2. Problem SQL ADODB
Kennt sich jemand mit dieser Fehlermeldung aus?
Betrifft auch wieder das SQL Leiden:
Dieses Problem plagt mich sicher schon seid 3 Wochen, Google und CO haben wirklich nichts mehr gebracht.
Es muss irgendwie mit dieser ADODB komponente zu tun haben
Danke für die Hilfe.
Silver
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: File or assembly name ADODB, or one of its dependencies, was not found.
File name: "ADODB"
at eShopReplikation.Form1.Button1_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
=== Pre-bind state information ===
LOG: DisplayName = ADODB, Version=7.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
(Fully-specified)
LOG: Appbase = C:\boshop\
LOG: Initial PrivatePath = NULL
Calling assembly : eShopReplikation, Version=1.0.1447.18977, Culture=neutral, PublicKeyToken=null.
LOG: Publisher policy file is not found.
LOG: Host configuration file not found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322\config\machine.config.
LOG: Post-policy reference: ADODB, Version=7.0.3300.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
LOG: Attempting download of new URL file:///C:/boshop/ADODB.DLL.
LOG: Attempting download of new URL file:///C:/boshop/ADODB/ADODB.DLL.
LOG: Attempting download of new URL file:///C:/boshop/ADODB.EXE.
LOG: Attempting download of new URL file:///C:/boshop/ADODB/ADODB.EXE.
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
eShopReplikation
Assembly Version: 1.0.1447.18977
Win32 Version: 1.0.1447.18977
CodeBase: file:///C:/boshop/eShopReplikation.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Neues Benutzerkonto erstellen
Anmelden
