macabros 10 Geschrieben 23. Juni 2004 Melden Geschrieben 23. Juni 2004 Hi, habe folgendes Problem u keine Ahnung mehr was ich noch machen soll. ====================================================================== Job server: Servername Job name: Dienstag_gerade Job started: Dienstag, 22. Juni 2004 at 23:00:07 Job type: Backup Log file: BEX44.txt ====================================================================== Drive and media information from media mount: Changer Name: Drive Name: SEAGATE 2 Media Slot: 0 Media Cartridge Label: 4MM000009 Targeted Media Set Name: Tapes ====================================================================== Job Operation - Backup Media operation - overwrite. Hardware compression enabled. ====================================================================== Media Name: "Dienstag_gerade" Backup of "\\SERVERNAME\Microsoft Information Store\Erste Speichergruppe " Backup set #1 on storage media #1 Backup set description: "Dienstag_gerade" Backup Type: FULL - Database & Logs (flush committed logs) Backup started on 22.06.2004 at 23:01:38 . Log files Backup completed on 22.06.2004 at 23:29:39 . Backed up 2 Exchange Server store(s) Backed up Exchange Server logs Processed 5.500.150.616 bytes in 28 minutes and 1 second. Throughput rate: 187,2 MB/min ---------------------------------------------------------------------- Media Name: "Dienstag_gerade" Backup of "E: DATA" Backup set #2 on storage media #1 Backup set description: "Dienstag_gerade" Backup Type: NORMAL - Back Up Files - Reset Archive Bit Backup started on 22.06.2004 at 23:29:39 . Media mount failed. User aborted a Physical Volume Library operation. Backup completed on 23.06.2004 at 00:34:40 . Backed up 73147 files in 4969 directories. Processed 10.320.783.901 bytes in 52 minutes and 51 seconds. Throughput rate: 186,2 MB/min ---------------------------------------------------------------------- ====================================================================== Job ended: Mittwoch, 23. Juni 2004 at 00:34:40 Job completion status: Aborted by SERVERNAME\. ====================================================================== habe laut Veritas Knowledge Base schon das Datensicherungslaufwerk deinstalliert und wieder installieren lassen. Leider kein Erfolg: Ein neues Datensicherungslaufwerk eingebaut + Bänder ausgetauscht --> erfolg das er jetzt wenigstens wieder den Information Store siehe oben sichert. Zur Info es ist ein DDS4 Laufwerk von Seagate mit DDS3 Bändern. Jemand eine Idee woran das liegen könnte? gruß MacabroS Zitieren
