J L 10 Geschrieben 17. Juli 2019 Melden Geschrieben 17. Juli 2019 Hallo zusammen, bei mir passiert etwas sehr komisches. Die Rechner in einem Netzwerk können die interne Domain nicht auflösen obwohl die richtigen DNS Server eingetragen sind. Die DNS server können per ping und telnet erreicht werden. Externe Anfrage werden richtig aufgelöst Sogar solche die auf interne Adressen umgebogen sind Server: Srv-SYS1.krauss.test Address: 10.0.0.1 ------------ SendRequest(), len 36 HEADER: opcode = QUERY, id = 18, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: srv-mail.krauss.de, type = A, class = IN ------------ ------------ Got answer (68 bytes): HEADER: opcode = QUERY, id = 18, rcode = NOERROR header flags: response, auth. answer, want recursion, recursion avail. questions = 1, answers = 2, authority records = 0, additional = 0 QUESTIONS: srv-mail.krauss.de, type = A, class = IN ANSWERS: -> srv-mail.krauss.de type = A, class = IN, dlen = 4 internet address = 10.0.0.32 ttl = 3600 (1 hour) -> srv-mail.krauss.de type = A, class = IN, dlen = 4 internet address = 10.0.0.31 ttl = 3600 (1 hour) ------------ ------------ SendRequest(), len 36 HEADER: opcode = QUERY, id = 19, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: srv-mail.krauss.de, type = AAAA, class = IN ------------ ------------ Got answer (103 bytes): HEADER: opcode = QUERY, id = 19, rcode = NOERROR header flags: response, auth. answer, want recursion, recursion avail. questions = 1, answers = 0, authority records = 1, additional = 0 QUESTIONS: srv-mail.krauss.de, type = AAAA, class = IN AUTHORITY RECORDS: -> srv-mail.krauss.de type = SOA, class = IN, dlen = 55 ttl = 3600 (1 hour) primary name server = srv-sys1.krauss.test responsible mail addr = hostmaster.krauss.test serial = 16 refresh = 900 (15 mins) retry = 600 (10 mins) expire = 86400 (1 day) default TTL = 3600 (1 hour) ------------ Name: srv-mail.krauss.de Addresses: 10.0.0.32 10.0.0.31 Wird nun die interne domain abgefragt erhalte ich nur DNS Timeouts. Im DNS Server log finde ich die entsprechende Antrag auch nicht. krauss.test Server: Srv-SYS1.krauss.test Address: 10.0.0.1 ------------ SendRequest(), len 29 HEADER: opcode = QUERY, id = 20, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: krauss.test, type = A, class = IN ------------ DNS request timed out. timeout was 2 seconds. timeout (2 secs) Fehler bei SendRequest. ------------ SendRequest(), len 29 HEADER: opcode = QUERY, id = 21, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: krauss.test, type = AAAA, class = IN ------------ DNS request timed out. timeout was 2 seconds. timeout (2 secs) Fehler bei SendRequest. ------------ SendRequest(), len 29 HEADER: opcode = QUERY, id = 22, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: krauss.test, type = A, class = IN ------------ DNS request timed out. timeout was 2 seconds. timeout (2 secs) Fehler bei SendRequest. ------------ SendRequest(), len 29 HEADER: opcode = QUERY, id = 23, rcode = NOERROR header flags: query, want recursion questions = 1, answers = 0, authority records = 0, additional = 0 QUESTIONS: krauss.test, type = AAAA, class = IN ------------ DNS request timed out. timeout was 2 seconds. timeout (2 secs) Fehler bei SendRequest. *** Zeitüberschreitung bei Anforderung an Srv-SYS1.krauss.test. Hat irgend jemand eine Ahnung was das sein Kann. Client ist - Windows Server 2019 - Windows 10 1903 Vielen Dank für eure Unterstützung Zitieren
Nobbyaushb 1.513 Geschrieben 17. Juli 2019 Melden Geschrieben 17. Juli 2019 Poste mal ein ipconfig /all | clip von dem/den DC´s und mind. einem Client Zitieren
J L 10 Geschrieben 18. Juli 2019 Autor Melden Geschrieben 18. Juli 2019 Die Konfiguration sieht wie folgt aus Netz A <----------------------VPN---------------------> Netz B DC/DNS 10.0.0.1 (SRV-Sys1) Client 10.3.0.240 DC/DNS 10.0.0.2 (SRV-Sys2) Router 10.0.0.254 Router 10.3.0.254 Netz C DC/DNS 10.2.0.240 Windows-IP-Konfiguration Hostname . . . . . . . . . . . . : Srv-SYS1 Primäres DNS-Suffix . . . . . . . : krauss.test Knotentyp . . . . . . . . . . . . : Hybrid IP-Routing aktiviert . . . . . . : Nein WINS-Proxy aktiviert . . . . . . : Nein DNS-Suffixsuchliste . . . . . . . : krauss.test Ethernet-Adapter Ethernet: Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Hyper-V Network Adapter Physische Adresse . . . . . . . . : 00-15-5D-0A-EF-00 DHCP aktiviert. . . . . . . . . . : Nein Autokonfiguration aktiviert . . . : Ja Verbindungslokale IPv6-Adresse . : fe80::f4ff:8429:97e7:a2b7%8(Bevorzugt) IPv4-Adresse . . . . . . . . . . : 10.0.0.1(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.0.0 Standardgateway . . . . . . . . . : 10.0.0.254 DHCPv6-IAID . . . . . . . . . . . : 100668765 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-24-A8-C7-3E-00-15-5D-0A-EF-00 DNS-Server . . . . . . . . . . . : ::1 10.0.0.2 10.2.0.240 NetBIOS über TCP/IP . . . . . . . : Aktiviert Windows-IP-Konfiguration Hostname . . . . . . . . . . . . : WIN-PP26F2NBFBF Primäres DNS-Suffix . . . . . . . : Knotentyp . . . . . . . . . . . . : Gemischt IP-Routing aktiviert . . . . . . : Nein WINS-Proxy aktiviert . . . . . . : Nein Ethernet-Adapter Srv-STU-DATA: Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Network Adapter Multiplexor Driver Physische Adresse . . . . . . . . : 00-30-48-FF-AE-E8 DHCP aktiviert. . . . . . . . . . : Nein Autokonfiguration aktiviert . . . : Ja Verbindungslokale IPv6-Adresse . : fe80::4018:9e6a:541e:6706%20(Bevorzugt) IPv4-Adresse . . . . . . . . . . : 10.3.0.240(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.255.0 Standardgateway . . . . . . . . . : 10.3.0.254 DHCPv6-IAID . . . . . . . . . . . : 335556680 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-24-BD-48-6C-00-30-48-FF-AE-E9 DNS-Server . . . . . . . . . . . : 10.0.0.1 10.0.0.2 NetBIOS über TCP/IP . . . . . . . : Aktiviert Ethernet-Adapter Npcap Loopback Adapter: Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Npcap Loopback Adapter Physische Adresse . . . . . . . . : 02-00-4C-4F-4F-50 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Verbindungslokale IPv6-Adresse . : fe80::a8c6:bc6d:12c8:f99e%35(Bevorzugt) IPv4-Adresse (Auto. Konfiguration): 169.254.249.158(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.0.0 Standardgateway . . . . . . . . . : DHCPv6-IAID . . . . . . . . . . . : 587333708 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-24-BD-48-6C-00-30-48-FF-AE-E9 DNS-Server . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS über TCP/IP . . . . . . . : Aktiviert Zitieren
