-Haselier- 10 Geschrieben 16. August 2012 Autor Melden Geschrieben 16. August 2012 da war ein bereits existierendes AD Konto werde jetzt aber mal über den EMC Wizzard ein komplette neuen AD Account mit MB generieren ... melde mich gleich ... ps: soll der "alte Inhalt" der *.xml erhalten bleiben, oder kommt nur der IMAP text rein?
-Haselier- 10 Geschrieben 16. August 2012 Autor Melden Geschrieben 16. August 2012 so Ergebniss: Summary: 1 item(s). 1 succeeded, 0 failed. Elapsed time: 00:00:16 mbtest3 Completed Warning: The cmdlet extension agent with the index 5 has thrown an exception in OnComplete(). The exception is: Microsoft.Exchange.Provisioning.ProvisioningException: ScriptingAgent: Exception thrown while invoking scriptlet for OnComplete API: Exception calling "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.". ---> System.Management.Automation.MethodInvocationException: Exception calling "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and available Connection. The connection's current state is closed." ---> System.InvalidOperationException: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed. at System.Data.SqlClient.SqlConnection.GetOpenConnection(String method) at System.Data.SqlClient.SqlConnection.ValidateConnectionForExecute(String method, SqlCommand command) at System.Data.SqlClient.SqlCommand.ValidateCommand(String method, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at ExecuteNonQuery(Object , Object[] ) at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) --- End of inner exception stack trace --- at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) at System.Management.Automation.ParserOps.CallMethod(Token token, Object target, String methodName, Object[] paramArray, Boolean callStatic, Object valueToSet) at System.Management.Automation.MethodCallNode.InvokeMethod(Object target, Object[] arguments, Object value) at System.Management.Automation.MethodCallNode.Execute(Array input, Pipe outputPipe, ExecutionContext context) at System.Management.Automation.ParseTreeNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context) at System.Management.Automation.StatementListNode.ExecuteStatement(ParseTreeNode statement, Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context) --- End of inner exception stack trace --- at Microsoft.Exchange.ProvisioningAgent.ScriptingAgentHandler.OnComplete(Boolean succeeded, Exception e) at Microsoft.Exchange.Provisioning.ProvisioningLayer.OnComplete(Task task, Boolean succeeded, Exception exception) Exchange Management Shell command completed: New-Mailbox -Name 'mbtest3' -Alias 'mbtest3' -UserPrincipalName 'mbtest3@ea.intern' -SamAccountName 'mbtest3' -FirstName 'mbtest3' -Initials '' -LastName '' -Password 'System.Security.SecureString' -ResetPasswordOnNextLogon $false Elapsed Time: 00:00:16 => IMAP enabled...
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 weitere Ideen, tipps & tricks
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 an dieser Stelle erneut meine Frage: soll der "alte Inhalt" der ScriptingAgentConfig.xml erhalten bleiben, oder kommt nur der IMAP text rein? " <?xml version="1.0" encoding="utf-8" ?> < Configuration version="1.0"> <Feature Name="MailboxProvisioning" Cmdlets="new-mailbox"> <ApiCall Name="OnComplete"> if($succeeded) { $newmailbox = $provisioningHandler.UserSpecifiedParameters["Name"] set-casmailbox $newmailbox -IMAPEnabled $false } </ApiCall> </Feature> < /Configuration> "
tesso 391 Geschrieben 17. August 2012 Melden Geschrieben 17. August 2012 an dieser Stelle erneut meine Frage: soll der "alte Inhalt" der ScriptingAgentConfig.xml erhalten bleiben, oder kommt nur der IMAP text rein? " Diese Frage wird dir im geposteten Link beantwortet. Add your script to the renamed configuration file on every Exchange 2010 server in your organization.
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 lt Link, soll`s ja auch funktionieren! Was es bei mir nicht tut ;)
tesso 391 Geschrieben 17. August 2012 Melden Geschrieben 17. August 2012 An welcher Stelle hast du deine Ergänzung eingefügt?
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 wenn wir einen 2 node DAG implementiert haben und ich habe auf server 1 ein anderes *.xml file als auf server 2, gibts dann probleme, so zumindestens habe ich den link verstanden, oder?
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 next try: xml <?xml version="1.0" encoding="utf-8" ?> < Configuration version="1.0"> <Feature Name="MailboxProvisioning" Cmdlets="new-mailbox,enable-mailbox"> <ApiCall Name="OnComplete"> if($succeeded) { set-casmailbox $provisioningHandler.UserSpecifiedParameters["Alias"] -ImapEnabled $false } </ApiCall> </Feature> </Configuration> komplet neuer User via EMC Wizzard erstellt (war NICHT im AD, wurde neu angelegt) wizzard info: Summary: 1 item(s). 1 succeeded, 0 failed. Elapsed time: 00:00:16 mbtest4 Completed Warning: The cmdlet extension agent with the index 5 has thrown an exception in OnComplete(). The exception is: Microsoft.Exchange.Provisioning.ProvisioningException: ScriptingAgent: Exception thrown while invoking scriptlet for OnComplete API: Exception calling "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.". ---> System.Management.Automation.MethodInvocationException: Exception calling "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and available Connection. The connection's current state is closed." ---> System.InvalidOperationException: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed. at System.Data.SqlClient.SqlConnection.GetOpenConnection(String method) at System.Data.SqlClient.SqlConnection.ValidateConnectionForExecute(String method, SqlCommand command) at System.Data.SqlClient.SqlCommand.ValidateCommand(String method, Boolean async) at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, String methodName, Boolean sendToPipe) at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() at ExecuteNonQuery(Object , Object[] ) at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) --- End of inner exception stack trace --- at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) at System.Management.Automation.ParserOps.CallMethod(Token token, Object target, String methodName, Object[] paramArray, Boolean callStatic, Object valueToSet) at System.Management.Automation.MethodCallNode.InvokeMethod(Object target, Object[] arguments, Object value) at System.Management.Automation.MethodCallNode.Execute(Array input, Pipe outputPipe, ExecutionContext context) at System.Management.Automation.ParseTreeNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context) at System.Management.Automation.StatementListNode.ExecuteStatement(ParseTreeNode statement, Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context) --- End of inner exception stack trace --- at Microsoft.Exchange.ProvisioningAgent.ScriptingAgentHandler.OnComplete(Boolean succeeded, Exception e) at Microsoft.Exchange.Provisioning.ProvisioningLayer.OnComplete(Task task, Boolean succeeded, Exception exception) Exchange Management Shell command completed: New-Mailbox -Name 'mbtest4' -Alias 'mbtest4' -OrganizationalUnit 'edit.intern/AGCXwp/E0001/E0001DE/E0001DENBG01/999999/Users' -UserPrincipalName 'mbtest4edit.intern' -SamAccountName 'mbtest4' -FirstName 'mbtest4' -Initials '' -LastName '' -Password 'System.Security.SecureString' -ResetPasswordOnNextLogon $false fazit -> IMAP enabeld!! hat jmd eine gute Idee?
