KiXtart Script - Drucker löschen und als Standart Setzten
Mi dem Tool con2prt.exe laesst sich das Ganze realisieren.
CON2PRT: Lets the user disconnect all existing connections to Windows NT
printers and connect to newly specified Windows NT printers.
Usage: CON2PRT [ /? | /h | /f |
[/c \\printserver\share | /cd \\printserver\share]+]
where:
/? - displays usage.
/h - displays usage.
/f - deletes all existing printer connections.
/c - connects to \\printserver\share printer.
/cd - connects to \\printserver\share printer and sets it as the default
printer.
NOTE: /?, /h can only be the first parameter and if specified further
interpretation of the command line is stopped. /f can also only
be the first parameter, however it doesn't stop further
interpretation of the command line. Any number of /c and /cd
parameters can be specified however only the first /cd sets the
printer specified as the default.
Gruss Michael
