Kann WSUS auf neuem Rechner nicht installieren
Hab einen ganz neuen Server 2008. Alle Updates gemacht. DC, DHCP, DNS laufen auf dem DC.
Nun wenn ich den WSUS hinzufügen will bekomme ich folgende Fehlermeldung:
2012-06-14 15:02:32  Success   MWUSSetup          Detected that setup was launched through Server Manager
2012-06-14 15:02:33  Success   MWUSSetup          Validating pre-requisites...
2012-06-14 15:02:33  Error     MWUSSetup          Failed to determine if an higher version of WSUS is installed. Assuming it is not... (Error 0x80070002: The system cannot find the file specified.)
2012-06-14 15:02:33  Error     MWUSSetup          WSUS is outdated. But this will not block setup (Error 0x00000000: The operation completed successfully.)
2012-06-14 15:02:35  Success   MWUSSetup          ReportViewer is not installed on this machine
2012-06-14 15:02:38  Success   MWUSSetup          No SQL instances found
2012-06-14 15:02:42  Success   MWUSSetup          Initializing installation details
2012-06-14 15:02:42  Success   MWUSSetup          Skipping Asp.Net install since not running on win2k3...
2012-06-14 15:02:42  Success   MWUSSetup          Installing wYukon using ocsetup
2012-06-14 15:02:42  Success   MWUSSetup          Installing Windows Internal database using ocsetup with command line as "ocsetup "WSSEE" /quiet /norestart"
2012-06-14 15:03:16  Error     MWUSSetup          The process ocsetup "WSSEE" /quiet /norestart returned error: 0x643 (Error 0x80070643: Fatal error during installation.)
2012-06-14 15:03:16  Error     MWUSSetup          ExecCmd failed (Error 0x80070643: Fatal error during installation.)
2012-06-14 15:03:16  Error     MWUSSetup          Install Windows Internal database: Failed to execute "ocsetup "WSSEE" /quiet /norestart" (Error 0x80070643: Fatal error during installation.)
2012-06-14 15:03:16  Error     MWUSSetup          CInstallDriver::PerformSetup: Installation of wYukon failed (Error 0x80070643: Fatal error during installation.)
2012-06-14 15:03:16  Error     MWUSSetup          CSetupDriver::LaunchSetup: Setup failed (Error 0x80070643: Fatal error during installation.)
habe schon diverse KBs gelesen, die mich nciht wirklich weitergebracht haben. Einige sagten dass das "uncompressing" des systems die lösung war, was nbei mri nicht der fall war.
Die installation bricht jedes mal ab. Das nun schon bei 2 neu instalierten Servern...
Es könnte helfen den Besitz von folgendem Registry Schlüssel zu übernehmen:
HKLM\software\Microsoft\windows\currentversion\installer\userdata\S-1-5-18\components
Anschliessend dem Administrator und System Vollzugriff gewähren.
Grüsse
Gulp
Hey. Danke für die Tipps, hat aber alles nichts gebracht...
iDiddi....
UAC hab ich abgeschaltet,
Bin Domainadmin
Wie starte ich die Setupdatei aus der Admin-Shell?
Gulp, Hab vollzugriff auf diesn ordner und alle unterordner, hat aber nichts gebracht.
Das problem ist irgendwo mit der Windows internal DB. Im eventvwr sehe ich folgendes:
Product: Windows Internal Database -- Error 29511. Failure creating local group SQLServer2005MSSQLUser$FILESERVERDE$MICROSOFT##SSEE.
Dann deinstalliere doch einfach die WID. Prüfe aber vorher, ob sie von irgendeiner Anwendung (z.B. Sharepoint) genutzt wird.
Hier hatte ich mal ein ähnliches Problem:
https://www.mcseboard.de/windows-server-forum-78/2k3-wsus-laesst-deinstallieren-182139.html
Dort findest Du auch folgenden TechNet-Link:
How to manually remove all of WSUS - The WSUS Support Team Blog - Site Home - TechNet Blogs
Nachdem Du die WID komplett entfernt hast, kannst Du noch einen Installationversuch starten.
Kannst auch versuchen die SQLGroup aus der Registry zu entfernen (siehe nachfolgenden KB Artikel) und dann wieder eine Installation versuchen:
Error message when you uninstall SQL Server 2005 or install SQL Server 2005 Service Pack 1: "The setup has encountered an unexpected error while Setting Internal Properties. The error is: Fatal error during installation"
Grüsse
Gulp
