sammy2ooo 10 Geschrieben 23. September 2004 Melden Geschrieben 23. September 2004 Hallo Leutz bastel schon ne gute Zeit an meinem 801er rum und bekomm den einfach nicht online. Da ich Cisco Neuling bin und die Kiste trotzdem via Telnet konfigurieren möchte, habe ich da noch einige Fragen. Also: cisco801#debug dialer Dial on demand events debugging is on cisco801#term mon cisco801# 00:03:48: BRI0 DDR: rotor dialout [priority] 00:03:48: BRI0 DDR: Dialing cause ip (s=192.168.1.5, d=208.185.174.52) 00:03:48: BRI0 DDR: Attempting to dial 0191011 00:03:240518168576: BRI0: wait for isdn carrier timeout, call id=0x8001 00:03:240518168576: BRI0 DDR: Attempting to dial 00191011 00:03:240518168576: BRI0: wait for isdn carrier timeout, call id=0x8002 00:03:240524393548: DDR: Dialing failed, 1 packets unqueued and discarded 00:04:17179869184: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 78 changed to up Hab auch schon versucht die vorangestellte null wegzulassen, hat nix gebracht. Hier mal die Ausgabe von "show running-config" Current configuration: ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname cisco801 ! enable secret 5 xxxxxxxxxxxx ! ip subnet-zero ! ip dhcp pool DHCPpool_1 network 192.168.1.0 255.255.255.0 dns-server 194.25.2.129 default-router 192.168.1.254 ! no ip domain-lookup isdn switch-type basic-1tr6 isdn voice-call-failure 0 ! interface Ethernet0 description connected to EthernetLAN ip address 192.168.1.254 255.255.255.0 no ip directed-broadcast ip nat inside ! interface BRI0 description connected to Internet no ip address no ip directed-broadcast encapsulation ppp dialer rotary-group 0 isdn switch-type basic-1tr6 ! interface Dialer0 ip address negotiated no ip directed-broadcast encapsulation ppp dialer in-band dialer idle-timeout 300 dialer string 0191011 dialer string 00191011 dialer hold-queue 10 dialer load-threshold 10 outbound dialer-group 1 ppp authentication pap callin ppp pap sent-username xxxxxxxxxxxx password 7 xxxxxxxxxxxx ppp multilink ! interface Dialer1 description connected to Internet ip address negotiated no ip directed-broadcast ip nat outside encapsulation ppp no ip split-horizon dialer in-band dialer string 0191011 class 56K dialer hold-queue 10 dialer-group 1 no cdp enable ppp authentication chap pap callin ppp chap hostname xxxxxxxxxxxx0001 ppp chap password 7 00728052 ppp pap sent-username xxxxxxxxxxxx0001 password 7 xxxxxxxxxxxx ! router rip version 2 passive-interface Dialer1 network 192.168.1.0 no auto-summary ! ip nat inside source list 1 interface BRI0 overload no ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ip route 0.0.0.0 0.0.0.0 192.168.1.1 ip route 0.0.0.0 0.0.0.0 192.168.2.1 ip route 192.168.2.1 255.255.255.255 Dialer0 ! map-class dialer 56K dialer isdn speed 56 access-list 1 permit 192.168.1.0 0.0.0.255 access-list 1 permit 0.0.0.0 255.255.255.0 dialer-list 1 protocol ip permit snmp-server engineID local 000000090200000142333BEE ! line con 0 exec-timeout 0 0 password xxxxxxxxxxxx login transport input none stopbits 1 line vty 0 4 password xxxxxxxxxxxx login ! end Gibt es eine Möglichkeit diese Konfiguration mit einem Editor zu bearbeiten? Als Bashliebhaber macht mich diese Shell noch krank :) Höffe ihr könnt mir weiterhelfen. Gruß Zitieren
thorgood 10 Geschrieben 23. September 2004 Melden Geschrieben 23. September 2004 isdn switch-type basic-1tr6 Hast du wirklich altes ISDN Versuche es mit isdn switch-type basic-net3 Zitieren
sammy2ooo 10 Geschrieben 23. September 2004 Autor Melden Geschrieben 23. September 2004 danke für deine Antwort. Nein, da hast du recht, wir haben kein altes ISDN. Hab nun isdn switch-type basic-net3 eingestellt. Allerdings hat das das Problem nicht gelöst. Komischerweise bekomme ich nun kein debug output mehr!! --> en debug dialer term mon <-- oder??? Noch nen Tip? Wie kann ich eigentlich den 2ten Dialerstring wieder ändern? --> en config interface dialer dialer string 0191011 <-- ändert immer nur den ersten string ?? Gruß Zitieren
