Tim--97 0 Geschrieben 22. Oktober 2021 Melden Geschrieben 22. Oktober 2021 Hallo, ich habe folgenden PS Code $username = 'user' $password = 'password' $credential = New-Object System.Management.Automation.PsCredential($username, $password) Connect-ExchangeOnline -credential $credential -Verbose Dieser wirft mir folgenden Fehler: VERBOSE: ExchangeEnvironment : O365Default VERBOSE: ConnectionUri : VERBOSE: AzureADAuthorizationEndpointUri : VERBOSE: DelegatedOrganization : VERBOSE: Prefix : VERBOSE: FormatTypeName :* VERBOSE: CommandName :* VERBOSE: Importing cmdlet 'Add-EXOClientTelemetryWrapper'. VERBOSE: Importing cmdlet 'New-EXOClientTelemetryFilepath'. VERBOSE: Importing cmdlet 'Push-EXOTelemetryRecord'. VERBOSE: Importing cmdlet 'Clear-ActiveToken'. VERBOSE: Importing cmdlet 'New-ExoPSSession'. VERBOSE: Importing cmdlet 'Test-ActiveToken'. New-ExoPSSession : Connecting to remote server outlook.office365.com failed with the following error message : The SSL connection cannot be established. Verify that the service on the remote host is properly configured to listen for HTTPS requests. Consult the logs and documentation for the WS-Management service running on the destination, most commonly IIS or WinRM. If the destination is the WinRM service, run the following command on the destination to analyze and configure the WinRM service: "winrm quickconfig -transport:https". For more information, see the about_Remote_Troubleshooting Help topic. At C:\Program Files\WindowsPowerShell\Modules\ExchangeOnlineManagement\2.0.5\netFramework\ExchangeOnlineManagement.psm1:475 char:30 + ... PSSession = New-ExoPSSession -ExchangeEnvironmentName $ExchangeEnviro ... + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : ResourceUnavailable: (:) [New-ExoPSSession], PSRemotingTransportException + FullyQualifiedErrorId : System.Management.Automation.Remoting.PSRemotingDataStructureException,Microsoft.Exchange.Management.ExoPowershellSnapin.NewExoP SSession Ist das nun ein Fehler auf meinem Server (Microsoft Windows Server 2016 Standard)? Fehlt ein SSL Zertifikat? Oder was genau ist der Fehler? Vielleicht stehe ich hier auch einfach auf dem Schlauch. Danke und VG
NorbertFe 2.325 Geschrieben 22. Oktober 2021 Melden Geschrieben 22. Oktober 2021 SSL geprüft? TLS 1.2 aktiviert? Proxy läßt den Server OHNE SSL Inspection raus? https://docs.microsoft.com/de-de/troubleshoot/azure/active-directory/enable-support-tls-environment
Tim--97 0 Geschrieben 22. Oktober 2021 Autor Melden Geschrieben 22. Oktober 2021 vor 9 Minuten schrieb NorbertFe: SSL geprüft? TLS 1.2 aktiviert? Proxy läßt den Server OHNE SSL Inspection raus? https://docs.microsoft.com/de-de/troubleshoot/azure/active-directory/enable-support-tls-environment [Net.ServicePointManager]::SecurityProtocol Tls12 Im IIS für default website:
tesso 389 Geschrieben 22. Oktober 2021 Melden Geschrieben 22. Oktober 2021 Du kannst das Passwort nicht im Klartext übergeben. $password = ConvertTo-SecureString 'MySecretPassword' -AsPlainText -Force
Tim--97 0 Geschrieben 22. Oktober 2021 Autor Melden Geschrieben 22. Oktober 2021 vor 6 Minuten schrieb tesso: Du kannst das Passwort nicht im Klartext übergeben. $password = ConvertTo-SecureString 'MySecretPassword' -AsPlainText -Force Ahja danke, hab das eigentlich in einen SecureString konvertiert, hatte das nur hier abgeändert. Aber ja stimmt :)
NorbertFe 2.325 Geschrieben 22. Oktober 2021 Melden Geschrieben 22. Oktober 2021 vor 7 Stunden schrieb Tim--97: Im IIS für default website: Der iis ist ziemlich egal ;)
