Cisco 2610 und SDSL PPPoE Einwahl
habe ein Problem mit einem 2610 an einer SDSL Leitung mit fixer IP der T-Com.
Problem ist das ich die Einwahl per PPOE nicht hinbekomme.
Freue mich auf Hilfe.
Hier mal ein sh running und ein debug ppp auth
2MBSDSL>enable
Password:
2MBSDSL#show running
Building configuration...
Current configuration : 1269 bytes
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname 2MBSDSL
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxx!
no aaa new-model
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ftp-server write-enable
interface Ethernet0/0
description SDSL
no ip address
ip nat outside
full-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface Ethernet1/0
description Internes Lan
ip address 192.168.0.200 255.255.255.0
ip nat inside
full-duplex
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
description T-Com SDSL mit fester ip
ppp pap sent-username t-online-com/fest.ipxxx.xxx.xxx.x/userxxxxxxxxxxx@t-online-com.de password 0 xxxxxxxxxxxxxxx
no ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
2MBSDSL#
Und hier nun mal ein deb ppp auth
2MBSDSL#terminal monitor
2MBSDSL#debug ppp auth
PPP authentication debugging is on
2MBSDSL#
2MBSDSL#
*Mar 1 04:54:23.074: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 04:54:23.074: Vi1 PPP: Using dialer call direction
*Mar 1 04:54:23.078: Vi1 PPP: Treating connection as a callout
*Mar 1 04:54:23.078: Vi1 PPP: Authorization required
*Mar 1 04:54:23.078: Vi1 PPP: No remote authentication for call-out
*Mar 1 04:54:23.082: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 04:54:23.082: Vi1 DDR: Dialer statechange to up
*Mar 1 04:54:23.142: Vi1 PPP: No authorization without authentication
*Mar 1 04:54:23.142: Vi1 PAP: Using hostname from interface PAP
*Mar 1 04:54:23.142: Vi1 PAP: Using password from interface PAP
*Mar 1 04:54:23.142: Vi1 PAP: O AUTH-REQ id 1 len 69 from "t-online-com/xxx.xxx.xxx.x/xxxxxxxxxxxxxxxxx@t-online-com.de"
*Mar 1 04:54:23.679: Vi1 PAP: I AUTH-NAK id 1 len 24 msg is "Zugriff verweigert "
*Mar 1 04:54:23.691: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 04:54:23.699: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
*Mar 1 04:54:46.187: %DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 04:54:46.187: Vi1 PPP: Using dialer call direction
*Mar 1 04:54:46.187: Vi1 PPP: Treating connection as a callout
*Mar 1 04:54:46.191: Vi1 PPP: Authorization required
*Mar 1 04:54:46.191: Vi1 PPP: No remote authentication for call-out
*Mar 1 04:54:46.191: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Mar 1 04:54:46.195: Vi1 DDR: Dialer statechange to up
*Mar 1 04:54:46.264: Vi1 PPP: No authorization without authentication
*Mar 1 04:54:46.264: Vi1 PAP: Using hostname from interface PAP
*Mar 1 04:54:46.264: Vi1 PAP: Using password from interface PAP
*Mar 1 04:54:46.264: Vi1 PAP: O AUTH-REQ id 1 len 69 from "t-online-com/xxx.xxxxxx./xxxxxxxxxxxxx@t-online-com.de"
*Mar 1 04:54:46.480: Vi1 PAP: I AUTH-NAK id 1 len 24 msg is "Zugriff verweigert "
Hallo Sickgolem
Willkommen im Board.
Vom Grundgerüst her sollte das so aussehen.
hostname 2MBSDSL
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
no ip address
pppoe enable
ip nat inside
interface Dialer1
ip address 217.xxx.xxx.xxx 255.255.255.248
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname t-online-com/fest.ipxxx.xxx.xxx.x/userxxxxxxxxxxx@t-online-com.de
ppp chap password 7 xxxxxx
ppp pap sent-username t-online-com/fest.ipxxx.xxx.xxx.x/userxxxxxxxxxxx@t-online-com.de password 7 xxxxxx
access-list 1 permit 192.168.0.0 0.0.0.255
thorgood
habe die config etwas geändert.
Anbei die show running.
Problem ist aber leider noch immer vorhanden.
Hat vielleicht jemand einen Tip,
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname 2MBSDSL
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
no ip subnet-zero
no ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
description SDSL
no ip address
ip nat outside
full-duplex
pppoe enable
ip nat inside
full-duplex
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname t-online-com217.xxx.xxx.xxxTBxxxxxxxxxxxxx6@t-online-com.de
ppp chap password 0 xxxxxxxxxxxxxx
ppp pap sent-username t-online-com217.xxx.xxx.xxxTBxxxxxxxx@t-online-com.de password 0 xxxxxx
no ip classless
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxx
login
end
2MBSDSL#
00:04:17: Vi1 PPP: Using dialer call direction
00:04:17: Vi1 PPP: Treating connection as a callout
00:04:17: Vi1 PPP: Authorization required
00:04:17: Vi1 PPP: No remote authentication for call-out
00:04:17: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
00:04:17: Vi1 PPP: No authorization without authentication
00:04:17: Vi1 PAP: Using hostname from interface PAP
00:04:17: Vi1 PAP: Using password from interface PAP
00:04:17: Vi1 PAP: O AUTH-REQ id 1 len 67 from "t-online-com217.xxx.xxx.xxxTBxxxxxxxxxx@t-online-com.de"
00:04:17: Vi1 PAP: I AUTH-NAK id 1 len 39 msg is "0012 PSFFM002 0345625243 test user"
00:04:17: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
00:04:17: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
hier mal meine runnining conf.
Stehe echt auf dem Schlauch.
Neues Benutzerkonto erstellen
Anmelden
