robertazo 0 Geschrieben 6. März 2014 Melden Geschrieben 6. März 2014 hello, we have a user who get's the following error message when he opens Outlook (after a couple of seconds) ONLY when he has a Citrix session opened (locally there is not problem at all): "There was a problem reading one or more of your reminders. Some reminders may not appear." Then he gets no popups for reminders at all but as already stated ONLY within Citrix, locally all reminders are popping up properly and not error messages are shown. Citrix servers - Windows 2008 R2 Outlook version in Citrix - Outlook 2007 user's PC OS - Windows XP user's PC Outlook version - Outlook 2007 As far as I know (would need to recheck that) all patches are pretty actual. what we did to try the problem: -run outlook.exe /cleanreminders - did not fix the problem -run outlook.exe /resetfolders - did not fix the problem -create a new mail profile - did not fix the problem -for citrix, roaming profiles are used --> renamed his user profile so that a new one was created - That fixed the problem for one week, then the same issue began again. 1.Does anyone have an idea what I could try further? 2.Does anyone know how to exactly identify corrupted reminders / appointments? Thanks, robertazo Zitieren
NorbertFe 2.197 Geschrieben 6. März 2014 Melden Geschrieben 6. März 2014 Try this: http://support.microsoft.com/kb/2553028/en-us •Office Outlook 2007 does not trigger reminders when it is in online mode. This issue occurs after you apply the hotfix package that is described in KB article 2544404. HTH Norbert Zitieren
robertazo 0 Geschrieben 6. März 2014 Autor Melden Geschrieben 6. März 2014 Hello Norbert, neither hotfix you mentioned is installed at all. Also when using outlook locally in online mode it's working perfectly and except one user there seems to be no one having the problem, at least nobody else claimed until now. Do you or anyone have any further suggestions? Thanks so far! robertazo Zitieren
NorbertFe 2.197 Geschrieben 6. März 2014 Melden Geschrieben 6. März 2014 So did you install the hotfix or not? Could you try? Zitieren
robertazo 0 Geschrieben 6. März 2014 Autor Melden Geschrieben 6. März 2014 I checked that and the update is intended for Office SP2 but we have Office SP3 installed so that won't match. Zitieren
