W2k AS SP4: dcdiag bringt Fehler frssysvol
Hallo zusammen:
Sind hier mit unserem Latein am ende!
Haben eine Domäne mit 4 Servern (w2k AS SP4):
SRV1: RID-Betriebsmaster, PDC-Betriebsmaster, GC, DNS
SRV2: Infrastruktur-Betriebsmaster, GC, SUS, DHCP, DNS2
Die anderen beiden sind in anderen Subdomains.
DCDIAG liefert nun bei frssysvol folgenden Fehler zurück:
DC Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial non skippeable tests
Testing server: Standardname-des-ersten-Standorts\SRV2
Starting test: Connectivity
......................... SRV2 passed test Connectivity
Doing primary tests
Starting test: Replications
[sRV3] DsBind() failed with error 1722,
Der RPC-Server ist nicht verf³gbar..
......................... SRV2 passed test Replications
Starting test: NCSecDesc
......................... SRV2 passed test NCSecDesc
Starting test: NetLogons
......................... SRV2 passed test NetLogons
Starting test: Advertising
......................... SRV2 passed test Advertising
Starting test: KnowsOfRoleHolders
......................... SRV2 passed test KnowsOfRoleHolders
Starting test: RidManager
......................... SRV2 passed test RidManager
Starting test: MachineAccount
......................... SRV2 passed test MachineAccount
Starting test: Services
......................... SRV2 passed test Services
Starting test: ObjectsReplicated
......................... SRV2 passed test ObjectsReplicated
Starting test: frssysvol
Error: No record of File Replication System, SYSVOL started.
The Active Directory may be prevented from starting.
......................... SRV2 passed test frssysvol
Starting test: kccevent
......................... SRV2 passed test kccevent
Starting test: systemlog
......................... SRV2 passed test systemlog
Running enterprise tests on : mthrgt25.svc
Starting test: Intersite
......................... mthrgt25.svc passed test Intersite
Starting test: FsmoCheck
......................... mthrgt25.svc passed test FsmoCheck
Die verzeichnisdienstwiederherstellung hat zu keinem Erfolg geführt.
Hinweis: Es handelt sich hierbei lediglich um eine lokale Domäne, nicht um eine im Web registrierte.
Kann uns da einer helfen?
Mit freundlichem Gruß
Salay (SU)
