Quick Launch per GPO ausblenden!
Setting State
Remove user's folders from the Start Menu Enabled
Remove links and access to Windows Update Enabled
Remove common program groups from Start Menu Enabled
Remove My Documents icon from Start Menu Enabled
Remove Documents menu from Start Menu Enabled
Remove programs on Settings menu Enabled
Remove Network Connections from Start Menu Enabled
Remove Favorites menu from Start Menu Enabled
Remove Search menu from Start Menu Enabled
Remove Help menu from Start Menu Enabled
Remove Run menu from Start Menu Enabled
Remove My Pictures icon from Start Menu Enabled
Remove My Music icon from Start Menu Enabled
Remove My Network Places icon from Start Menu Enabled
Add Logoff to the Start Menu Not configured
Remove Logoff on the Start Menu Not configured
Remove and prevent access to the Shut Down command Not configured
Remove Drag-and-drop context menus on the Start Menu Enabled
Prevent changes to Taskbar and Start Menu Settings Enabled
Remove access to the context menus for the taskbar Enabled
Do not keep history of recently opened documents Enabled
Clear history of recently opened documents on exit Enabled
Turn off personalized menus Enabled
Turn off user tracking Not configured
Add "Run in Separate Memory Space" check box to Run dialog box Not configured
Do not use the search-based method when resolving shell shortcuts Not configured
Do not use the tracking-based method when resolving shell shortcuts Not configured
Gray unavailable Windows Installer programs Start Menu shortcuts Not configured
Prevent grouping of taskbar items Enabled
Turn off notification area cleanup Not configured
Lock the Taskbar Enabled
Force classic Start Menu Enabled
Remove Balloon Tips on Start Menu items Enabled
Remove pinned programs list from the Start Menu Not configured
Remove frequent programs list from the Start Menu Enabled
Remove All Programs list from the Start menu Enabled
Remove the "Undock PC" button from the Start Menu Not configured
Remove user name from Start Menu Not configured
Remove Clock from the system notification area Not configured
Hide the notification area Not configured
Do not display any custom toolbars in the taskbar Enabled
Remove Set Program Access and Defaults from Start menu Enabled
  • 8 Monate später...
Setting State
Ich finde diesen Eintrag nicht in Deutsch!? Bin ich blind??
Naja, ich würde eigentlich nur gerne diese MS Outlook-Balloontips ausschalten.
Geht das? Ich möchte nicht ständig darüber informiert sein, wenn der Client mal wieder
versucht, Daten mit dem Server (Exchange 2k3) auszutauschen...
Kann man das eingrenzen auf Outlook-Balloons oder nur komplett ausschalten.
Und wenn ja, wo? Gibt es die Funktion in den GPOs, sowie die bei XP-Antispy (die ja
wahrscheinlich nur komplett deaktiviert)?
axel
