Dateiendungen
ein passendes und kostenloses Tool für Windows: TrID (engl.)
Homepage: http://mark0.ngi.it/soft-trid-e.html
Info vom Hersteller:
...TrID is a utility designed to identify file types from their binary signatures. While there are similar utilities with hard coded rules, TriID has no such rules. Instead, it is extensible and can be trained to recognize new formats in a fast and automatic way.
TrID uses an XML-based database of definitions which describe recurring patterns for supported file types. The first 2,000 bytes of a file are examined for these patterns....
Viele Grüße,
