Traceback ...
Und täglich grüßt das Murmeltier...
Ein Problem jagt das nächste....
Folgendes Problem:
Bekomme folgende Traceback Meldungen:
Thu Mar 18 00:08:32 2004: <186>692: Mar 8 17:32:53.131: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>693: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>694: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>695: Mar 8 17:32:53.131: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>696: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>697: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>698: Mar 8 17:32:53.131: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>699: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>700: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>701: Mar 8 17:32:53.135: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>702: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>703: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>704: Mar 8 17:32:53.135: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>705: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>706: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>707: Mar 8 17:32:53.135: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>708: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>709: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>710: Mar 8 17:32:53.139: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>711: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>712: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <186>713: Mar 8 17:32:53.139: %SYS-2-INTSCHED: 'may_suspend' at level 5
Thu Mar 18 00:08:32 2004: <186>714: -Process= "PPP IP Route", ipl= 5, pid= 56
Thu Mar 18 00:08:32 2004: <186>715: -Traceback= 8028855C 802711AC 80A9F5BC 80AB31F0 80AB1CE8 810FB358 80AB1D28 80A9BFA4 8044C44C 8044DDE8 8044DE88 8044FF0C 809BA7D0 80280B30 80280C68 809BD634
Thu Mar 18 00:08:32 2004: <190>716: Mar 8 17:32:53.143: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Thu Mar 18 00:08:32 2004: <187>717: Mar 8 17:32:53.147: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Jemand eine Idee, was da verrückt spielt ?
hi,
ja das ist das schicksaal der 12.3 nutzer.
es gibt einen ähnlichen bug der bei cisco beschrieben ist.
Symptoms: There is a CPUHOG at process = PPP IP Route, and the router reloads.
Condition: The symptoms are observed on Cisco 7200 and RSP series routers
running IOS 12.3(4)T1.
Workaround: There is no workaround.
First Fixed-in Version 12.3(7.6)T
nur so zur info. wenn innerhalb eines ios mehr als ein punkt im namen auftaucht ist "bös obacht" angesagt.
Hi Pretender ich bin absolut neu hier und ich habe das gleiche Problem. Vorher war es so das es ne zeit lang gedauert hat bis diese tracebacks angefangen haben. Mittlerweile habe ich meine Config neu eingestellt damit die MTU zuweisung funktioniert So jetzt hab ich haber das Problem, dass es schon nach 5,6,7,8 Std. schon anfängt. Ich weiss nicht warum und nachdem dies eingetreten ist kann ich nicht mehr surfen und gar nichts mehr selbst wenn ich über das HT drauf geh ist die reaktionszeit von dem Router sehr sehr langsam.
Wie könnte man dem Abhilfe schaffen??????
Weiss das vielleicht jemand?
jo eine antwort in der art hatte ich erwartet.
bei neueren ios-versionen kommt alle nase lang update raus.
wenn nicht unbedingt wegen neuren features eine 12.3 sein muß, dann lieber auf eines der letzten 12.2T oder 12.2 gd oder ld versionen gehen.
btw:
das erste 12.x major-release ist "baugleich" mit letzten zuvor erschienen major 12.xT release.
beispiel:
eine 12.3 beinhaltet die gleichen features wie eine 12.2(15)T10
bei einer 12.3 ist halt die wahrscheinlichkeit neuer bugs wesentlich höher.
solange die 12.2T nicht eoe oder eol ist wird sie auch noch supported.
Also das mit dem IOS Update hab ich mir schon durch den kopf gehen lassen aber ich weiss nicht ob das so ohne weiteres möglich ist bei mir. Ich hab einen Cisco 803 Router meine Aktuelle Version ist die 12.2 meinst du das würde funktionieren? So das dann hinterher des DSL weiterhin funktioniert. Weil momentan ist es so das bei mir dieses Dialer interface nur Emuliert wird. Ob das ohne weiteres einfach so funktioniert?????
Kann des vielleicht auch an meiner config liegen? Das diese Tracebacks anfangen? Da wie gesagt das Problem erst aufgetreten ist als ich die config neu angepasst hab!!!
Habe hier einen 836 Zuhause stehen. Natürlich sollte man sofern alle Voraussetzungen, wie z.B. RAM und FLASH Ausbau, stimmen ein anderes IOS verwenden. Die Schwierigkeit für jemanden ohne Cisco Contract dürfte es sein, legal an ein neues Image zu kommen.
Ja schon klar ich wollt eigentlich nur wissen ob das möglich wäre. Problem is halt nur das dein Router "etwas mehr Speicher hat als meiner" :-) Ich hab nur insgesamt 16MB!!!!! ICh bin grad dabei meinen Cisco zu machen mal sehen wie weit ich von meiner Firma unterstützt werde mal sehen aber viele dan @Pretender für die hilfreichen Infos!!!!
