butcher308 10 Geschrieben 19. Januar 2005 Melden Geschrieben 19. Januar 2005 HI Leute. Versuche gerade meinen Exchange Server 2003 mit ExMerge ein Backup von einigen Mailboxen zu machen. Aber wenn ich die Mailboxen ausgewählt habe, deutsch ausgewählt und den Ordner auf c:temp gelegt habe. Kann die Mailbox nicht gesichert werden: **************************************************************** Microsoft Exchange Mailbox Merge Program, v6.5.7408.1 Start Logging:January 19, 2005 16:53:02 **************************************************************** [16:53:02] Logging Level: None [16:53:02] Reading settings from file 'C:\temp\Exmerge\EXMERGE.INI'. [16:53:02] Reading list of subjects for messages to be selected from file '' [16:53:02] Reading list of attachment names for messages to be selected from file '' [16:53:02] List of folders to be ignored has been read. 0 folders in the list. [16:53:02] Current machine locale ID is 0x409 [16:53:02] Operating System Version 5.2 (Build 3790) [16:53:08] Accessing Domain Controller 'EXCHANGE' [16:53:09] 'EXCHANGE' is running Exchange Server 2000 or later [16:53:09] Mailbox '/o=name-exchange/ou=First Administrative Group/cn=Configuration/cn=Servers/cn=EXCHANGE/cn=Microsoft System Attendant' will be ignored as its DN contains strings in the ignore list [16:53:09] Mailbox '/o=name-exchange/ou=First Administrative Group/cn=Configuration/cn=Connections/cn=SMTP (EXCHANGE)/cn={AC740D3F-A7F8-4D71-BD0F-BCBC868CA6E1}' will be ignored as its DN contains strings in the ignore list [16:53:09] Mailbox '/o=name-exchange/ou=First Administrative Group/cn=Recipients/cn=SystemMailbox{AC740D3F-A7F8-4D71-BD0F-BCBC868CA6E1}' will be ignored as its DN contains strings in the ignore list [16:53:10] Found 13 mailbox(es) homed on database 'FIRST STORAGE GROUP/MAILBOX STORE (EXCHANGE)'. [16:53:10] Ignored 3 mailbox(es) homed on database 'FIRST STORAGE GROUP/MAILBOX STORE (EXCHANGE)'. [16:53:10] Found 13 mailbox(es) homed on the specified databases. [16:53:10] Ignored 3 mailbox(es) homed on the specified databases. [16:54:49] Using attribute 'PR_MESSAGE_DELIVERY_TIME' for date operations. [16:54:49] Merging data into target store. The program will copy only those messages that do not exist in the target store. [16:54:49] Associated folder data will NOT be copied to the target store. [16:54:49] Using 'German' (0x407) as the default locale (Code page 1252) [16:54:49] All mailboxes will be processed, regardless of locale [16:54:49] Using default locale for all mailboxes [16:54:49] Initializing worker thread (Thread0) [16:54:49] Copying data from mailbox 'NAME' ('NAME') on Server 'EXCHANGE' to file 'C:\TEMP\NAME.PST'. [16:54:50] Error opening message store (MSEMS). Verify that the Microsoft Exchange Information Store service is running and that you have the correct permissions to log on. (0x8004011d) [16:54:50] Errors encountered. Copy process aborted for mailbox 'NAME' ('NAME'). [16:54:50] Number of items copied from the source store for all mailboxes processed: 0 [16:54:50] Total number of folders processed in the source store: 0 [16:54:50] 0 mailboxes successfully processed. 1 mailboxes were not successfully processed. 0 non-fatal errors encountered. [16:54:50] Process completion time: 00:00:00 IIS ist aber installiert und ich bin als Admin auf dem rechner Zitieren
Nonaminus 10 Geschrieben 19. Januar 2005 Melden Geschrieben 19. Januar 2005 Admins und ExAdmins haben keinen Zugriff auf den Postfachspeicher deer User. Vorgehensweise steht im Exmerge Readme. Die Datei ist da mit bei... Siehe auch http://www.msexchangefaq.de unter Exmerge. Da gibt es auch eine Anleitung. Zitieren
butcher308 10 Geschrieben 20. Januar 2005 Autor Melden Geschrieben 20. Januar 2005 Das ist schön, das die da drin steht. Gibt nur leider keine Readme :-( HAbe bei Microsoft Exmerge.EXE runtergeladen, entpackt und ausgeführt. Hab aber keine Readme Datei gefunden. Zitieren
AluX 10 Geschrieben 20. Januar 2005 Melden Geschrieben 20. Januar 2005 Hallo, vergib dem User mit dem Du den exmerge ausführen willst die Berechtigung "Senden Als" und "Empfangen Als" ("Send as" und "Receive as") auf den Postfachspeicher im Exchange System - Manager. Dann sollte es auch funzen.... Gruss Daniel Zitieren
GuentherH 61 Geschrieben 20. Januar 2005 Melden Geschrieben 20. Januar 2005 Hi. Hab aber keine Readme Datei gefunden Heißt ja auch nicht read.me sondern Mailbox Merge Wizard (ExMerge).doc ;) Und genauer wir Frank Carius kann es wohl keiner beschreiben - http://www.msxfaq.de/tools/exmerge.htm ;) Lg Günther Zitieren
butcher308 10 Geschrieben 20. Januar 2005 Autor Melden Geschrieben 20. Januar 2005 Danke, jetzt geht's Auch ein ganz gutes Tool mit Schritt für Schritt anweisung ist: http://spotlight.de/zforen/mbo/m/mbo-1105008740-10362.html :D Hatte vergessen die Gruppe Send As und Recive As Rechte zu geben :rolleyes: Zitieren
