Alith Anar 40 Geschrieben 5. April 2012 Melden Geschrieben 5. April 2012 Hallo, hab hier ein Problem mit der Installtion eines SQL Server 2008 Express Advanced ... . Die ganzen Vorchecks laufen alle sauber durch. Während des Schrittes "Installation" steigt der Wizard dann aber aus. Im Logfile finde ich folgendes: <snip> 04/05/2012 09:58:10.321 c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 09:58:54.119 Process returned exit code: 0x00000000 04/05/2012 09:58:54.119 Workflow RUNRULES /RULES=GlobalRules returned exit code: 0x00000000 04/05/2012 09:58:54.119 Attempting to launch component update workflow 04/05/2012 09:58:54.119 Media source: c:\b169d72adf0cdb4244fa\ 04/05/2012 09:58:54.119 Install media path: c:\b169d72adf0cdb4244fa\x86\setup\ 04/05/2012 09:58:54.119 Media layout: Advanced 04/05/2012 09:58:54.119 Attempting to get execution timestamp 04/05/2012 09:58:54.119 Timestamp: 20120405_095810 04/05/2012 09:58:54.119 Attempting to run workflow COMPONENTUPDATE 04/05/2012 09:58:54.135 Attempting to launch process c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 10:02:15.864 Process returned exit code: 0x00000000 04/05/2012 10:02:15.864 Workflow COMPONENTUPDATE returned exit code: 0x00000000 04/05/2012 10:02:15.864 Attempting to launch user requested workflow locally 04/05/2012 10:02:15.864 Attempting to find local setup.exe 04/05/2012 10:02:15.864 Local bootstrap folder path: c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\ 04/05/2012 10:02:15.864 Local setup100.exe full path: c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 10:02:15.864 Media source: c:\b169d72adf0cdb4244fa\ 04/05/2012 10:02:15.864 Install media path: c:\b169d72adf0cdb4244fa\x86\setup\ 04/05/2012 10:02:15.864 Media layout: Advanced 04/05/2012 10:02:15.880 Attempting to get execution timestamp 04/05/2012 10:02:15.880 Timestamp: 20120405_095810 04/05/2012 10:02:15.880 Attempting to run user requested action from local setup100.exe 04/05/2012 10:02:15.880 Attempting to launch process c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 10:11:25.057 Process returned exit code: 0x84B30001 04/05/2012 10:11:25.057 Local setup100.exe returned exit code: 0x84B30001 04/05/2012 10:11:25.057 Attempting to release setup mutex 04/05/2012 10:11:25.073 Setup mutex has been released 04/05/2012 10:11:25.073 Setup closed with exit code: 0x84C40013 04/05/2012 10:11:25.073 ====================================================================== Ich habe bisher gefunden, das es an irgendwelchen BErchtigungen in der Registry geht. Aber nirgendwo welche Registryeinträge den Fehler verursachen können. Hat evtl jemand eine Idee wo ich mal nachschauen könnte. Also Host dient ein Server 2003 R2 SP2 und die Installation findet unter dem Account einen Domänenadministrator statt, die auch lokale Administratoren sind. Danke Thomas PS: Hoffe hab jetzt nicht zu viel gekürzt, aber ich sprenge das 4000 Zeichen Limit mit dem kompletten Logfile. Zitieren
zahni 574 Geschrieben 5. April 2012 Melden Geschrieben 5. April 2012 Installiere mal die neuste Version von .NET 3.5 (SP1 ?) inkl. aller .NET-Updates von Windows Update. Zitieren
Alith Anar 40 Geschrieben 5. April 2012 Autor Melden Geschrieben 5. April 2012 Hallo, das SQL Connectivity SDK ist installiert, aber der rest vom SQL Server nicht :( Fehler ist der gleiche 04/05/2012 12:22:56.346 Media layout: Advanced 04/05/2012 12:22:56.346 Attempting to get execution timestamp 04/05/2012 12:22:56.346 Timestamp: 20120405_122237 04/05/2012 12:22:56.346 Attempting to run workflow COMPONENTUPDATE 04/05/2012 12:22:56.363 Attempting to launch process c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 12:23:13.047 Process returned exit code: 0x00000000 04/05/2012 12:23:13.083 Workflow COMPONENTUPDATE returned exit code: 0x00000000 04/05/2012 12:23:13.083 Attempting to launch user requested workflow locally 04/05/2012 12:23:13.083 Attempting to find local setup.exe 04/05/2012 12:23:13.083 Local bootstrap folder path: c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\ 04/05/2012 12:23:13.083 Local setup100.exe full path: c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 12:23:13.100 Media source: c:\a199b8ab523592d13b9f\ 04/05/2012 12:23:13.100 Install media path: c:\a199b8ab523592d13b9f\x86\setup\ 04/05/2012 12:23:13.100 Media layout: Advanced 04/05/2012 12:23:13.100 Attempting to get execution timestamp 04/05/2012 12:23:13.100 Timestamp: 20120405_122237 04/05/2012 12:23:13.100 Attempting to run user requested action from local setup100.exe 04/05/2012 12:23:13.100 Attempting to launch process c:\Programme\Microsoft SQL Server\100\Setup Bootstrap\Release\x86\setup100.exe 04/05/2012 12:28:08.318 Process returned exit code: 0x84B30001 04/05/2012 12:28:08.318 Local setup100.exe returned exit code: 0x84B30001 04/05/2012 12:28:08.318 Attempting to release setup mutex 04/05/2012 12:28:08.318 Setup mutex has been released 04/05/2012 12:28:08.318 Setup closed with exit code: 0x84C40013 04/05/2012 12:28:08.334 Das Eventlog zeigt keine relevanten Fehler. (Drucker von TS Sitzung kann nicht eingebunden werden). Zitieren
zahni 574 Geschrieben 5. April 2012 Melden Geschrieben 5. April 2012 Hast Du meine 1. Antwort gelesen ? Zitieren
Alith Anar 40 Geschrieben 5. April 2012 Autor Melden Geschrieben 5. April 2012 Jupp. Habs auch umgesetzt. Vergessen dazuzuschreiben :( .Net 3.5 SP1 + Sprachpaket + Update für Sp1 + Updates für .Net 2 und 3,5 Zitieren
Alith Anar 40 Geschrieben 5. April 2012 Autor Melden Geschrieben 5. April 2012 (bearbeitet) Problem gelöst. In einem der Logfiles (aber nicht im SQL Install Logfile)stand dieser abschnitt drin: MSI (s) (E0:80) [12:53:07:480]: Note: 1: 1708 MSI (s) (E0:80) [12:53:07:480]: Produkt: MSXML 6.0 Parser (KB933579) -- Die Installation ist fehlgeschlagen. MSI (s) (E0:80) [12:53:07:480]: Das Produkt wurde durch Windows Installer installiert. Produktname: MSXML 6.0 Parser (KB933579). Produktversion: 6.10.1200.0. Produktsprache: 1031. Erfolg- bzw. Fehlerstatus der Installation: 1603. Also den vorhandenen MSXML 6.0 Parser deinstalliert danach lief die Installation sauber durch. bearbeitet 5. April 2012 von Alith Anar Zitieren
mygil 10 Geschrieben 11. April 2012 Melden Geschrieben 11. April 2012 Vielen Dank Alith Anar! Auch bei mir funktionierte die Lösung: Einfach START\EINSTELLUNGEN\SOFTWARE und das Teil: "MSXML 6 Service Pack2 (KB973686)" deinstallieren und die Installation verlief ohne Probleme! Zitieren
