Problem bei CISCO 800 Einwahl ISDN !
vielleicht hat da jemand eine Idee, ich möchte mir eine Verbindung zweier Standorte (CISCO 800 zu CISCO 2610) herstellen.
Auf dem CISCO 800 habe ich folgende Config eingegeben:
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router1
logging buffered 8192 debugging
enable secret 5 xxxxxxxxxxxxxxxxxxxx
username ntnetdog password 7 xxxxxxx
ip subnet-zero
no ip source-route
isdn voice-call-failure 0
interface Ethernet0
ip address 192.168.125.1 255.255.255.0
no ip directed-broadcast
no ip proxy-arp
interface BRI0
no ip address
encapsulation ppp
dialer pool-member 1
dialer pool-member 2
isdn switch-type basic-net3
isdn answer1 123456
isdn calling-number 123456
interface Dialer1
description Remote Zugriff 1
ip unnumbered Ethernet0
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer remote-name Remote1
dialer pool 1
dialer idle-timeout 40
dialer string 0815123456 class DialClass
dialer caller x123456
dialer hold-queue 10
dialer load-threshold 10 either
dialer-group 1
pulse-time 0
ppp authentication chap pap callin
ppp chap hostname ntnetdog
ppp chap password 7 xxxxxxxx
ppp pap sent-username ntnetdog password 7 xxxxxxx
interface Dialer2
description Remote Zugriff 2
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer remote-name Remote2
dialer pool 2
dialer string 081512345 class DialClass
dialer caller x123457
dialer-group 1
pulse-time 0
ppp chap password 7 xxxxxxxxx
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.120.5
ip route 192.168.104.0 255.255.255.0 Dialer1
ip route 192.168.102.0 255.255.255.0 Dialer1
ip route 192.168.103.0 255.255.255.0 Dialer1
ip route 192.168.105.0 255.255.255.0 Dialer1
ip route 192.168.106.0 255.255.255.0 Dialer1
ip route 192.168.107.0 255.255.255.0 Dialer1
ip route 192.168.108.0 255.255.255.0 Dialer1
ip route 192.168.109.0 255.255.255.0 Dialer1
ip route 192.168.120.0 255.255.255.0 Dialer2
map-class dialer DialClass
dialer-list 1 protocol ip permit
line con 0
exec-timeout 0 0
password 7 xxxxxxxxxxxxxxxxx
transport input none
line vty 0 4
login
no rcapi server
end
Problem ist, mit einer ISDN-Karte kann ich eine Verbindung zu dem CISCO 2610 aufbauen und dann über die Eingabeaufforderung auch einen Ping an den CISCO 2610 senden.
Über die oben gennante Config habe ich gesehen, dass er sich wohl einwählt (orange-LED leuchtet einige Minuten) allerdings bekomme ich beim pingen in das andere Netz keine Antwort.
Was habe ich falsch gemacht ???
:rolleyes:
Hi,
welche Orange Lampe geht an? Die vom Cisco 800 oder vom 2600?
Im Grunde sieht die COnfig schon o.k. aus.
Mach bitte mal folgendes:
debug isdn q931 auf beiden seiten. Damit siehst du welche nummer gerufne wird ob ein connected zustande kommt oder nicht. Wenn das o.k. ist dann mach mal ein debug ppp authentification
dann bitte alles rufnummern und passwörter raus machen und hier bitte posten.
Also hier das Ergebnis vom Logging:
Beim ISDN-Logging hat alles gut ausgesehen, hier das
PPP-Logging:
1d01h: %DIALER-6-BIND: Interface BRI0:1 bound to profile Dialer1
1d01h: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 0815123456
1d01h: BR0:1 PPP: Treating connection as a callout
1d01h: BR0:1 CHAP: I CHALLENGE id 43 len 26 from "ntnetdog"
1d01h: BR0:1 CHAP: Using alternate hostname lueke
1d01h: BR0:1 CHAP: Ignoring Challenge with local name
1d01h: BR0:1 CHAP: I CHALLENGE id 44 len 26 from "ntnetdog"
1d01h: BR0:1 CHAP: Using alternate hostname ntnetdog
(Rufnummer und Hostname verändert)
Heist das hier er hat ein Passwort Problem ? :suspect:
Gib uns mehr, viel mehr :D
Bis dahin hat der Router eine Connection hingezimmert, der interessante Teil müsste dann in den nächsten paar Zeilen kommen, irgendein established oder irgendein Abbruch mt entsprechenden Meldungen.
Gruss
Markus
Problem ist, da kommt nicht mehr...
...ausser:
ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from 0815123456 , call lasted 39 secounds
und das haut auch hin, denn da ist ein idle-timeout bei 40,
nur es geht kein Ping oder sonst irgendetwas durch die Leitung, selbst die orange LED leutet die 40 Sekunden, so sagt auch das Logging, dass die Verbindung da ist.
Alles sehr eigenartig...
HILFE !!!
