tseng 10 Geschrieben 23. November 2004 Melden Geschrieben 23. November 2004 Hi undzwar habe ich seit einigen tagen sus auf win2k3 laufen habe alles "richtig" eingestellt updates gemacht diese auch approved. nur sehe ich auf den clients meistens solche dinge in den logs 2004-11-23 21:54:04 20:54:04 Success IUENGINE Determining machine configuration 2004-11-23 21:54:13 20:54:13 Success IUENGINE Querying software update catalog from http://tnetpdc/autoupdate/getmanifest.asp'>http://tnetpdc/autoupdate/getmanifest.asp'>http://tnetpdc/autoupdate/getmanifest.asp'>http://tnetpdc/autoupdate/getmanifest.asp 2004-11-23 21:54:13 20:54:13 Success IUENGINE Determining machine configuration 2004-11-23 21:54:13 20:54:13 Success IUENGINE Querying software update catalog from http://tnetpdc/autoupdate/getmanifest.asp 2004-11-23 21:54:13 20:54:13 Success IUENGINE Determining machine configuration 2004-11-23 21:54:13 20:54:13 Success IUENGINE Querying software update catalog from http://tnetpdc/autoupdate/getmanifest.asp 2004-11-23 21:54:14 20:54:14 Success IUENGINE Determining machine configuration 2004-11-23 21:54:14 20:54:14 Success IUENGINE Querying software update catalog from http://tnetpdc/autoupdate/getmanifest.asp 2004-11-23 21:54:15 20:54:15 Success IUENGINE Determining machine configuration 2004-11-23 21:54:15 20:54:15 Error IUENGINE Querying software update catalog from http://tnetpdc/autoupdatedrivers/getmanifest.asp (Error 0x80190194) 2004-11-23 21:54:15 20:54:15 Success IUENGINE Shutting down ODER 2004-11-10 21:47:58 20:47:58 Success IUENGINE Starting 2004-11-10 21:47:58 20:47:58 Success IUENGINE Starting 2004-11-10 21:48:01 20:48:01 Success IUENGINE Shutting down 2004-11-10 21:48:01 20:48:01 Success IUENGINE Install started 2004-11-10 21:48:05 20:48:05 Success IUENGINE Installing SOFTWARE item from publisher com_microsoft 2004-11-10 21:48:05 20:48:05 Success IUENGINE Installer Command Type: EXE 2004-11-10 21:51:34 20:51:34 Error IUENGINE See iuhist.xml for details: Install finished (Error 0x80070643: Schwerwiegender Fehler bei der Installation.) 2004-11-10 21:51:35 20:51:35 Success IUENGINE Shutting down woran kann das liegen mit den fehlern kann ich nicht wirklich etwas anfangen update modus ist 4 clients können tnetpdc auflösen clients sind nur lokale admins danke Zitieren
solinske 10 Geschrieben 24. November 2004 Melden Geschrieben 24. November 2004 sind die ntfs rechte ok ? /clientseitig) wurden schon patches über den sus installiert ? Zitieren
MikeKellner 10 Geschrieben 24. November 2004 Melden Geschrieben 24. November 2004 Hier wird Dir heholfen Error 0x80190194 http://support.microsoft.com/default.aspx/kb/842773/DE/? Error 0x80190194 http://support.microsoft.com/default.aspx?scid=kb;de;326596 Gruss Mike Zitieren
