white-horse 10 Geschrieben 1. Oktober 2004 Melden Geschrieben 1. Oktober 2004 Hallo, ich hätte da mal ein paar Fragen zum Thema Browsing. Browstat gibt folgende Meldung aus: C:\>browstat status Status for domain DOM1 on transport \Device\NwlnkNb Browsing is active on domain. Master browser name is: PC019HS Master browser is running build 2600 2 backup servers retrieved from master PC019HS \\PC032HS \\PC019HS Unable to retrieve server list from PC019HS: 71 Status for domain DOM1 on transport \Device\NetBT_Tcpip_{AE120E11-E286-4666-B8 3B-95570BFC5B61} Browsing is active on domain. Master browser name is: RSA1 Master browser is running build 2195 3 backup servers retrieved from master RSA1 \\RSC1 \\RSC4 \\RSA2 There are 24 servers in domain DOM1 on transport \Device\NetBT_Tcpip_{AE12 0E11-E286-4666-B83B-95570BFC5B61} There are 4 domains in domain DOM1 on transport \Device\NetBT_Tcpip_{AE120 E11-E286-4666-B83B-95570BFC5B61} Status for domain DOM1 on transport \Device\NwlnkIpx Browsing is active on domain. Master name cannot be determined from GetAdapterStatus. Using \\PC031HS Could not connect to registry, error = 5 Unable to determine build of bro wser master: 5 Unable to determine server information for browser master: 5 2 backup servers retrieved from master PC031HS \\PC031HS \\PC030HS Unable to retrieve server list from PC031HS: 71 Jetzt hierzu meine Fragen: 1. Gibts einen Unterschied zwischen den MasterBrowser des NwlinkIpx-Protokolles und von TCP/IP? Schaut zumindest so aus?!? 2.Wie kann ich diesm Probl auf die Schliche kommen? Could not connect to registry, error = 5...... Status for domain DOM1 on transport \Device\NwlnkIpx Browsing is active on domain. Master name cannot be determined from GetAdapterStatus. Using \\PC031HS Could not connect to registry, error = 5 Unable to determine build of bro wser master: 5 Unable to determine server information for browser master: 5 2 backup servers retrieved from master PC031HS \\PC031HS \\PC030HS Unable to retrieve server list from PC031HS: 71 Ich finds sowieso selzam das der MasterBrowser für NwlinkIpx der pc031hs ist. Das ist nämlich ein Windows 2000 Prof PC. Müsste die Rolle nicht ein Server inne haben, der OS-Level von W2k Server sollte doch höher sein oder? Irgendwas funktioniert nicht 100% mit dem Browsing. Wenn ich aufs Netzwerk zugreife dauert das manchmal zwischen 5 und 10 Sekunden. Dann geht es mal wieder ganz schnell. Das Problem tritt sporatisch auf. Das Problem ist erst aufgetreten nachdem ich den Novell-Client 4.9 auf die Citrix-Server installiert habe. Davor ging alles ohne Probleme. Danke für jeden Tip. Gruß Patrick Zitieren
marka 589 Geschrieben 1. Oktober 2004 Melden Geschrieben 1. Oktober 2004 In der Registry (Frag' bitte im Mom. nicht wo...) gibt es einen Key, der bestimmt, welches Verhalten der PC bei der Aushandlung des Masterbrowsers hat. Ich weiß nur, dass der Reg-Pfad in einem der MOC-Ordner steht... Zitieren
white-horse 10 Geschrieben 1. Oktober 2004 Autor Melden Geschrieben 1. Oktober 2004 Original geschrieben von marka In der Registry (Frag' bitte im Mom. nicht wo...) gibt es einen Key, der bestimmt, welches Verhalten der PC bei der Aushandlung des Masterbrowsers hat. Ich weiß nur, dass der Reg-Pfad in einem der MOC-Ordner steht... Hallo, ich nehme an du meinst den Pfad hier oder?: HKLM/System/CurrentControlSet/Services/Browser/Parameters Hier gibts drei Einträge: - DirectHostBinding - IsDomainMaster - MaintainServerList Bei IsDomainMaster gibts doch, wenn ich richtig liege folgende Optionen oder? - Yes == Wird bevorzugt als DomainMaster eingesetzt - No == Wird nicht als DM verwendet - TRUE == ? - FALSE == ? Bei MaintainServerList - Yes ? - No ? Für was steht MaintainServerList? Danke für Tips Gruß Patrick Zitieren
