Ich habe 2 800er Router bei mir stehen. Auf dem einen läuft TinyRom V1.0 und auf dem andren V1.2.
Jetzt ist meine Frage was dieses ROM genau steuert und ob ein Update von dem einen zum anderen Router möglich ist.
hi,
das tiny rom ist u.a verantwortlich für den post (power-on self-test), und das laden des ios.
ein update ist ohne weiteres möglich, da die neueren tiny-rom´s
abwärtskomatibel zu den älteren ios versionen sind.
hier eine liste der tiny-roms und der features:
tiny rom 1.3(1)/ios version 12.1(2.2) and later:
* TinyROM can handle multiple boot system commands in the order they were issued and will attempt to boot the valid images specified.
* If none of the specified images boots, TinyROM boots any of the unspecified IOS images stored in Flash memory.
* IOS will fail to boot only if there are no valid images, or if the router was configured to boot only from TinyROM.
tiny rom 1.2(3) and earlier ios/version 12.1(2.2) and later:
* TinyROM cannot boot from more than one image. If the single image specified fails to boot, TinyROM boots from any valid image stored in Flash memory. TinyROM attempts to boot first from undeleted images, then to those marked for deletion.
* IOS checks the validity of the single boot filename. If the filename is not valid, IOS will display warning messages to that effect.
tiny rom 1.2(1) and earlier/ios version Any:
* TinyROM does not boot from an unspecified image in Flash memory. If the single IOS image that you specify fails to boot, the router remains at the boot# prompt without booting the IOS
tiny rom Any/ios version 12.1(2.1) and earlier:
* IOS will modify the single boot image only if you use the IOS boot system command. Changes to the boot system by any other means (such as copying from TFTP or from Flash memory backup) are ignored.
* Output from the show startup command does not show the correct boot filename unless you edit the boot system list to match the ROM boot filename.
Cool und wenn ich ein Update durchführen möchte wie gehe ich dann vor ?
Einfach nur neuere Datei Uploaden oder wie mach ich das ?
Wie Kompatibel sind die verschiedenen Router Typen untereinander ?
Wie im Beispiel 801 und 803 ??
Gibts das Tiny-Rom und evtl Erklärung bei Cisco for free ?
Neues Benutzerkonto erstellen
Anmelden
