WWW.Server Installation
ich möchte einen Webserver installieren und dafür Microsoft IIS verwenden.Hat
jemand von Euch Erfahrung damit? Auf was ist zu achten, weche Voraussetzungen
müssen erfüllt sein? Als Hardware setzen wir einen HP Netserver LC2000 ein.
Vielen dank im Voraus für Euere Hilfe.
Please can someone tell me how i can Installed a Webserver in my Company using
Internet infomartion Services. I used the Example in our coursebook titel Configuring
A Web Server but this did not work out for me, secondly I used the help site in internet
http://www.webmeister.ch/server/webserver/iis/default.htm it seemed that I need to configuredsomething first , this is where I need help if someone can give me detail of it.I will be very
pleased for your help.
Hi paulinus,
Resources for Installing and Using IIS 5.0
http://support.microsoft.com/support/kb/articles/Q266/1/15.ASP?LN=EN-US
IIS 5 - Installation / Upgrading, Prerequisites
http://www.iisanswers.com/articles/Upgrading_to_IIS5/Upgrading%20to%20IIS%205_FAQ.htm'>http://www.iisanswers.com/articles/Upgrading_to_IIS5/Upgrading%20to%20IIS%205_FAQ.htm
There are at least two scenarios we are concerned with, one is upgrading an existing IIS 4 server (and maybe even IIS 3 for some of you slackers). The other is installing a sparkling fresh IIS 5 server from the start.
These sites might help you in general:
http://www.iisfaq.com/
Good luck
