EventID 5586 SharePoint Foundation
Hi,
ich bekomme dauernd (4 mal pro Stunde!) folgende Fehlermeldung:
Log Name: Application
Source: Microsoft-SharePoint Products-SharePoint Foundation
Date: 2/6/2012 3:00:25 PM
Event ID: 5586
Task Category: Database
Level: Error
Keywords:
User: SYSTEM
Computer: AD.local
Description:
Unknown SQL Exception 2 occurred. Additional error information from SQL Server is included below.
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Shared Memory Provider, error: 40 - Could not open a connection to SQL Server)
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-SharePoint Products-SharePoint Foundation" Guid="{6FB7E0CD-52E7-47DD-997A-241563931FC2}" />
<EventID>5586</EventID>
<Version>14</Version>
<Level>2</Level>
<Task>3</Task>
<Opcode>0</Opcode>
<Keywords>0x4000000000000000</Keywords>
<TimeCreated SystemTime="2012-02-06T14:00:25.586864500Z" />
<EventRecordID>1443017</EventRecordID>
<Correlation />
<Execution ProcessID="12952" ThreadID="11832" />
<Channel>Application</Channel>
<Computer>AD.local</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="int0">2</Data>
<Data Name="string1">A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Shared Memory Provider, error: 40 - Could not open a connection to SQL Server)</Data>
</EventData>
</Event>
Version: 14.0.6106.5000
Lokale ID: 1033
OS: Windows Smal Business Server 2011
Kann jemand helfen?
Danke
Flo
Was sagt den wenn du - (get-spserver $env:computername).NeedsUpgrade - in die SharePoint 2010 Management Shell eingibst?
PS C:\Users\f_a> (get-spserver $env:computername).NeedsUpgrade
Get-SPServer : The farm is unavailable.
At line:1 char:14
+ (get-spserver <<<<  $env:computername).NeedsUpgrade
   + CategoryInfo          : InvalidData: (Microsoft.Share...CmdletGetServer:
  SPCmdletGetServer) [Get-SPServer], SPException
   + FullyQualifiedErrorId : Microsoft.SharePoint.PowerShell.SPCmdletGetServe
  r
PS C:\Users\f_a> get-spserver $env:localhost.NeedsUpgrade
PS C:\Users\f_a> (get-spserver $env:localhost).NeedsUpgrade
At line:1 char:14
  r
mit "computername" bekomme ich eine Fehlermeldung und mit "localhost" kommt gar keine Meldung....
kann ich leider nicht mehr sagen. Folgende Meldung erscheint auch 1x täglich:
Source: BlackBerry MDS Connection Service
Date: 2/5/2012 12:38:27 AM
Event ID: 15000
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: AD.local
Description:
<2012-02-05 00:38:27.937 CET>:[15]:<MDS-CS_AD_MDS-CS_1>:<ERROR>:<LAYER = SCM, BMS: setConfigConfig failed rc=-1000>
Event Xml:
<System>
<Provider Name="BlackBerry MDS Connection Service" />
<EventID Qualifiers="0">15000</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-02-04T23:38:27.000000000Z" />
<EventRecordID>1438950</EventRecordID>
<Security />
</System>
<EventData>
<Data><2012-02-05 00:38:27.937 CET>:[15]:<MDS-CS_AD_MDS-CS_1>:<ERROR>:<LAYER = SCM, BMS: setConfigConfig failed rc=-1000>
</Data>
</EventData>
</Event>
