T-DSL und Cisco 1721
Hallo zusammen,
ich habe ein kleines Prob beim konfigurieren eines Cisco1721 für T-DSL beim debuggen von ppp auth und dialer bekomme ich folgende Meldung:
DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 01:05:35.907: Vi1 PPP: Using dialer call direction
*Mar 1 01:05:35.907: Vi1 PPP: Treating connection as a callout
*Mar 1 01:05:35.907: Vi1 PPP: Authorization required
*Mar 1 01:05:35.911: Vi1 PPP: No remote authentication for call-out
*Mar 1 01:05:35.911: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up
*Mar 1 01:05:35.911: Vi1 DDR: Dialer statechange to up
*Mar 1 01:05:36.267: Vi1 PPP: No authorization without authentication
*Mar 1 01:05:36.267: Vi1 PAP: Using hostname from interface PAP
*Mar 1 01:05:36.267: Vi1 PAP: Using password from interface PAP
*Mar 1 01:05:36.267: Vi1 PAP: O AUTH-REQ id 1 len 55 from "xxxxx#0001@t-online.de"
*Mar 1 01:05:36.499: Vi1 PAP: I AUTH-NAK id 1 len 52 msg is "0030 PSOLD001 0857
704833 session limit exceeded"
*Mar 1 01:05:36.555: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 01:05:36.559: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o down
Meine Config sieht wie folgt aus:
version 12.3
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname cisco1721
boot-start-marker
boot-end-marker
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
no ip domain lookup
ip name-server 194.25.2.129
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface BRI0
no ip address
shutdown
interface Ethernet0
description T-DSL
no ip address
ip nat outside
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
interface FastEthernet0
description LAN
ip address 172.20.1.1 255.255.255.0
ip nat inside
speed 100
full-duplex
interface Dialer1
ip address negotiated
ip access-group 100 in
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name cisco1721
dialer idle-timeout 900
dialer string 0191011
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxx#0001@t-online.de password xxxx!
router rip
version 2
redistribute static
passive-interface Dialer1
network 172.20.0.0
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
access-list 100 remark ACL fuer Internet
access-list 100 deny udp any any eq netbios-dgm
access-list 100 deny tcp any any eq 139
access-list 100 deny udp any eq netbios-ns any
access-list 100 deny tcp any any eq 1863
access-list 100 deny udp any any eq 4000
access-list 100 deny udp any eq netbios-dgm any
access-list 100 deny udp any eq netbios-ss any
access-list 100 deny udp any range snmp snmptrap any
access-list 100 deny udp any range bootps bootpc any
access-list 100 deny tcp any eq 137 any
access-list 100 deny tcp any eq 138 any
access-list 100 deny tcp any eq 139 any
access-list 100 permit udp any any eq ntp
access-list 100 permit icmp any any echo
access-list 100 permit icmp any any echo-reply
access-list 100 permit udp any any eq domain
access-list 100 permit tcp any any eq www
access-list 100 permit tcp any any eq ftp-data
access-list 100 permit tcp any any eq smtp
access-list 100 permit tcp any any eq pop3
access-list 100 permit ip 172.20.1.0 0.0.0.255 any
access-list 100 deny ip any any log
dialer-list 1 protocol ip permit
Was mache ich falsch?
Vielen Dank für Eure Hilfe.
Zimbo
hi,
In der Config sind ein paar sachen die "komisch" ..;-)
Ich orientiere mich mal an meiner config und versuche nachzubessern.
haste du einen static ip oder dynamisch ?
haben diese einträge einen hintergrund ? (wenn nicht, dann raus)
router rip
version 2
redistribute static
network 172.20.0.0
version 12.3
hostname cisco1721
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface BRI0
no ip address
shutdown
interface Ethernet0
description T-DSL
no ip address
half-duplex
pppoe enable
description LAN
ip nat inside
speed 100
full-duplex
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip proxy arp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp pap hostname xxxx#0001@t-online.de
ppp pap password xxxx! (versuche auch mal chap zu nutzen)
router rip
version 2
redistribute static
network 172.20.0.0
no auto-summary
ppp ipcp dns request
ip classless
no ip http server
Zimbo
Hallo Zimbo,
lasse die drei einfach weg
und die Anmeldung so
ppp authentication chap pap callin
ppp chap hostname 000000000000000000000000#0001@t-online.de
ppp chap password xxxx
ppp pap sent-username 000000000000000000000000#0001@t-online.de password xxxx
danke für die Hilfe, aber es funkt immer noch nicht.
Ich bekomme immer noch die gleichen Fehler.
Di1 DDR: Cannot place call, no dialer string set.
%DIALER-6-BIND: Interface Vi1 bound to profile Di1
*Mar 1 00:45:49.475: PPPoE: Virtual Access interface obtained.
