Gruppenrichtlinien Problem !
@fritzo:
sind in den Netzwerkeinstellungen auf dem DC die Einträge für WINS und DNS enthalten? Der DC muß auf sich selbst verweisen, also trag ihm jeweils seine eigene IP ein.
Meinst du die Netzwerkkarten / Eigenschaften :
hier steht unter erweitert DNS / und Wins je mit 10.10.32.100
I had this problem when I deactivated the DNS Client service but it was not fixed by simply restarting the DNS Client.
If this error appears on one or more Windows 2003 DCs, the problem is not the DNS Client. The 1058/1030 errors are a result of a wrong DNS query. When a DC wants to load and apply the GPs, it is sending a DNS query against the domain name (e.g. \\mydomain.local\sysvol\policies...). Now comes the bug: the DC is getting the wrong IP adress for the sysvol-Dfs-share hosted on each DC. This IP adress is neither a part of your DC configuration nor a part of your subnet. So in fact, the DC tries to reach a machine which isn't there. As a result, you'll get the 1058 error message ("access denied").
I have tried to hotfix this with Q830905 which can be obtained from PSS, but in my case it did not work. Thanks to Walter Russo, he suggested a workaround by adding the IP adresses of each DC to local hosts-file. For example, if you have the domain "mydomain.local" you have to edit the hosts file on each DC as follows:
mydomain.local 10.0.0.1 # local DC
mydomain.local 10.0.0.2 # second DC
mydomain.local 10.0.0.3 # third DC
Make sure that you always mention the local adress first. This method works, because by using the hosts file, the local DNS cache is loading the entries with a non-expiry TTL. So no DNS query will be performed for the "mydomain.local" name.
--> weitere mögliche Lösungen
-Start "TCP/IP NetBIOS Helper Service", Startart Automatisch
-Neustart DFS-Dienst
-dcgpofix.exe (vorsicht)
-Q810907
-Q314494
Grüße,
Fritz
@fritzo:
Du meinst TCP IP NEtbios Hilfsprogramm ?!
ist automatisch gestartet
die Q's hab ich durch
dcgpofix hilft mir beim Zugriff auf sysvol glaube ich wenig ;)
Grüße
ich denke wir sollten uns auf die Freigaben Sysvol und netlogon konzentrieren oder ?! alles andere läuft ja :cry:
Das Archiv mit dem Screenshot ist defekt.
hm...
hast Du eigentlich in der Zwischenzeit mal eine Pause gemacht? Wenn nicht - mach mal, trink Dir nen Kaffee und iß was.
("ja Mama") *grins
Ansonsten - was passiert, wenn Du Dir SYSVOL auf dem DC selbst ansiehst - erscheint da auch kein Karteireiter "DFS"?
Grüße,
Fritz
