tobee 10 Geschrieben 7. März 2012 Melden Geschrieben 7. März 2012 Hallo Sowohl in meiner Mini-Testumgebung (win7 ohne Domäne), als auch produktiv (Server 2008 R2 in einer Domäne) habe ich das Problem, dass der SQL Server 2008 R2 (Standard-Edition mit SP1) nicht auf 1433 lauscht, wie in TCP/IP port numbers required to communicate to SQL over a firewall beschrieben Z.B. C:\Windows\system32>netstat -abn | findstr 143 UDP 0.0.0.0:1434 *:* UDP [::]:1434 *:* oder (xp_errorlog): 2012-03-07 13:56:21.770 Server Microsoft SQL Server 2008 R2 (SP1) - 10.50.2500.0 (X64) Jun 17 2011 00:54:03 Copyright (c) Microsoft Corporation (64-bit) on Windows NT 6.1 <X64> (Build 7601: Service Pack 1) 2012-03-07 13:56:21.780 Server Authentication mode is WINDOWS-ONLY. 2012-03-07 13:56:21.780 Server Logging SQL Server messages in file 'C:\Program Files\Microsoft SQL Server\MSSQL10_50.SQL2008R2INSTANZ\MSSQL\Log\ERRORLOG'. 2012-03-07 13:56:21.790 Server Registry startup parameters: -d C:\Program Files\Microsoft SQL Server\MSSQL10_50.SQL2008R2INSTANZ\MSSQL\DATA\master.mdf -e C:\Program Files\Microsoft SQL Server\MSSQL10_50.SQL2008R2INSTANZ\MSSQL\Log\ERRORLOG -l C:\Program Files\Microsoft SQL Server\MSSQL10_50.SQL2008R2INSTANZ\MSSQL\DATA\mastlog.ldf 2012-03-07 13:56:22.110 spid7s FILESTREAM: effective level = 0, configured level = 0, file system access share name = 'SQL2008R2INSTANZ'. 2012-03-07 13:56:22.130 spid7s SQL Trace ID 1 was started by login "sa". 2012-03-07 13:56:22.140 spid7s Starting up database 'mssqlsystemresource'. 2012-03-07 13:56:22.300 spid10s Starting up database 'model'. 2012-03-07 13:56:22.330 spid10s The tail of the log for database model is being rewritten to match the new sector size of 4096 bytes. 3584 bytes at offset 16896 in file C:\Program Files\Microsoft SQL Server\MSSQL10_50.SQL2008R2INSTANZ\MSSQL\DATA\modellog.ldf will be written. 2012-03-07 13:56:22.350 spid10s Clearing tempdb database. 2012-03-07 13:56:22.620 spid10s Starting up database 'tempdb'. 2012-03-07 13:56:22.650 spid14s The Service Broker protocol transport is disabled or not configured. 2012-03-07 13:56:22.660 Server A self-generated certificate was successfully loaded for encryption. 2012-03-07 13:56:22.670 Server Server is listening on [ 'any' <ipv6> 49344]. 2012-03-07 13:56:22.670 Server Server is listening on [ 'any' <ipv4> 49344]. 2012-03-07 13:56:22.670 Server Server local connection provider is ready to accept connection on [ \\.\pipe\SQLLocal\SQL2008R2INSTANZ ]. 2012-03-07 13:56:22.670 Server Server local connection provider is ready to accept connection on [ \\.\pipe\MSSQL$SQL2008R2INSTANZ\sql\query ]. 2012-03-07 13:56:22.670 Server Server is listening on [ ::1 <ipv6> 49345]. 2012-03-07 13:56:22.680 Server Server is listening on [ 127.0.0.1 <ipv4> 49345]. 2012-03-07 13:56:22.680 spid14s Service Broker manager has started. 2012-03-07 13:56:22.680 Server Dedicated admin connection support was established for listening locally on port 49345. 2012-03-07 13:56:22.680 Server SQL Server is now ready for client connections. This is an informational message; no user action is required. 2012-03-07 13:56:52.570 spid17s Starting up database 'msdb'. 2012-03-07 13:56:52.570 spid18s Starting up database 'ReportServer$SQL2008R2INSTANZ'. 2012-03-07 13:56:52.590 spid20s Starting up database 'ReportServer$SQL2008R2INSTANZTempDB'. 2012-03-07 13:56:53.300 spid7s Recovery is complete. This is an informational message only. No user action is required. 2012-03-07 13:57:00.030 spid13s A new instance of the full-text filter daemon host process has been successfully started. Wie behebt man das? Auf dem Produktiven Server läuft sonst nix, nur Domain Member, kein DC, DNS, DHCP, Mail oder sonstiges. Auf meinem Testrechner (Win7ulti, 64bit) auch nur diese Serversoftware, ansonsten nur Browser und Textverarbeitung. Asncheinend sind die Ports bei Win7 und Server 2008R2 unterschiedlich? Ciao Zitieren
wilgin 11 Geschrieben 8. März 2012 Melden Geschrieben 8. März 2012 Hallo, ich bin mal vor einiger Zeit über so etwas "gefallen". Bei mir war der Port nicht auf den Schnittstellen aktiviert. Navigiere zu SQL Server Configuration Manager > SQL Server Network Configuration > Protocols for MSSQLSERVER > TCP/IP > Registerkarte: IP Addresses Hier muss bei der betroffenen Schnittstelle (falls mehrere) UND (!!!) im Bereich IPAll (ganz unten) unter TCP Port 1433 eingetragen sein. Erst nachdem ich unter IPALL den Port eingetragen hab, funktionierte es. Zitieren
Sunny61 823 Geschrieben 14. März 2012 Melden Geschrieben 14. März 2012 Evtl. hilft dieser Lösungsvorschlag: http://blog.alexonasp.net/post/2011/03/06/Auf-welchem-Port-lauft-mein-SQL-Server-%28Express%29-2008-R2-Oder-warum-bekomme-ich-keine-Verbindung.aspx Zitieren
