SparRitter 10 Geschrieben 23. April 2004 Melden Teilen Geschrieben 23. April 2004 Bekomme bei dem Start des Autom W2k Serverupdates immer die Fehlermeldung Error 0x800A138F W2k findet nicht die noch fehlenden Updates danke Zitieren Link zu diesem Kommentar
Gast fusselkopp Geschrieben 23. April 2004 Melden Teilen Geschrieben 23. April 2004 Hola :-) erstmal der typische an******: RTFM ;-) unter http://v4.windowsupdate.microsoft.com/troubleshoot/ , erreichbar über "hilfe und Support" steht folgendes: Error 0x800A138F when scanning for updates This behavior indicates that the scan process encountered an error it could not recover from. You may be able to determine the specific error by looking in the Windows Update.log file, located in the Windows folder on Windows XP, Windows 98, and Windows Millennium Edition. The folder is located in the Winnt folder on Windows 2000. Temporarily disabling antivirus and firewall programs while you use Windows Update may solve this problem. Be sure to enable them again when you complete the update process. You might also be able to resolve this issue by deleting all of the content in Program Files\Windowsupdate and Program Files\Windowsupdate\V4 except for the iuhist.xml file located in Program Files\Windowsupdate\V4. gruß, fusselkopp Zitieren Link zu diesem Kommentar
