuten folgende Fehlermeldung: Zitat Log Name: ApplicationSource: Microsoft-SharePoint Products-SharePoint Foundation Date: 2/6/2012 3:00:25 PM Event ID: 5586 Task Category: Database Level: Error Keywords: User: SYSTEM Computer: AD.srlabs.local Description: Unknown SQL Exception 2 occurred. Additional error information from SQL Server is included below. A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Shared Memory Provider, error: 40 - Could not open a connection to SQL Server) Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-SharePoint Products-SharePoint Foundation" Guid="{6FB7E0CD-52E7-47DD-997A-241563931FC2}" /> <EventID>5586</EventID> <Version>14</Version> <Level>2</Level> <Task>3</Task> <Opcode>0</Opcode> <Keywords>0x4000000000000000</Keywords> <TimeCreated SystemTime="2012-02-06T14:00:25.586864500Z" /> <EventRecordID>1443017</EventRecordID> <Correlation /> <Execution ProcessID="12952" ThreadID="11832" /> <Channel>Application</Channel> <Computer>AD.srlabs.local</Computer> <Security UserID="S-1-5-18" /> </System> <EventData> <Data Name="int0">2</Data> <Data Name="string1">A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Shared Memory Provider, error: 40 - Could not open a connection to SQL Server)</Data> </EventData> </Event> OS: Windows Smal Business Server 2011 mit SQL 2005 und 2008. Das Problem scheint ja der SharPoint Service zu verursachen. Kann mir jemand helfen? Vielen Dank Flo
GuentherH 61 Geschrieben 6. Februar 2012 Melden Geschrieben 6. Februar 2012 Einmal reicht. Hier geht es weiter - http://www.mcseboard.de/ms-sql-server-forum-81/eventid-5586-sharepoint-foundation-183988.html
