xtragood 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Original geschrieben von xtrapack 2.- Priorität über start Befehl ändern ??? Keine Ahnung wo und wie der start Befahlt anzuwenden ist START ["title"] [/Dpath] [/i] [/MIN] [/MAX] [/sEPARATE | /SHARED] [/LOW | /NORMAL | /HIGH | /REALTIME | /ABOVENORMAL | /BELOWNORMAL] [/WAIT] [/b] [command/program] [parameters] "title" Title to display in window title bar. path Starting directory B Start application without creating a new window. The application has ^C handling ignored. Unless the application enables ^C processing, ^Break is the only way to interrupt the application I The new environment will be the original environment passed to the cmd.exe and not the current environment. MIN Start window minimized MAX Start window maximized SEPARATE Start 16-bit Windows program in separate memory space SHARED Start 16-bit Windows program in shared memory space LOW Start application in the IDLE priority class NORMAL Start application in the NORMAL priority class HIGH Start application in the HIGH priority class REALTIME Start application in the REALTIME priority class ABOVENORMAL Start application in the ABOVENORMAL priority class BELOWNORMAL Start application in the BELOWNORMAL priority class WAIT Start application and wait for it to terminate command/program If it is an internal cmd command or a batch file then the command processor is run with the /K switch to cmd.exe. This means that the window will remain after the command has been run. If it is not an internal cmd command or batch file then it is a program and will run as either a windowed application or a console application. ...sollte helfen... Übrigens hab ich erst kürzlich gelesen, daß ein Virus NTVDM mit 100% Auslastung belegt, leider wird dieser nicht von allen Scannern erkannt. Deswegen sollte man sich mal ne Boot-CD/Disk mit Scanner machen und dann mal überprüfen... Tritt das Problem auch replizierbar auf anderen Rechnern (neu installiert) auf? Zitieren Link zu diesem Kommentar
jvogler 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Lässt sich in meinem Fall auf jedem Rechner mit W2k oder XP Pro nachstellen. Virus würde ich ausschließen. Auch in einer frischen VM mit NT4 läuft mein DOS Proggi völlig normal. Lässt sich "start" unter Standard Userrechten ausführen? Jochen Zitieren Link zu diesem Kommentar
xtragood 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 ...ok, dann würde ich den Virus auch ausschließen! Ich hatte noch keine Probleme mit Rechten. Probier's einfach mal aus... Zitieren Link zu diesem Kommentar
xtrapack 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 die Auslastung tritt auf allen Rechnern einer Abteilung auf die mit dem alten DOS Programm noch arbeiten (6 Stück) Alle laufen unter WinNT4 WS Virus kann ich ausschliessen da alle Rechner vor einer Woche frisch aufgesetzt wurden und sofort nach Inbetriebnahme das Problem hatten. Die 100% treten NUR bei den neuen Dell Optiplex GS270N auf - die alten Rechner, Dell Dimension 4100 mit PIII, hatten dieses Problem nicht, obwohl sie ebenfalls unter NT liefen !?!?! Ich hab die PIF , autoexec.nt und config.nt von den alten rechnern 1:1 übernommen. Auf anderen älteren Rechnern läuft das DOS Programm zur Zeit auch ohne probleme - unter Windows2000 ebenfalls ohne Probleme. Wie gesagt hatet ich Probleme mit GHOST und rausgefunden das es an dem neuen Chipsatz der Optiplexe liegt - ist es vorstellbar das auch hier der Hund begraben liegt ??? Zitieren Link zu diesem Kommentar
cyberfox 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Hi, also ich stimme dem Weihnachtsmann da zu. Das generelle Problem ist die 16bit Unterstützung von Windows, die leider noch immer implementiert ist und generell das System einmal bremmst! Wenn Du jetzt alte Programme startest und sie mit neuer Hardware fütterst, so zu sagen, kommen diese damit ned wirklich zurrecht. Also cih sehe das so: Das DOS Programm erkennt nicht, dass die CPU genug Rechenleistung hat, weil der Wert einen Überlauf proudziert und somit sagt, hei i hab nur 1MHZ z.B ... somit fordert das Programm mehr leistung, da es ja langsam is. Also der ich sehe das Problem in der Schnittstelle 16bit - 32bit von Windows selber. Das Program kan da gar nix dafür. ALso der Arktikel ist da eh recht brauchbar denk ich. lG, Fox Zitieren Link zu diesem Kommentar