*Mar 1 00:45:49.475: PPPoE : encap string prepared
*Mar 1 00:45:49.479: [0]PPPoE 3315: data path set to Virtual Acess
*Mar 1 00:45:49.479: Vi1 PPP: No remote authentication for call-out
*Mar 1 00:45:49.483: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o up.
*Mar 1 00:45:49.483: Vi1 DDR: Dialer statechange to up
*Mar 1 00:45:49.835: Vi1 PPP: No authorization without authentication
*Mar 1 00:45:50.163: PPPoE 3315: I PADT R:0090.1a10.147b L:0004.dc0c.b59a Et0
*Mar 1 00:45:50.163: PPPoE : Shutting down client session
*Mar 1 00:45:50.163: [0]PPPoE 3315: O PADT R:0090.1a10.147b L:0004.dc0c.b59a E
t0
*Mar 1 00:45:50.163: %DIALER-6-UNBIND: Interface Vi1 unbound from profile Di1
*Mar 1 00:45:50.167: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state t
o down
*Mar 1 00:45:50.487: Di1 DDR: Cannot place call, no dialer string set.
Ich habe den RIP-Eintrag entfernt, aus dem Dialer die 3 Zeilen entfernt und zusätzlich die CHAP-Authen aktiviert.
version 12.3
hostname cisco1721
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface BRI0
no ip address
shutdown
interface Ethernet0
description T-DSL
no ip address
ip nat outside
shutdown
half-duplex
pppoe enable
description LAN
ip nat inside
speed 100
full-duplex
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxxxxxx#0001@t-online.de
ppp chap password xxxxxxx
ppp pap sent-username xxxxxxxx#0001@t-online.de password xxxx
ip classless
no ip http server
Ich finde einfach nicht den Fehler.
Danke für die Hilfe.
GRuß
Zimbo
hi,
übernehme mal so:
und vorallem neheme das shutdown raus !!!!!
version 12.3
hostname cisco1721
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface BRI0
no ip address
shutdown
interface Ethernet0
description T-DSL
no ip address
ip nat inside
half-duplex
pppoe enable
description LAN
ip nat inside
speed 100
full-duplex
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
no ip proxy arp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ip classless
no ip http server
cheers
-xymos.
besten dank, ich komme jetzt mit den Router ins http://www.
ich kann vom Router aus die DNS-Server anpingen, aber keine www-seiten. Vom Client aus geht nix, kann jediglich den Router anpingen.
Warum? Sind die ACL's falsch?
Die LAN-Seite ist OK, weil ich sonst mit einem anderem Router ins WWW gehe. Der andere ist aber ausgestellt, wenn der Cisco an ist.
Ich brauche noch einmal bitte Eure Hilfe.
BEsten Dank im voraus.
GRuß
Zimbo
das wars leider auch nicht.
die namensauflösung vom router klappt jetzt eingeschränkt.
habe folgendes gemacht:
ip domain-lookup
im Dialer
no ip proxy arp
in den ACL's habe ich folgende Zeile hinzugefügt:
komischerweise sagt er mir aber das der 53 (dns) über udp geblockt wird.
Langsam verstehe ich gar nix mehr.
Vom Client aus kann ich weder einen DNS-Server anpingen, noch eine www-domäne.
Ich bin völlig ratlos langsam.
Danke
Zimbo
hi,
poste mal deine aktuelle config ;-)
"ip name-server 194.25.2.129" brauchst du nicht, denn "ppp ipcp dns request fordert einen DNS Server" von deinem ISP an.
mit "ip domain-lookup" fungiert dein router als DNS Server.
trage mal als gateway/DNS die IP deines routers ein (im System)
cheeers
-xymos.
version 12.3
hostname cisco1721
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface BRI0
no ip address
shutdown
interface Ethernet0
description T-DSL
no ip address
ip nat outside
half-duplex
pppoe enable
description LAN
ip nat inside
speed 100
full-duplex
interface Dialer1
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp chap hostname xxxx#0001@t-online.de
ppp pap sent-username xxx#0001@t-online.de password xxx
ip classless
no ip http server
Zimbo
Warum?
Die Einwahl funktioniert doch. Router geht ins Internet.
Ich kann über Console vom Router aus öffentliche IP's anpingen, aber nicht vom Client aus.
Ich habe entweder ein Routing-Prob oder ein ACL-Prob, aber ich finde den Fehler nicht.
Der Fehler kann dann doch nicht bei der cahp-Auth liegen, oder doch?
Danke
Zimbo
hi,
klingt nach einem DNS problem.
"ip dns server"
damit kann dein router namen auflösen....
-xymos.
deine config gleicht meiner ein wenig, habe bei mir als gateway/dns die IP des routers eingetragen - funzt ohne probs.
zeige mal, was kommt wenn du:
"sh interface Dialer1" startest
