801 einwahl und danach reboot
hab da folgendes Problem, mein 801 Router connected sich kurz (abzulesen an den LEDs) und nach etwa 3 sec macht er einen Reboot. Jedesmal wenn er versucht zu wählen das selbe Spiel, woran liegts?
Habe folgende config mit ConfigMaker erstellt
DD-Cisco-Router#sh start
Using 1998 out of 8060 bytes
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname DD-Cisco-Router
enable secret ****
username NOF2224 password 0 nofelet
ip subnet-zero
ip dhcp pool 1
network 192.168.10.0 255.255.255.0
domain-name home-zone.local
default-router 192.168.10.1
dns-server 192.168.10.1
ip dhcp pool Cisco-Router
netbios-name-server 192.168.10.1
lease 8
no ip domain-lookup
isdn switch-type basic-net3
isdn voice-call-failure 0
interface Ethernet0
description connected to EthernetLAN
ip address 192.168.10.1 255.255.255.0
no ip directed-broadcast
ip nat inside
interface BRI0
description connected to Arcor 18-9
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
no cdp enable
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer string *****
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname blabla
ppp chap password *****
ppp pap sent-username blabla password *****
router rip
version 2
passive-interface Dialer1
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 100 deny ip any any
access-list 100 permit ip any any
dialer-list 1 protocol ip permit
snmp-server engineID local 0000000902000002176351EC
line con 0
exec-timeout 0 0
password *****
absolute-timeout 60
login
transport input none
stopbits 1
line vty 0
password *****
absolute-timeout 60
login
line vty 1 4
password *****
login
rcapi server port 2578
end
net3 müsste ja richtig sein, habe schonmal 1tr6 ausprobiert aber da macht er dann gar nichts noch nicht einmal einen reboot *grins*
danke schonmal in voraus
MacabroS
Hi @all
ersteinmal danke für die vielen Antworten
IOS Version ist 12.0(7)XV, early Deplyment Release Software (fc1) falls das noch wichtig ist... Wie sicher ist es das es am IOS liegt?
wenn ich dialer pool-member 1 hinzufügen kommt die fehlermeldung %remove legacy DDR configuration first
bei dialer pool 1
%remove Dialer Profile
kann es sein das sich das mit einer konfiguration irgendwie beißt oder inkompatibel ist?
ip nat outside auf bri 0 habe ich ausgeschaltet!
Wie lese ich von dem Flash das Crash-Info aus?
Thx a lot
MacabroS
Hallo !!
Probier diese Konfig !!
interface BRI1/1
no ip address
isdn answer1 xxxxxxx
isdn answer2 xxxxxxxx #jeweils deine isdn-nummer
isdn calling-number 0xxxxxx
no cdp enable
interface Dialer1
description xxxx
ip address xxxxxxxxxxxxxxx #deine ip addresse des transitnetzes
ip address negotiated # wennsd eine zugewiesen bekommst
encapsulation ppp
dialer pool 1
dialer idle-timeout 90
dialer string xxxxxxxxxxxxxxxx #nummer des gegenüber
dialer-group 1
no cdp enable
ppp chap hostname xxxxx
ppp chap password xxxxxx!
oder was auch immer für einen authentifikation
Frohe Weihnachten
Rossi
