[Cisco 1603] Keine Einwahl mehr moeglich
Hi,
ich habe seit heute morgen Probleme mit der Einwahl ueber meinen Cisco 1603 - manuell ueber den Windows PPPoE-Treiber funzt es.
Staendig bekomme ich folgende Meldungen:
Mar  1 00:19:23.440: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
Mar  1 00:19:23.448: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to
up
Mar  1 00:19:26.666: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
Mar  1 00:19:26.678: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to
down
router#
Mar  1 00:19:49.335: %DIALER-6-BIND: Interface Vi2 bound to profile Di1
Mar  1 00:19:49.343: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to
up
Mar  1 00:19:52.466: %DIALER-6-UNBIND: Interface Vi2 unbound from profile Di1
Mar  1 00:19:52.478: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state to
down
Meine Config schaut folgendermaßen aus:
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname router
enable secret 5 geheim
enable password geheim
clock timezone MET 1
clock summer-time MST recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
request-dialin
 protocol pppoe
ip mtu adjust
interface Ethernet0
description LAN interface
ip address 192.168.7.1 255.255.255.0
no ip unreachables
ip nat inside
load-interval 30
shutdown
pppoe enable
pppoe-client dial-pool-number 1
no keepalive
no cdp enable
no shut
interface BRI0
no ip address
shutdown
interface Dialer1
description Versatel
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer remote-name isp
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username meinusername password 0 meinpwd
ip nat translation timeout 120
ip nat translation tcp-timeout 1000
ip nat translation udp-timeout 30
ip nat translation icmp-timeout 30
ip nat translation max-entries 2500
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.7.3 4005 interface Dialer1 4005
ip nat inside source static tcp 192.168.7.3 4006 interface Dialer1 4006
ip nat inside source static udp 192.168.7.3 4006 interface Dialer1 4006
ip nat inside source static udp 192.168.7.3 4005 interface Dialer1 4005
ip nat inside source static tcp 192.168.7.3 5005 interface Dialer1 5005
ip nat inside source static tcp 192.168.7.3 5004 interface Dialer1 5004
ip nat inside source static tcp 192.168.7.3 5003 interface Dialer1 5003
ip nat inside source static tcp 192.168.7.3 5002 interface Dialer1 5002
ip nat inside source static tcp 192.168.7.3 5001 interface Dialer1 5001
ip nat inside source static tcp 192.168.7.3 5000 interface Dialer1 5000
ip nat inside source static udp 192.168.7.3 14567 interface Dialer1 14567
ip nat inside source static tcp 192.168.7.3 14567 interface Dialer1 14567
ip nat inside source static tcp 192.168.7.4 80 interface Dialer1 80
ip nat inside source static udp 192.168.7.4 80 interface Dialer1 80
ip nat inside source static udp 192.168.7.3 4672 interface Dialer1 4672
ip nat inside source static udp 192.168.7.3 4665 interface Dialer1 4665
ip nat inside source static tcp 192.168.7.3 4662 interface Dialer1 4662
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip http server
access-list 1 permit 192.168.7.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server trap-source Ethernet0
snmp-server location Keller
snmp-server contact phil
snmp-server enable traps tty
snmp-server enable traps config
snmp-server host xxx.xxx.xxx.xxx public  config snmp
line con 0
line vty 0 4
password geheim
login
sntp server 192.53.103.104 version 3
sntp server 192.53.103.103 version 3
ntp server 192.168.1.100
end
Wieso bekomme ich nun anstelle einer Einwahl staendig diese Meldungen?
