zimbo123 10 Geschrieben 31. Oktober 2004 Autor Melden Geschrieben 31. Oktober 2004 sh int dial1 zeigt folgendes: Dialer1 is up, line protocol is up (spoofing) Hardware is Unknown Internet address is 217.95.57.144/32 MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set Keepalive set (10 sec) DTR is pulsed for 1 seconds on reset Interface is bound to Vi1 Last input never, output never, output hang never Last clearing of "show interface" counters 02:49:52 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 42 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 2093 packets input, 103628 bytes 1959 packets output, 135668 bytes Bound to: Virtual-Access1 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open Open: IPCP PPPoE vaccess, cloned from Dialer1 Vaccess status 0x44, loopback not set Keepalive set (10 sec) Interface is bound to Di1 (Encapsulation PPP) Last input 00:00:07, output never, output hang never Last clearing of "show interface" counters 00:06:12 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 20 packets input, 803 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 20 packets output, 949 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions Vom PC im Netzwerk kann ich lediglich die öffentl. IP des Routers anpingen, mehr nicht. Noch nicht einmal den DNS-Server von T-Online kann ich anpingen. Danke Sorry, wenn ich so nerve, aber ich habe keine Idee wo der Fehler liegt. Gruß Zimbo Zitieren
thorgood 10 Geschrieben 31. Oktober 2004 Melden Geschrieben 31. Oktober 2004 Hallo zimbo123, die Einwahl geht doch. Am besten du wirfst mal deine access-list 100 vom Dialer1 runter. interface Dialer1 no ip access-group 100 in Dann teste ob es geht. Wenn ja, bau dir deine Accesslists in Ruhe neu auf. Beispiele findes du hier im Forum. thorgood Zitieren
phrock 10 Geschrieben 12. November 2004 Melden Geschrieben 12. November 2004 Hallo zimbo123, Problem schon gelöst? Falls nicht: Du hast in der Config 2x "ip nat outside"! interface Ethernet0 description T-DSL ip nat outside ! interface Dialer1 ip nat outside Ich bilde mir ein, mich zu erinnern, bei einem Cisco-ISDN-Workshop als Info mal mitgenommen zu haben, daß bei einer "ISDN-Connection" zwei Mal "encap ppp" (auf BRI UND auf Dialer) auch nicht funktioniert. Ich könnte mir vorstellen, daß das der Fehler ist! Auf dem Eth0 sollte kein "ip nat outside" konfiguriert sein. Bitte einfach mal probieren und Ergebnis hier posten. Viel Erfolg! Zitieren