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 An welcher Stelle hast du deine Ergänzung eingefügt? hallo, mit ein paar leerzeichen, unten, am ende...
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 wenn ich bereits einen existierenden AD Account nehme, kommt diese Meldung nicht komtm die vorher gepostete "Warnung" NICHT...und IMAP ist immernoch aktiv!
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 5. EMS: 6. New-Mailbox -UserPrincipalName mbtest5@test.de -Alias mbtest5b -ResetPasswordOnNextLogon $true Info: 7. cmdlet New-Mailbox at command pipeline position 1 8. Supply values for the following parameters: 9. Name: mbtest5 10. Password: *********** 11. Name Alias ServerName ProhibitSendQuota 12. ---- ----- ---------- ----------------- 13. mbtest5 mbtest5b tb00006a unlimited 14. WARNING: The cmdlet extension agent with the index 5 has thrown an exception in 15. OnComplete(). The exception is: Microsoft.Exchange.Provisioning.ProvisioningException: 16. ScriptingAgent: Exception thrown while invoking scriptlet for OnComplete API: Exception 17. calling "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and 18. available Connection. The connection's current state is closed.". ---> 19. System.Management.Automation.MethodInvocationException: Exception calling 20. "ExecuteNonQuery" with "0" argument(s): "ExecuteNonQuery requires an open and available 21. Connection. The connection's current state is closed." ---> 22. System.InvalidOperationException: ExecuteNonQuery requires an open and available 23. Connection. The connection's current state is closed. 24. at System.Data.SqlClient.SqlConnection.GetOpenConnection(String method) 25. at System.Data.SqlClient.SqlConnection.ValidateConnectionForExecute(String method, 26. SqlCommand command) 27. at System.Data.SqlClient.SqlCommand.ValidateCommand(String method, Boolean async) 28. at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(DbAsyncResult result, 29. String methodName, Boolean sendToPipe) 30. at System.Data.SqlClient.SqlCommand.ExecuteNonQuery() 31. at ExecuteNonQuery(Object , Object[] ) 32. at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, 33. Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) 34. --- End of inner exception stack trace --- 35. at System.Management.Automation.DotNetAdapter.AuxiliaryMethodInvoke(Object target, 36. Object[] arguments, MethodInformation methodInformation, Object[] originalArguments) 37. at System.Management.Automation.ParserOps.CallMethod(Token token, Object target, 38. String methodName, Object[] paramArray, Boolean callStatic, Object valueToSet) 39. at System.Management.Automation.MethodCallNode.InvokeMethod(Object target, Object[] 40. arguments, Object value) 41. at System.Management.Automation.MethodCallNode.Execute(Array input, Pipe outputPipe, 42. ExecutionContext context) 43. at System.Management.Automation.ParseTreeNode.Execute(Array input, Pipe outputPipe, 44. ArrayList& resultList, ExecutionContext context) 45. at System.Management.Automation.StatementListNode.ExecuteStatement(ParseTreeNode 46. statement, Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext 47. context) 48. --- End of inner exception stack trace --- 49. at Microsoft.Exchange.ProvisioningAgent.ScriptingAgentHandler.OnComplete(Boolean 50. succeeded, Exception e) 51. at Microsoft.Exchange.Provisioning.ProvisioningLayer.OnComplete(Task task, Boolean 52. succeeded, Exception exception) MB wurde angelegt aber IMAP ist immer noch “enabled!!
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 evtl hilft das: [PS] D:\Exchsrvr\PS-Log\MBRights-SA-FA>Get-CmdletExtensionAgent | ft name,enabled,priority - Name Enabled Priority ---- ------- -------- Scripting Agent True 6 OAB Resources Management Agent True 5 Provisioning Policy Agent True 4 Mailbox Resources Management Agent True 3 Rus Agent True 2 Query Base DN Agent True 1 Admin Audit Log Agent True 255 Mailbox Creation Time Agent True 0
-Haselier- 10 Geschrieben 17. August 2012 Autor Melden Geschrieben 17. August 2012 keiner von euch "Spezialisten" eine zündende idee?
tesso 391 Geschrieben 18. August 2012 Melden Geschrieben 18. August 2012 Welchen Dateinamen hat die xml, wie ist der Inhalt?
