Securityadvisory: woher Zertifikate bekommen
Per automatischem Update der Certificate Revocation list. Steht doch in dem Artikel drin:
What is Microsoft doing to help with resolving this issue?
Although this issue does not result from an issue in any Microsoft product, we are nevertheless updating the CTL and providing an update to help protect customers. Microsoft will continue to investigate this issue and may make future changes to the CTL or release a future update to help protect customers.
After applying the update, how can I verify that the certificate is in the Microsoft Untrusted Certificates Store?
For Windows Vista, Windows 7, Windows Server 2008, and Windows Server 2008 R2 systems that are using the automatic updater of revoked certificates (see Microsoft Knowledge Base Article 2677070 for details), and for Windows 8, Windows 8.1, Windows RT, Windows RT 8.1, Windows Server 2012, Windows Server 2012 R2, and Windows 10 systems, you can check the Application log in the Event Viewer for an entry with the following values:
  • Source: CAPI2
  • Level: Information
  • Event ID: 4112
  • Description: Successful auto update of disallowed certificate list with effective date: Thursday, September 24, 2015 (or later).
For systems running Windows Vista, Windows 7, Windows Server 2008, or Windows Server 2008 R2 that do not have the automatic updater of revoked certificates installed, this update is not available. To receive this update customers must install the automatic updater of revoked certificates (see Microsoft Knowledge Base Article 2677070 for details).
Falls Deine Systeme keinen Internetzugriff haben, dann kannst Du das auch manuell updaten:
Customers in disconnected environments who are running Windows Vista, Windows 7, Windows 8, Windows Server 2008, Windows Server 2008 R2, or Windows Server 2012 can install update 2813430 to receive this update (see Microsoft Knowledge Base Article 2813430 for details).
Have fun!
Daniel
