Topology changed
Heut morgen hab ich mal so die Logfiles der Switche durchgeschaut und musste feststellen, das die Topology sich sehr oft ändert.
Nortel Passport 1612
953 2004/10/17 11:34:28 Topology changed
952 2004/10/17 11:30:57 Topology changed
951 2004/10/15 14:48:04 Topology changed
950 2004/10/15 14:47:21 Topology changed
949 2004/10/13 12:32:40 Topology changed
948 2004/10/13 12:29:15 Topology changed
947 2004/10/11 14:06:36 Topology changed
946 2004/10/11 07:17:01 Topology changed
945 2004/10/11 07:16:14 Topology changed
944 2004/10/11 07:06:15 Topology changed
943 2004/10/11 07:02:22 Topology changed
942 2004/10/08 15:57:14 Topology changed
941 2004/10/08 15:56:29 Topology changed
940 2004/10/07 11:22:59 Topology changed
939 2004/10/04 11:11:17 Topology changed
938 2004/10/04 11:10:32 Topology changed
937 2004/10/04 10:53:54 Topology changed
936 2004/10/04 10:53:09 Topology changed
935 2004/10/04 07:11:11 Topology changed
934 2004/09/29 12:01:05 Topology changed
933 2004/09/29 12:00:21 Topology changed
932 2004/09/27 13:55:50 Topology changed
931 2004/09/27 12:18:23 Topology changed
930 2004/09/27 12:15:04 Topology changed
929 2004/09/23 11:49:35 Topology changed
928 2004/09/23 11:48:51 Topology changed
927 2004/09/23 08:09:20 Topology changed
926 2004/09/22 13:51:21 Topology changed
925 2004/09/22 13:25:16 Topology changed
924 2004/09/22 08:25:58 Topology changed
923 2004/09/22 08:25:14 Topology changed
922 2004/09/21 08:31:11 Topology changed
921 2004/09/17 14:58:57 Topology changed
920 2004/09/17 14:58:13 Topology changed
919 2004/09/17 14:39:32 Topology changed
918 2004/09/15 10:43:38 Topology changed
917 2004/09/15 10:42:54 Topology changed
916 2004/09/08 12:00:36 Topology changed
915 2004/09/08 11:59:53 Topology changed
914 2004/09/08 11:28:22 Topology changed
913 2004/09/08 11:27:38 Topology changed
912 2004/09/06 17:28:01 Topology changed
911 2004/09/02 08:02:21 Topology changed
910 2004/08/31 10:56:42 Topology changed
909 2004/08/31 10:43:08 Topology changed
908 2004/08/31 10:42:25 Topology changed
907 2004/08/27 07:42:25 Topology changed
906 2004/08/27 07:31:17 Topology changed
oder ist das normal ? :confused:
Ich dachte immer die Topology würde sie nur ändern wenn ein neuer Switch mit niedriger BridgeID ins Netz kommt oder wenn es neue redundante Wege gibt. Es kann es auch sein das wenn viel Lasst auf dem Netz ist, die Wegkosten neu berechnet werden und deshalb die Topology sich wieder ändert? Is tmir irgendwie ein Rätsel.
Das nächste Problem ist, das mir auf dem eine Switch die Ports im hoch und runter fahren.
Nortel Passport 1648
4147 2004/10/18 07:23:49 Login failed through Telnet (Usernam
4146 2004/10/17 11:30:48 Topology changed
4145 2004/10/17 11:30:29 Port 4 link up, 100Mbps FULL duplex
4144 2004/10/17 11:30:27 Port 4 link down
4143 2004/10/17 11:30:25 Port 3 link up, 100Mbps FULL duplex
4142 2004/10/17 11:30:23 Port 3 link down
4141 2004/10/17 11:30:21 Port 2 link up, 100Mbps FULL duplex
4140 2004/10/17 11:30:19 Port 2 link down
4139 2004/10/17 11:30:17 Port 1 link up, 100Mbps FULL duplex
4138 2004/10/17 11:30:15 Port 1 link down
4137 2004/10/17 11:27:17 Topology changed
4136 2004/10/17 11:26:45 Port 4 link up, 100Mbps FULL duplex
4135 2004/10/17 11:26:45 Port 3 link up, 100Mbps FULL duplex
4134 2004/10/17 11:26:45 Port 2 link up, 100Mbps FULL duplex
4133 2004/10/17 11:26:45 Port 1 link up, 100Mbps FULL duplex
Das hat dazu geführt das unser Cluster etwas verrückt spielt.
Hat da jemand ne Idee?
Danke und GRuß
Osirus
Hmm, ein bisschen schwierig, wenn man das Nez nicht kennt.
Aber mal so ins Blaue :
Dadurch das bei dem einen Switch die Links flappen, könnte eine neue Spanning Tree Berechnung stattfinden. Aber das hast Du ja schon selber erkannt.
Abhilfe wäre m.M. nach die Prioritäten so zu setzen, dass genau festgelegt wird, wer Root Bridge und wer Designated Root Bridge ist.
Dann mal die Uplinks prüfen und fest einstellen (Speed/Duplex).