thorgood 10 Geschrieben 23. September 2004 Melden Geschrieben 23. September 2004 Mit no dialer string 00191011 versuche manuelles wählen mit isdn call int bri 0 0191011 dann schau dir das ergebnis an mit sh isdn hist und disconnecten mit isdn dis int bri 0 all thorgood Zitieren
Hr_Rossi 10 Geschrieben 23. September 2004 Melden Geschrieben 23. September 2004 hi du musst das physikalische interface bri0 einen dialer pool hinzufügen dialer pool-member 1 und am logischen interface sprich dialer1 - dialer... dialer pool 1 angeben das bindet die logischen dialer an das phys. interface so müsste es klappen mfg rossi Zitieren
sammy2ooo 10 Geschrieben 23. September 2004 Autor Melden Geschrieben 23. September 2004 also folgendes hab ich probiert cisco801#debug dialer Dial on demand events debugging is on cisco801#term mon cisco801#isdn call interface bri 0 0191011 cisco801# 00:01:01: BRI0 DDR: Attempting to dial 0191011 00:01:21474836480: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up 00:01:05: BRI0:1 DDR: disconnecting call 00:01:05: BRI0:2 DDR: disconnecting call 00:01:05: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down 00:01:05: %SYS-2-INTSCHED: 'suspend' at level 4 -Process= "PPP manager", ipl= 4, pid= 44 -Traceback= 3101C 198C88 198DB8 31EC78 31F2AC 2C9F98 2CAD3C 2F3F10 2F4110 2F42D4 395ED0 3A4380 39C624 39C7FC 395ED0 3980CC 00:01:21474877440: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 87 changed to up 00:01:13: BRI0:1 DDR: disconnecting call und dann macht die kiste einen neustart!!! Was ich nicht verstehe: Warum steht da 00:01:01: BRI0 DDR: Attempting to dial 0191011 Laut meiner config sollte dialer in-band deaktiviert sein, oder etwa nicht??? hier nochmal meine neue config ! version 12.0 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname cisco801 ! enable secret 5 $xxxxx ! ip subnet-zero ! no ip domain-lookup isdn switch-type basic-net3 isdn voice-call-failure 0 ! interface Ethernet0 description connected to EthernetLAN ip address 192.168.1.254 255.255.255.0 no ip directed-broadcast ip nat inside ! interface BRI0 description connected to Internet no ip address no ip directed-broadcast encapsulation ppp dialer rotary-group 0 isdn switch-type basic-net3 ! interface Dialer0 ip address negotiated no ip directed-broadcast encapsulation ppp dialer idle-timeout 300 dialer string 0191011 dialer hold-queue 10 dialer-group 1 ppp authentication pap callin ppp pap sent-username xxxx0001 password 7 xxxxx ! router rip version 2 network 192.168.1.0 no auto-summary ! ip nat inside source list 1 interface BRI0 overload no ip http server ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 0.0.0.0 0.0.0.0 192.168.1.1 ip route 0.0.0.0 0.0.0.0 192.168.2.1 ip route 192.168.2.1 255.255.255.255 Dialer0 ! access-list 1 permit 192.168.1.0 0.0.0.255 access-list 1 permit 0.0.0.0 255.255.255.0 dialer-list 1 protocol ip permit ! line con 0 exec-timeout 0 0 password xxxxx login transport input none stopbits 1 line vty 0 4 password xxxxx login ! end gruß Zitieren
Hr_Rossi 10 Geschrieben 23. September 2004 Melden Geschrieben 23. September 2004 ach bei dial on demand routing sprich DDR muss die verb. von aussen initiiert werden sonst geht gar nix binde die log. interface an das phys. und schmeiss die rotary group raus brauchst ned dann versuch über einen ping vom ethernet aus die isdn verb. zu initieren sprich schau das dein routing passt bsp. interface BRI1/0 no ip address no ip directed-broadcast encapsulation ppp dialer pool-member 1 isdn switch-type basic-net3 isdn answer1 xxxxxxx isdn answer2 xxxxxxx isdn calling-number xxxxxxx no cdp enable interface Dialer3 description xxxxx ip address negotiated no ip directed-broadcast ip nat outside encapsulation ppp dialer idle-timeout 90 dialer string xxxxxxx dialer hold-queue 20 dialer pool 1 dialer-group 1 no cdp enable ppp authentication chap callin ppp chap hostname xxxxxx ppp chap password xxxxxxxxx mfg rossi am bri0 interface die isdn calling number ist DEINE isdn nummer sowie ISDN answer 1&2 für beide kanäle Zitieren
