steffen3379 10 Geschrieben 23. März 2004 Melden Geschrieben 23. März 2004 hi mein cisco 803 öffnet nicht alle seiten z.b. die meiner bank aber auch noch viele andere,woran kann das liegen?? hier mal meine config: version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname "router" ! logging buffered 8192 debugging enable password password ! username router clock timezone MET 1 ! dial-peer voice 1 pots no caller-id no forward-to-unused-port call-waiting ring 0 registered-caller ring 1 port 1 destination-pattern xxxx ! pots country DE ip subnet-zero no ip source-route ! ip dhcp pool DHCPPoolLAN_0 import all network 192.168.100.0 255.255.255.0 default-router 192.168.100.1 ! isdn switch-type basic-net3 ! ! ! interface Ethernet0 ip address 192.168.100.1 255.255.255.0 ip access-group 121 in no ip proxy-arp ip nat inside ! interface BRI0 no ip address encapsulation ppp dialer pool-member 1 isdn switch-type basic-net3 isdn incoming-voice modem isdn calling-number xxxx ppp authentication chap pap callin ! interface Dialer1 description ISP ip address negotiated ip access-group 121 in no ip proxy-arp ip nat outside encapsulation ppp no ip split-horizon dialer pool 1 dialer remote-name Cisco1 dialer idle-timeout 150 dialer string 0193670 class DialClass dialer hold-queue 10 dialer-group 1 ppp authentication chap pap callin ppp chap hostname msn@easysurfer-eco.de ppp chap password 0 msn ppp pap sent-username msn@easysurfer-eco.de password 0 msn ppp ipcp dns request ! ip nat inside source list 18 interface Dialer1 overload ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ! map-class dialer DialClass access-list 18 permit 192.168.100.0 0.0.0.255 access-list 100 permit tcp any any eq www access-list 100 permit tcp any any eq 4662 access-list 100 permit tcp any any eq 443 access-list 100 permit tcp any any eq ftp access-list 100 permit tcp any any eq smtp access-list 100 permit tcp any any eq pop3 access-list 100 permit udp any any eq domain access-list 100 permit udp any any eq 80 access-list 100 permit udp any eq domain any dialer-list 1 protocol ip list 100 ! line con 0 exec-timeout 120 0 stopbits 1 line vty 0 4 exec-timeout 0 0 login local ! no rcapi server ! ! end Zitieren
steffen3379 10 Geschrieben 23. März 2004 Autor Melden Geschrieben 23. März 2004 also ich habe nochmal im net gelesen und bin auf darauf gestoßen das man wohl wenn man cisco router verwendet die mtu size verstellen muß !!das habe ich nun auch auf dem rechner gemacht und schon kann ich alle seiten laden!!!:-)) gibt es die möglichkeit das man das am router einstellt?? sonnst müsste ich ja jeden rechner im netzwerk umstellen!! mfg Zitieren
