Hallo zusammen,
Datum: xxx
Quelle: WUSyncService
Ereigniskennung 107
Tyxp Warnung
Benmutzer nicht zutreffend.
Software Update Services failed to load some configuration information. Examples of configuration information include: proxy server configuration, content location, and client locales to support. Because not all configuration information was loaded successfully, the default settings will be used instead.
User Action
To confirm your configuration, go to the Software Update Services Admin Web site (http://<YourServerName>/SUSAdmin), and click the Set options link.
Additional Data
One or more errors occurred while loading the settings file 'C:\inetpub\wwwroot\autoupdate\dictionaries\settings.txt'. (Error 0x80070057: Falscher Parameter.)
For more information about administering a server running Software Update Services and for a list of the default values, see the Microsoft Software Update Services Deployment Guide (http://go.microsoft.com/fwlink/?LinkId=6928).
Weitere Informationen über die Hilfe- und Supportdienste erhalten Sie unter http://go.microsoft.com/fwlink/events.asp.
Was ist den das für ein Mist, im google oder im Internet kann man darüber nichts finden??? Was kann man dagegen tun?
Apache
Und da dort der Link nicht mehr aktuell ist.
http://www.microsoft.com/windowsserversystem/updateservices/evaluation/previous/faq.mspx
Q. Why do I get warnings in the System event log about event ID 107 on my SUS server?
A. This message is erroneous and can be safely ignored. The Synchronization Service works properly, and you should be able to carry out the SUS administration tasks as usual.
thorgood
