shoty 10 Geschrieben 13. August 2012 Melden Geschrieben 13. August 2012 Hallo Leute, Hardware: cisco WS-C6506-E (R7000) Cisco Internetwork Operating System Software IOS s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1) am Samstag hatte ich ein komisches Phenomen, unser Cisco Router hat ohne Vorwarnung, nach vier Jahren dauerbetrieb, sich einfach neu gestartet, mit folgenden Meldungen im LOG: Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns) Console logging: level debugging, 44 messages logged Monitor logging: level debugging, 0 messages logged Buffer logging: level debugging, 44 messages logged Exception Logging: size (4096 bytes) Count and timestamp logging messages: disabled Trap logging: level informational, 60 message lines logged Logging to 10.90.xx.xx, 60 message lines logged Log Buffer (10000 bytes): 00:00:58: curr is 0x0 00:00:58: RP: Currently running ROMMON from S (Gold) region *Aug 11 17:53:31 MEZ: %SYS-6-CLOCKUPDATE: System clock has been updated from 16:53:31 UTC Sat Aug 11 2012 to 17:53:31 MEZ Sat Aug 11 2012, configured from console by console. *Aug 11 18:53:31 MESZ: %SYS-6-CLOCKUPDATE: System clock has been updated from 17:53:31 MEZ Sat Aug 11 2012 to 18:53:31 MESZ Sat Aug 11 2012, configured from console by console. Aug 11 18:53:34 MESZ: %SYS-5-CONFIG_I: Configured from memory by console Aug 11 18:53:36 MESZ: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1) Technical Support: Support and Documentation - Cisco Systems Copyright © 1986-2007 by cisco Systems, Inc. Compiled Fri 13-Jul-07 07:29 by kellythw Aug 11 18:53:36 MESZ: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress Aug 11 18:53:36 MESZ: %SYS-6-BOOTTIME: Time taken to reboot after reload = 154676838 seconds 00:00:05: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output. Firmware compiled 29-Jun-07 15:19 by integ Build [100] 00:00:06: %OIR-SP-6-CONSOLE: Changing console ownership to route processor 00:00:07: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output. 00:01:07: SP: SP: Currently running ROMMON from S (Gold) region 00:01:15: %SYS-SP-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1) Technical Support: Support and Documentation - Cisco Systems Copyright © 1986-2007 by cisco Systems, Inc. Compiled Fri 13-Jul-07 07:42 by kellythw *Aug 11 16:53:37 UTC: %OIR-SP-6-INSPS: Power supply inserted in slot 1 *Aug 11 16:53:37 UTC: %C6KPWR-SP-4-PSOK: power supply 1 turned on. *Aug 11 16:53:40 UTC: %C6KENV-SP-4-FANHPMODE: Fan-tray 1 is operating in high power mode *Aug 11 16:53:43 UTC: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5. *Aug 11 16:53:43 UTC: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active. *Aug 11 18:53:45 MESZ: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimal Diagnostics... Aug 11 18:54:08 MESZ: %DIAG-SP-6-DIAG_OK: Module 5: Passed Online Diagnostics Aug 11 18:54:09 MESZ: %OIR-SP-6-INSCARD: Card inserted in slot 5, interfaces are now online Aug 11 18:54:09 MESZ: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics... Zitieren
shoty 10 Geschrieben 13. August 2012 Autor Melden Geschrieben 13. August 2012 hier gehts weiter... Aug 11 18:54:18 MESZ: %CAPI_EC-4-RATE_LIMITED: Adding interfaces on WS-X6148-GE-TX to an etherchannel will limit channel throughput to 1 Gbps! Aug 11 18:54:18 MESZ: %CAPI_EC-4-RATE_LIMITED: Adding interfaces on WS-X6148-GE-TX to an etherchannel will limit channel throughput to 1 Gbps! Aug 11 18:54:18 MESZ: %CAPI_EC-4-RATE_LIMITED: Adding interfaces on WS-X6148-GE-TX to an etherchannel will limit channel throughput to 1 Gbps! Aug 11 18:54:17 MESZ: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics 00:00:02: BaseBoard Index:152 00:00:02: DaughterBoard Index:208 (Centralized Forwarding Card) 00:00:02: Gemini Rev#: 3 Firmware compiled 29-Jun-07 15:19 by integ Build [100] 00:00:04: %SYS-CFC2-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS c6lc2 Software (c6lc2-SP-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1) Technical Support: Support and Documentation - Cisco Systems Copyright © 1986-2007 by cisco Systems, Inc. Compiled Fri 13-Jul-07 07:29 by kellythw *Nov 30 00:00:02.591: CFC2: Currently running ROMMON from S (Gold) region Aug 11 18:54:29 MESZ: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online Aug 11 18:54:31 MESZ: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics... Aug 11 18:54:46 MESZ: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled. Aug 11 18:54:46 MESZ: %DIAG-SP-6-DIAG_OK: Module 2: Passed Online Diagnostics Aug 11 18:54:49 MESZ: %STANDBY-6-STATECHANGE: Vlan10 Group 10 state Standby -> Active Aug 11 18:54:49 MESZ: %STANDBY-6-STATECHANGE: Vlan10 Group 11 state Standby -> Active Aug 11 18:54:49 MESZ: %STANDBY-6-STATECHANGE: Vlan30 Group 30 state Standby -> Active 00:00:03: BaseBoard Index:227 00:00:03: DaughterBoard Index:218 (Distributed Forwarding Card 3) Firmware compiled 29-Jun-07 15:19 by integ Build [100] 00:00:28: %SYS-DFC1-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS c6lc2 Software (c6lc2-SP-M), Version 12.2(18)SXF10, RELEASE SOFTWARE (fc1) Technical Support: Support and Documentation - Cisco Systems Copyright © 1986-2007 by cisco Systems, Inc. Compiled Fri 13-Jul-07 07:29 by kellythw 00:00:28: DFC1: Currently running ROMMON from S (Gold) region Aug 11 18:54:56 MESZ: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimal Diagnostics... Aug 11 18:54:57 MESZ: %OIR-SP-6-INSCARD: Card inserted in slot 2, interfaces are now online Aug 11 18:55:16 MESZ: %STANDBY-6-STATECHANGE: Vlan20 Group 20 state Standby -> Active Aug 11 18:55:16 MESZ: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics Aug 11 18:55:16 MESZ: %OIR-SP-6-DOWNGRADE_EARL: Module 1 DFC installed is not identical to system PFC and will perform at current system operating mode. Aug 11 18:55:18 MESZ: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online Aug 11 18:56:07 MESZ: %STANDBY-6-STATECHANGE: Vlan10 Group 11 state Active -> Speak Aug 11 18:56:07 MESZ: %STANDBY-6-STATECHANGE: Vlan10 Group 10 state Active -> Speak Hat jemand eine Idee, warum das passiert ist und was ich dagegen machen kann, dass das nicht mehr passiert?? Zitieren
shoty 10 Geschrieben 14. August 2012 Autor Melden Geschrieben 14. August 2012 Hat denn keiner eine Idee?? Zitieren
