Firewall Problem (Zyxel 2WE)
Hallo Boarder !
Meine 2WE kickt mich ca. nach 1,5 - 2,5 Stunden aus dem Internet und zwar mit folgenden Log-Einträgen:
34 04/04/2004 22:09:15 Firewall session time out, sent TCP RST 80.170.252.118:6112 172.16.98.10:2286 TCP RST
35 04/04/2004 22:09:15 Firewall session time out, sent TCP RST 172.16.98.10:2286 80.170.252.118:6112 TCP RST
36 04/04/2004 22:09:13 WAN interface gets IP:62.47.62.130 WAN1
37 04/04/2004 22:09:13 ppp:IPCP Opening
38 04/04/2004 22:09:13 ppp:IPCP Starting
39 04/04/2004 22:09:13 ppp:CHAP Opening
40 04/04/2004 22:09:13 ppp:LCP Opening
41 04/04/2004 22:09:09 ppp:LCP Starting
42 04/04/2004 22:09:09 board 0 line 0 channel 0, call 3, C02 OutCall Connected 1000000 CALL DETAIL RECORD
43 04/04/2004 22:09:09 Packet Trigger: Protocol=1, Data=Packet Trigger: Protocol=1, Da PACKET TRIGGER
44 04/04/2004 22:09:09 board 0 line 0 channel 0, call 3, C01 Outgoing Call dev=a ch=0 CALL DETAIL RECORD
45 04/04/2004 22:09:08 board 0 line 0 channel 0, call 2, C02 Call Terminated CALL DETAIL RECORD
46 04/04/2004 22:09:07 Firewall session time out, sent TCP RST 62.47.48.145:6112 80.170.252.118:65328 TCP RST
47 04/04/2004 22:09:07 Firewall session time out, sent TCP RST 80.170.252.118:65328 62.47.48.145:6112 TCP RST
48 04/04/2004 22:09:05 ppp:LCP Closing
49 04/04/2004 22:09:05 ppp:LCP Opening
50 04/04/2004 22:09:05 ppp:LCP Starting
51 04/04/2004 22:09:05 board 0 line 0 channel 0, call 2, C02 OutCall Connected 1000000 CALL DETAIL RECORD
52 04/04/2004 22:09:05 Packet Trigger: Protocol=1, Data=Packet Trigger: Protocol=1, Da PACKET TRIGGER
53 04/04/2004 22:09:04 board 0 line 0 channel 0, call 2, C01 Outgoing Call dev=a ch=0 CALL DETAIL RECORD
54 04/04/2004 22:09:04 ppp:IPCP Closing
55 04/04/2004 22:09:04 ppp:LCP Closing
56 04/04/2004 22:09:04 board 0 line 0 channel 0, call 1, C02 Call Terminated CALL DETAIL RECORD
57 04/04/2004 22:09:04 Exceed TCP MAX incomplete, sent TCP RST 10.0.0.138:1723 10.0.0.140:1074 TCP RST
58 04/04/2004 22:09:04 Exceed TCP MAX incomplete, sent TCP RST 10.0.0.140:1074 10.0.0.138:1723 TCP RST
59 04/04/2004 22:09:03 Firewall session time out, sent TCP RST 10.0.0.140 10.0.0.138 TCP RST
60 04/04/2004 22:09:03 Firewall session time out, sent TCP RST 62.47.48.145:6112 62.47.53.89:24124 TCP RST
61 04/04/2004 22:09:03 Firewall session time out, sent TCP RST 62.47.53.89:24124 62.47.48.145:6112 TCP RST
Das mit dem Call Detail Record soll ja (was ich gehört habe) mit der Verbindung zum ISP zu tun haben und das das so sein muss.
Dass ich momentan dann nicht ins internet komme ist mir auch klar (neue IP vom ISP)
Aber bei meinem ADSL (Österreich Telekom) wird man alle 8-9 h gekickt.
Und noch was schöneres was mir gestern passiert ist:
Mein 2WE hat sich von alleine als ich aus dem Battlenet ausgestiegen bin rebootet
Kann mir jemand bitte nähere Details zu den einzelnen Logs geben:
:suspect: Firewall session time out, sent TCP RST ????
:suspect: Firewall default policy: UDP (W to W/ZW)???? und
:suspect: was es mit den ppp closing und opening ... auf sich hat.
Habe gehört dass es auch an der Hardware der 2WE liegen könnte wenn da jemand erfahrungen hat bitte posten.
Systeminfo:
Model Name : ZyWALL 2WE
ZyNOS Firmware Version: V3.62(WJ.0) | 02/24/2004
Routing Protocols : IP
Vielen lieben Dank im Voraus.
Master
  • 2 Wochen später...