jvogler 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 In Deinem Fall könnte vielleicht der 2GHz M$ Patch helfen. Telefonier doch mal... Jochen Zitieren Link zu diesem Kommentar
weide_1 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Ich verfolge das Probelm schon seit mindestens einen halben Jahr auf einen Win2003 Server! Hab aber nirgends eine Lösung gefunden! Dann habe ich mir Virtuel PC von MS besorgt, und auf diesen Rechner installiert! SubSystem Win98! Da läuft dieses Dos-Programm nun ohne Probleme! Nachteil: Virtual PC grabscht sich auch 15 % der Resourcen, aber allerdings besser als 100% Zitieren Link zu diesem Kommentar
ronny3312 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Hallo, @weide_1 Und was ist dann mit den Vorteilen von Windows 2003 (ADS, NFTS, Terminal,usw) Die kannst Du dann leider nicht nutzen, oder wie hast du das dann gelöst? Wir haben das Problem hier auch und hatten auch an eine solche Lösung gedacht, allerdings waren wir uns dann einig das wir dann keinen Umstieg machen müßten. Aber ich bin beruhigt das andere dieses Problem auch haben und es anscheinend keine richtige Lösung dafür gibt. Gruß Karsten ronny3312 Zitieren Link zu diesem Kommentar
xtragood 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 Man könnte das Problem lösen, indem man einen VirtualPC Client (z.B. VMWare Workstation) laufen lässt, auf dem man DOS installiert und dort das 16 Bit Programm ausführt. Hat den Vorteil, daß man alle Resourcen kontrollieren kann. Zum Problem: Vielleicht liegt es an der Emulierung der 16Bit Daten per Windows auf die 32Bit Prozessor - Technologie (obwohl bis PIII die volle Abwärtsunterstützung gewährleistet war, weiß ich leider nicht, ob da was mit der P4 Architektur geändert wurde) Zitieren Link zu diesem Kommentar
weide_1 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 @ronny3312 Auf auf den Virtuellen Win98 Rechner läuft nur ein Dos-Programm mehr nicht! Da kann ich getrost die anderen Sachen auf den W2003 Server laufen lassen! Hier brauche ich auch keine Vorteile die NTFS etc bieten! Zitieren Link zu diesem Kommentar
xtrapack 10 Geschrieben 12. August 2004 Melden Teilen Geschrieben 12. August 2004 das mit dem START befehl wäre nich schlecht wen ichs zum laufen bringen würde Im DOS Fenster mit eintippen des START Befehls und der Parameter startet mein DOS Prog in Priorität LOW und die Auslastung geht von 100% runter auf zeitweise 40-50% wenn ich zB Outlook starte START funktioniert aber nur im DOS Fenster - in einer batch bleibt die Priorität auf NORMAL obwohl das programm mit der batch startet - die befehlszeile also ausgeführt wird ???!!! wieso geht das nicht in ner batch ??? Zitieren Link zu diesem Kommentar
tomw 10 Geschrieben 17. August 2004 Melden Teilen Geschrieben 17. August 2004 nachdem ich jetzt wieder stunden mit dem prob zugebracht hab - leider ergebnislos.... keine weiteren ideen was man noch probieren könnte ??? Zitieren Link zu diesem Kommentar
ccna2000 10 Geschrieben 17. August 2004 Autor Melden Teilen Geschrieben 17. August 2004 habe das Problem "gelöst". es gibt ein progwas die cpu leistung auf fast 0 prozent drückt. http://www.tamedos.com/downloads/downloads.htm ist zwar nur eine 30-tage-version, aber wenn das bei euch auch so läuft, dann holt euch die vollversion. kostet nur 20 US$ aber immer noch besser, als wenn man ne woche rumtüftelt! dank euch für euere hilfe! MfG CCNA2000 :D Zitieren Link zu diesem Kommentar
tomw 10 Geschrieben 23. August 2004 Melden Teilen Geschrieben 23. August 2004 danke - der tip mit tamedos ist gold wert 20$ zahl ich da gerne wenn ich mich nicht mehr stundenlang mit den prob rumschlagen muss. runtergeladen installiert = 0% wieder deinstalliert = 100% wieder installiert = 0% also direkt registriert und fertig ! Zitieren Link zu diesem Kommentar
ccna2000 10 Geschrieben 7. September 2004 Autor Melden Teilen Geschrieben 7. September 2004 moin. erstam danke für euere tatkräftige unterstützung. habe mir das programm tamedos runtergeladen. http://www.tamedos.com 30 tage trail. ist aber echt super. habe es erstmal gekauft. ist auch easy. nur kreditkarten-nummer und dann eine per mail erhaltene .exe öffnen, fertig. kann es nur jedem empfehlen der dieses problem hat. also, nochmal danke und bis zum nächsten mal! mfg ccna2000 :) Zitieren Link zu diesem Kommentar