gruss
edit: Habe grad nochmal 'debug ppp negotiation' gemacht, und dabei folgende Meldungen registriert:
Mar  1 00:19:23.000: Vi1 LCP: I CONFACK [REQsent] id 1 len 14:16:15.968: Vi1 LCP
Mar  1 00:19:24.900: Vi1 LCP: O CONFREQ [ACKrcvd] id 2 len 14
Mar  1 00:19:24.900: Vi1 LCP:    MRU 1492 (0x010405D4)
Mar  1 00:19:24.904: Vi1 LCP:    MagicNumber 0x030F01C5 (0x0506030F01C5)
Mar  1 00:19:24.920: Vi1 LCP: I CONFACK [REQsent] id 2 len 14
Mar  1 00:19:24.924: Vi1 LCP:    MRU 1492 (0x010405D4)
Mar  1 00:19:24.924: Vi1 LCP:    MagicNumber 0x030F01C5 (0x0506030F01C5)
Mar  1 00:19:26.011: Vi1 LCP: I CONFREQ [ACKrcvd] id 235 len 19
Mar  1 00:19:26.015: Vi1 LCP:    MRU 1492 (0x010405D4)
Mar  1 00:19:26.019: Vi1 LCP:    AuthProto CHAP (0x0305C22305)
Mar  1 00:19:26.019: Vi1 LCP:    MagicNumber 0x3A6E59C5 (0x05063A6E59C5)
Mar  1 00:19:26.023: Vi1 LCP: O CONFACK [ACKrcvd] id 235 len 19
Mar  1 00:19:26.027: Vi1 LCP:    MRU 1492 (0x010405D4)
Mar  1 00:19:26.027: Vi1 LCP:    AuthProto CHAP (0x0305C22305)
Mar  1 00:19:26.031: Vi1 LCP:    MagicNumber 0x3A6E59C5 (0x05063A6E59C5)
Mar  1 00:19:26.031: Vi1 LCP: State is Open
Mar  1 00:19:26.035: Vi1 PPP: Phase is AUTHENTICATING, by the peer
Mar  1 00:19:26.047: Vi1 CHAP: I CHALLENGE id 76 len 38 from "sr2.DTM1"
Mar  1 00:19:26.055: Vi1 CHAP: Unable to authenticate for peer
Mar  1 00:19:26.059: Vi1 PPP: Sending Acct Event[Down] id[2E]
Mar  1 00:19:26.063: Vi1 PPP: Phase is TERMINATING
Mar  1 00:19:26.063: Vi1 LCP: O TERMREQ [Open] id 3 len 4
Mar  1 00:19:26.142: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Mar  1 00:19:26.154: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to
down
Insbesondere dieses
verwundert mich. Wenn ich mich mit den exakt selben Daten mithilfe des Windows-PPPoE-Client einwaehle bekomme ich naemlich wie gesagt keinen Fehler.
Hi!
Das ist es ja was mich wundert; vorher lief sie so!
Hier das Log:
router#debug ppp authentication
PPP authentication debugging is on
router#
Mar  1 03:24:28.618: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
Mar  1 03:24:28.622: Vi1 PPP: Using dialer call direction
Mar  1 03:24:28.626: Vi1 PPP: Treating connection as a callout
Mar  1 03:24:28.626: Vi1 PPP: Authorization required
Mar  1 03:24:28.630: Vi1 PPP: No remote authentication for call-out
Mar  1 03:24:28.634: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to
up
Mar  1 03:24:31.669: Vi1 PPP: No authorization without authentication
Mar  1 03:24:31.892: Vi1 CHAP: I CHALLENGE id 35 len 32 from "sr2.DTM1"
Mar  1 03:24:31.899: Vi1 CHAP: Unable to authenticate for peer
Mar  1 03:24:32.201: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Mar  1 03:24:32.213: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to
down
Hi !
Bist Du sicher ?
Warum gerade callin ?
Oder war das Protocol nicht eher chap ?
Versuchs mal mit chap (ohne callin) !
Mfg
Geht leider auch nicht.
Habe nun folgendes eingegeben:
router(config-if)#ppp authentication pap chap
und bekomme immer folgende Meldung:
Mar  1 04:07:12.430: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
Mar  1 04:07:12.434: Vi1 PPP: Using dialer call direction
Mar  1 04:07:12.434: Vi1 PPP: Treating connection as a callout
Mar  1 04:07:12.438: Vi1 PPP: Authorization required
Mar  1 04:07:12.442: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to
up
Mar  1 04:07:12.609: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
Mar  1 04:07:12.620: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to
down
Ausserdem hats ja vorher gefunzt.. :(
Das Problem ist nun geloest.
Es lag daran, dass mein Provider (ohne mich zu informieren) das Einwahlprotokoll auf CHAP umgestellt habe. Ich als nichtswissender habe nun stundenlang versucht mich mit PAP einzuwaehlen.. *naaarf*
