FETT 10 Geschrieben 1. September 2004 Melden Geschrieben 1. September 2004 Hi wie kann ich denn bei der unteren konfiguration die rufnummernindentifizierung machen? also das der router ne bestimmte nummer hat und nur ne bestimmte nummer akzeptiert! ! service timestamps debug uptime service timestamps log uptime no service password-encryption no service tcp-small-servers no service udp-small-servers ! hostname **** ! enable secret **** username **** password **** ! no ip name-server ! isdn switch-type basic-net3 ! ip subnet-zero no ip domain-lookup ip routing ! interface Dialer 1 description connected to **** ip address ***** ip nat inside no ip split-horizon encapsulation ppp dialer in-band dialer idle-timeout 50 dialer remote-name **** dialer-group 1 dialer pool 1 ppp authentication chap pap callin ppp multilink no cdp enable peer default ip address pool Cisco801-Group-1 ! interface Dialer 2 description connected to Internet ip address negotiated ip nat outside no ip split-horizon encapsulation ppp dialer in-band dialer idle-timeout 50 dialer string 1619 class 56K dialer hold-queue 10 dialer load-threshold 10 dialer remote-name **** dialer-group 1 dialer pool 2 ppp authentication chap pap callin ppp chap hostname **** ppp chap password 7 **** ppp pap sent-username **** password 7 **** ppp multilink no cdp enable ! interface Ethernet 0 no shutdown description connected to **** ip address ***** ip nat inside keepalive 10 ! interface BRI 0 no shutdown description connected to **** no ip address encapsulation ppp dialer pool-member 1 dialer pool-member 2 ! map-class dialer 56K dialer isdn speed 56 ! ! Access Control List 1 ! no access-list 1 access-list 1 permit 192.168.10.0 0.0.0.255 access-list 1 permit 192.168.11.0 0.0.0.255 ! ! Dialer Control List 1 ! no dialer-list 1 dialer-list 1 protocol ip permit ! ! Dynamic NAT ! ip nat translation timeout 86400 ip nat translation tcp-timeout 86400 ip nat translation udp-timeout 300 ip nat translation dns-timeout 60 ip nat translation finrst-timeout 60 ip nat inside source list 1 interface Dialer 2 overload ! router rip version 2 network 192.168.11.0 network 192.168.10.0 passive-interface Dialer 2 no auto-summary ! ! ip local pool Cisco801-Group-1 192.168.11.2 192.168.11.3 ip classless ! ! IP Static Routes ip route 0.0.0.0 0.0.0.0 Dialer 2 no ip http server snmp-server location Tunesien snmp-server contact ***** banner motd #Please do not change anything!!!# ! line console 0 exec-timeout 0 0 password **** login ! line vty 0 password **** login ! end Zitieren
tom12 10 Geschrieben 4. September 2004 Melden Geschrieben 4. September 2004 Hi, mit dem Befehl dialer caller 123456 am Dialer Interface konfigurierst du die Rufnummererkennung. Du kannst auch mehrere Nummern konfigurieren.. Grüsse Thomas Zitieren
thorgood 10 Geschrieben 4. September 2004 Melden Geschrieben 4. September 2004 Mit isdn calling-number Rufnummer wird dem Router die MSN mitgeteilt, über welche er rauswählen soll. interface BRI0 isdn calling-number Rufnummer Mit isdn caller Rufnummer akkzeptiert er nur einen eingehenden Ruf wenn die richtige MSN übermittelt wird. interface BRI0/0 isdn caller Rufnummer thorgood Zitieren
corc 10 Geschrieben 4. September 2004 Melden Geschrieben 4. September 2004 Hi, Original geschrieben von thorgood Mit isdn calling-number Rufnummer wird dem Router die MSN mitgeteilt, über welche er rauswählen soll. interface BRI0 isdn calling-number Rufnummer Mit isdn caller Rufnummer akkzeptiert er nur einen eingehenden Ruf wenn die richtige MSN übermittelt wird. interface BRI0/0 isdn caller Rufnummer thorgood in einer Konfiguration mit Dialer-Pools (wie oben) funktioniert das mit interface Dialer1 dialer caller 12345 für CLI (calling line identification) bzw. mit interface Dialer1 dialer called 54321 um die Nummer festzulegen, auf die der Router bei einem eingehenden Anruf reagieren soll. Gruß, corc. Zitieren
berndwalter 10 Geschrieben 23. November 2004 Melden Geschrieben 23. November 2004 Hallo! Bin auch absoluter IOS Neuling, hab zwar nen MCSE, aber IOS ist ja ne ganz andere Welt :) Ich versuch gerade mir mit nem 801 sozusagen ne Hintertür zu schaffen, falls mal wieder die DSL Leitung ausfällt. An sich muss der Router nur eins können. - Ich ruf Ihn auf der MSN 123456 an und er hebt ab - Danach bekomm ich ne IP aus diesem Subnet Als ergänzung wäre es natürlich noch cool, wen der Router auch als VPN Server dienen könnte, aber ich denke das packt das Kistchen nicht :) Kann mir dafür mal jemand ne Beispielkonfiguration geben, eventuell auch ausm ConfigMaker, damit ich die einfach einspielen kann? Die aktuelle Konfiguration blick ich einigermaßen, aber jetzt ist erstmal wichtig, dass das Ding funktioniert. Danach gehts dann ans lernen :) Danke für eure Hilfe! Ach ja, sachen wie Routing,... kann ich, das sollt ich eigentlich selber hinbekommen. Nur die ISDN Konfig blick ich net. Vorallem sind es meine ersten Schritte mit Cisco, denke, dass das aber nicht zu kompliziert sein dürfte, schliesslich ist es nur ein Router und ein Client und kein riesen Netzwerk. Bernd Zitieren
berndwalter 10 Geschrieben 23. November 2004 Melden Geschrieben 23. November 2004 Ach ja, ich navigier gerade durch das ganze Telnet. Gibt es die Konfiguration nicht auch als File, damit ich, wie in Linux unter /etc das File einfach editieren kann? oder muss ich die Befehle nach und nach hacken? Zitieren
berndwalter 10 Geschrieben 23. November 2004 Melden Geschrieben 23. November 2004 :suspect: Das geht ja! :suspect: Ich hab das ganze mit dem Configmaker zusammengeklickt und per Telnet die entsprechende MSN eingegeben und jetzt hab ich spassenhalber da angerufen und es geht! Ich bin drin! Ich komm sogar auf alle Rechner! Irre! Bernd Zitieren
